Battery powered chainsaw
/ Battery powered chainsaw #1,121
My only gas saw I have now is a Husky 395xp which has compression relief bulb which I have to use to even pull the cord. I have both left and right bad rotator cuff and rt ruptured bicep and bad fingers plus had hip replaced last year so i'm not in the best shape to be cutting firewood especially with gas chain saw.
/ Battery powered chainsaw #1,122
Amazing that with all the small/smart battery technology, nobody has tried to make an electric start, gas powered chainsaw.
Or maybe one that utilizes a power cord from a truck or tractor 12V outlet to hook up to the saw’s starter to start it. Then there’s no dead battery issues. Almost everything on wheels has a 12V outlet now, right?
Then all you need is any vehicle with a 12V battery in it to start the saw.
Someone told me McCullough might have had this decades ago.
/ Battery powered chainsaw #1,123
You already named the main problem, the weight of any battery sized sufficiently for years of trouble-free usage. Also, excepting the big boys over 75cc, most are too easy to pull over to make that any primary obstacle for most new saw buyers. A lot of 75+ year old members here may own and use chainsaws, but their new saw buying days were probably 10+ years prior, so their unique challenges don't get figured into the manufacturer's design decisions.
Running it off the tractor would be pretty slick, for those who only use their saw near a tractor. You'd have to overcome the current limit of a cigarette lighter jack, usually 20A, but that could be handled with a DC/DC converter charging some big on-board capacitors, with a few seconds of charging before green-lighting for a start. 12V capacitors are not heavy, and the DC/DC converter is almost weightless.
I think it'd be a niche market item, maybe the sales forecast is just too low to justify the costs involved. Of course it's a compound problem, low sales projection leads to higher manufacturing cost per unit, on top of the already-fixed NRE costs.
I do have one saw that's a very hard pull, at 85cc with no decomp valve. I've given a few cutting partners the chance to use it, and they've all handed it back after one pull attempt. You need to yank the cord like you want to hurt the thing, but it always starts after just 1 - 3 pulls.
My saws with decomp always seem to take more pulls to self-prime with the decomp pressed, versus without, so I actually almost never bother pressing the button.
/ Battery powered chainsaw #1,124
I think there was a start assist made at one time that you could hook a drill up to.
Maybe a brushcutter or something.
Guess it did not sell well.
/ Battery powered chainsaw #1,125
With all the 3 prong outlets in farm tractors, even small Kubotas and all the trucks that now come with pick-up bed AC outlets, might even be able to make it AC, kind of like the snowblower starters. Heck, my 2020 Ram has really strong AC outlets. Use them every day.
It would need to be miniaturized.
Seems like with all the mini-electric tech out there, some whipper snapper engineer could do it.
/ Battery powered chainsaw #1,126
Yeah those flopped because you had to bring along another tool.
/ Battery powered chainsaw #1,127
When I was a kid, I remember a chainsaw my father used. It had a wind up spring contraption on the side under the pull cord mechanism. You threw a lever before shutting the saw off that would wind up the spring. The spring could then be used to start the saw again.
I don't remember the name but it was big, heavy and quite old. I think it was my grandfathers originally.
Stihl has something similar with their "Easy2Start" feature on the MS 211-C-BE saw:
but you still have to pull the cord.
/ Battery powered chainsaw #1,128
The pull is super easy on my MS250…
/ Battery powered chainsaw #1,129
AC start of a 2-stroke could work. But the power limitations of most of these outlets would eliminate the chance of a full electric chainsaw on a truck or tractor 110VAC. Most of those I've seen are limited to just 100 watts, or even a few hundred watts, but even small chainsaws usually require more like 2 kW.
My father had a 1970's electric chainsaw from Craftsman, I think it ran real close to 15A @ 110VAC, and only supported a 14"ish bar. It was hella handy for cutting firewood by the back door, quiet and never a mess, but I wouldn't want to take it into the field with me.
/ Battery powered chainsaw #1,130
Troy bilt made these years ago. It wasn’t a big success apparently.
/ Battery powered chainsaw #1,132
Yeah the dewalt 60v is WAY the heck heavier than my echo 501P or the little echo cs310-18, it's on par with my old husky 372xp. It is easier to start than the 372 though... but balance is really a lot worse...
I've actually been super impressed with the cs310 so far although I only have maybe 20hrs on it - it's a 30cc saw so you kind of have to run it all out and let it do it's thing without pushing it to hard.. but for the price.. it's light, pretty easy starting, and if you don't push it to hard.. cuts really well.. Out of my collection that's the one I've been grabbing if I need a lightweight trail cutting saw at this point.
I keep giving the dewalt a chance.. maybe I should have gone with a husky or stihl or one of the others for the electric adventure.. I guess at least I can use the 12Ah batteries in other tools worst case.
I actually have one of the Oregon CS1500 plug in saws. I bought it when I was at my last house for cutting bowl blanks to size for the lathe because the big saw annoyed the neighbors lol. It's .. well.. it's a 15a saw with a lightweight bar. If you treat it as such it's not terrible. I've ripped up to full bar length with it in dry walnut and it got the job done. It took a little while but it did ok all things considered. For light cross cutting and trimming it's not the worst saw I've ever used. The cord is kind of annoying if you have to go very far with it, but for small woodshed work or trimming turning pieces like I used it for it's not bad at all. The "self sharpening chain" is kind of a gimmick though.
/ Battery powered chainsaw #1,133
So just to make myself more clear, I was only suggesting a plug in device (ac or dc) to work as a start aid for gas powered saws for some of our senior/seasoned citizens with shoulder issues.
I’m not suggesting to trade in gas saws for AC powered, plug-in black & decker home owner saws. :)
Here's a little log sawing cleanup from yesterday
The 261C handled this with ease
Loading logs on lightly thawed ground. Slicker than owl sheet.
/ Battery powered chainsaw #1,134
I use the 450 watt outlet in my pickup bed to charge one tool battery while I use the other in my electric chainsaw.
/ Battery powered chainsaw #1,135
Me, too.
I have the DeWalt 60V stuff and I still use the impacts for mech repairs and the 60V weed wacker for light grass trimming.
The Milwaukee twin battery saw and the 1” impact for big sockets might be in my future or the Stihl 300 electric saw.
/ Battery powered chainsaw #1,136
Batteries are handy, I'd still like to find a hydraulic chainsaw for a reasonable price to try for a while.
/ Battery powered chainsaw #1,138
You see them here, they are a pain in the but to use!
Heavy stiff hydraulic hoses to pull around.
SR
I hired a tree trimmer to cut the dead limbs out of a few trees. They had a hydraulic saw in a bucket lift truck.
They fought the hoses with nearly every cut. And complained of the weight.
They finally gave up and started using a top handle 12 inch Stihl.
/ Battery powered chainsaw #1,139
Dude... is that sky for real? Not sure I'd have gotten any work done. Mesmerizing.
My desk job is warmer, I have a wood stove and couch in my office. But I miss the opportunity to see a lot of beautiful weather and sky, while staring at these screens and keyboard.
/ Battery powered chainsaw #1,140
Yes, it was a beautiful day.
That photo is a view of the estate of a world famous artist….YOU know who it is ;)
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
2016 Nissan Versa Note Hatchback (A66738)
2016 Nissan Versa...
2018 CHEVROLET SILVERADO REGULAR CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2012 HINO 258A CAB AND CHASSIS(INOPERABLE) (A67714)
2012 HINO 258A CAB...
Unused HLA HD42 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused HLA HD42...
CAT 416B 24" Bucket (A68134)
CAT 416B 24"...
