ultrarunner
Epic Contributor
- Joined
- Apr 6, 2004
- Messages
- 30,110
- Tractor
- Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
Makes sense… I have one carbide chain but never tried it…'Rocking' a chain means either hitting metal in a cut or sticking the bar in the dirt. Sounds to me like you are experiencing a pitch issue which will cause the chain links to become stiff. Can you increase the oiling rate on your saw? Mine all have adjustable rate oilers, usually a screw on the bottom of the saw and you might want to add a bit of kerosene to the bar oil to help flush the pitch away.
Not an issue here.
Nothing better than hitting metal in any cut to make for a bad day. My buddy runs carbide tooth chains because he cuts wood everywhere. Problem is, you have to have a diamond wheel (expensive) to sharpen them and they are very expensive. Solid carbide tooth chains are what first responders use, but they buy them on your dime.
Sometimes the oak is so green it squirts…
Will try kero
