Battery powered chainsaw
/ Battery powered chainsaw #1,101
Milwaukee has jumped on the dual battery bandwagon. Their model 2827-22 is claimed to have the power of a 70cc gas chainsaw.
I have not lid eyes on one yet.
That I’d like to see.
/ Battery powered chainsaw #1,102
I have a Greenworks 60 volt chainsaw with 20 inch bar and it claims to be equivelent to 60 cc gas saw and I believe it. Had a Husky 372xp and I think it would come close to keeping up with it cutting trees under 16 inches in diameter or less and the 8 ah battery will outlast me. Gas has its place but I am going battery powered tools easier to start and no mixing fuel and no carb problems.
/ Battery powered chainsaw #1,103
You can get rid of mixing and a lot of carb probs by buying motomix or Trufuel. Premixed, no ethanol and longer shelf life.
/ Battery powered chainsaw #1,104
my biggest problem is pull starting, the body is just not what it once was (81 yrs old) also I just don't like to fool with carb problems due to not using saw for long periods of time
/ Battery powered chainsaw #1,105
Do you have a saw with compression release button? That would help you a lot.
The storage problems can be alleviated with non-ethanol fuel or storage additives,
but at 81, I’d probablyt feel same as you. Just pull trigger and roll.
/ Battery powered chainsaw #1,106
Heck at 73 I feel that way already, I'm about to try a cordless leaf blower.
I pull starter mine this morning blow snow of the vehicles, danged snow was just a bit to wet to blow off nicely,ended up using a brush.
/ Battery powered chainsaw #1,107
I bought a battery saw primarily to carry in my truck to cut deadfalls out of the road. Not having to worry about stale gas and 2-cycle oil leaking in the truck is a big plus. And I carry an impact wrench in case I need to change a tire in the woods, which uses the same battery.
I used to work for the US Forest Service. Since I hadn't been to the right classes, I wasn't allowed to carry a chain saw or crosscut saw in my work truck. I had gone up to check soil conditions at a lookout and driven through a lot of snags going up. When I was at the lookout, the wind came up, and I could hear snags falling all over the place. On my way off the mountain, I had to drag a few trees which had fallen, out of the road with my tow strap. Finally ran into one that was 14 to 16-inch diameter and wedged in between live trees that I couldn't drag anywhere. It was after 1700, so dispatch had closed for the day and gone home. Nobody to come rescue me. Spent three hours cutting through the deadfall with a 14-inch carpenters toolbox saw, blistering both hands. And, I still couldn't drag the damnable thing out of the way. Ate an MRE, wrapped up in a fire shelter, and spent the night. Next morning when dispatch came back on, I called in and got a couple of sawyers headed my way. They had to cut their way in through deadfalls on the road below me. Finally got out at about 1300.
Big stink ensued. My supervisor was in trouble, because they had gone home without knowing I was back to pavement safe. I found a "Carpenters Green Wood Saw", a 34-inch version of a one man crosscut saw, and skirted the rules about me having a crosscut saw. Below 36-inches the old catalogs called them Capenters saws, and at 36-inch they became a timber tool for felling trees.
I always carry a chainsaw in my personal vehicles now.
/ Battery powered chainsaw #1,108
How do you stop bar oil from leaking?
I had one battery pole saw that leaked and one that didn't.
Guess I could just box it with a pad....?
/ Battery powered chainsaw #1,109
Very interesting story. I had a similar experience, albeit on a much smaller scale, when I was riding my mountain bike on a rugged old logging road. I was about 8 miles in, when a sudden squall hit. I was in a deep ravine and the steep walls acted like a wind tunnel. I ducked under a rock ledge for cover or I likely would have been injured. Many trees came down across the trail ahead and behind, effectively trapping me in that ravine. No cell service in that remote location so I couldn't call for help.
I had heard of situations like this, so I started carrying a 14" folding hand saw in my bike gear:
Some of the trees were a foot or more in diameter and the saw certainly wouldn't have been much help with the trunks. I was however able to limb the trunks enough so I could lift my bike & gear over them. Took about 4 hours to hack my way out and it was dark by the time I got back to my vehicle.
Never underestimate what you can do with a hand saw.
/ Battery powered chainsaw #1,110
I have lots of 20V DeWalt tools so I bought their pole saw which I love but it leaked out of box first fill, so the store gave me another one which leaks. My Greenworks saws do not.
I fabricated a hanger so it doesn't leak in garage...just when I use it.
/ Battery powered chainsaw #1,111
I usually store & carry my saws on their side with the bar on top of the oil tank. That way, gravity doesn't force the oil out.
/ Battery powered chainsaw #1,112
I carry a dewalt elect chainsaw on service truck for use during winter. I always have 6 charged batteries on truck. I do work in rural locations in winter and dont want to have to turn around because a small tree is on road
/ Battery powered chainsaw #1,113
DeWalt's chain saws have a known issue with the bar oil leaking. I keep mine drained.
/ Battery powered chainsaw #1,114
Every pole saw I have ever owned seems to leak bar oil. Oddly, my chainsaws do not, even the very old ones.
I've settled for keeping something under the pole saw, to absorb the oil that will inevitably leak. I also only fill it with a little more than needed for a quick job, rather than keeping the tank always full, like I do with my chainsaws.
/ Battery powered chainsaw #1,115
/ Battery powered chainsaw #1,117
My fingers don't like pull starting and when I must... heavy gloves help... Doc said years of over use and too many kick backs I guess...
/ Battery powered chainsaw #1,118
My old Stihl 031 used to leak oil everywhere and I always had to refill it when I used it at my mom's.
When she was done with it and gave it to me... I didn't use 30-weight like she and her helper used and surprise surprise it doesn't leak sticky bar oil!
/ Battery powered chainsaw #1,120
A friend of mine started having that problem years ago. I put a D-handle on the starter cord for his saw (Oregon calls it a mitten handle.)
The grip doesn't help those with shoulder problems, but it made all the difference in the world for him with his hand issues. It let him wrap the handle much deeper into his hand, greatly reducing the stress on his fingers.
2012 Gillig G27B102N4 Low Floor 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
PORTA POTTY (A67714)
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
2006 MACK CHN613 (A67714)
2006 MACK CHN613...
2018 MACK LR633 6X4 TA GARBAGE TRUCK (A66091)
2018 MACK LR633...
2013 WINSTON AP22024-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
