Battery powered chainsaw
/ Battery powered chainsaw #361
'Rocking' a chain means either hitting metal in a cut or sticking the bar in the dirt. Sounds to me like you are experiencing a pitch issue which will cause the chain links to become stiff. Can you increase the oiling rate on your saw? Mine all have adjustable rate oilers, usually a screw on the bottom of the saw and you might want to add a bit of kerosene to the bar oil to help flush the pitch away.
Not an issue here.
Nothing better than hitting metal in any cut to make for a bad day. My buddy runs carbide tooth chains because he cuts wood everywhere. Problem is, you have to have a diamond wheel (expensive) to sharpen them and they are very expensive. Solid carbide tooth chains are what first responders use, but they buy them on your dime.
Makes sense… I have one carbide chain but never tried it…
Sometimes the oak is so green it squirts…
Will try kero
/ Battery powered chainsaw #362
My greenworks 60v works much much better with the 5amp batteries vs the 2 or 2.5amp.
/ Battery powered chainsaw #363
Agree. My DeWalt runs great on 5 amp but I don't even bother trying to use the 2 amp batteries on it anymore. Those are for drills. Same with the angle grinder.
/ Battery powered chainsaw #364
The 50 buck Bauer (tool only) 14" chainsaw I got for my wife specifically states to use either a 3AH or 5AH pack and nothing less. Nice little saw btw. Comes with an Oregon Lo Pro chain and Oregon bar with a greaseable roller nose.
Hard to go wrong for 50 bucks plus HF is running a promotion on it. You buy the saw and HF gives you a 3AH pack for zip.
/ Battery powered chainsaw #365
Is keeping those batteries refrigerated going to be the norm for you??
If it's a hot sunny day, keep your tools & spare batteries in the shade. If there's a flat heat sink nearby - like a rock or concrete slab - keep the batteries on that. Putting tools & batteries in cool damp (not wet) grass to keep them cool too.
I had a task where I had to use a biscuit joiner on some very hard wood repeatedly and I found that it was getting really warm. I broke up the job so that I could cut a bunch of slots, toss the joiner in the freezer, do some other things, get the joiner out, repeat, and it was a lot happier.
Guessing time: The 5Ah batteries probably have 2.5x more cells than the 2Ah (and 2x than the 2.5Ah), and/or the cells themselves are larger, so each cell is being asked for less so each cell isn't generating as much heat - in fact, at the same power draw, there's likely less total heat in the 5Ah than in a smaller battery, because the heat generation probably goes up faster than current draw (ie, pull 2x the current from a battery and it probably generates more than 2x the heat) so it'll handle it better.
/ Battery powered chainsaw #366
If double the cells but same voltage then cells are paralleled. This reduces the resistance allowing more current to flow.
However, larger capacity cells can be used, and internal resistances vary widely among lithium cells.
Lower resistance will result in less heat.
The borrowed EGo 16" saw strained using my fresh 2AH battery on green sasafras but did it's best with a 7.5AH. Later purchased the 18" after it came out. Came with 5AH. Loves that but didn't strain on green maple with the 2AH.
/ Battery powered chainsaw #367
There's a reason they liquid cool the battery packs on Tesla's. Especially when using it in Ludacris mode !
/ Battery powered chainsaw #368
The Tesla battery is also heated by it’s coolant.
And possibly to your surprise, it may be heated to prepare for Supercharging. When navigation comes near a Supercharger stop the car will start “preconditioning” the battery for what is to come. It tells the driver this is occurring.
If you have been in the raid for a while there is very little preconditioning needed, but if the Supercharger is 15 miles from a cold start then preconditioning starts almost immediately.
/ Battery powered chainsaw #369
Trying to keep your batteries cool while getting all-day work done is inpractical. We go into the feild with a bag that has three or more fresh battery in it. No worries.
/ Battery powered chainsaw #370
You're also in a forest; a lot of my work is done under a scorching sun in the open
/ Battery powered chainsaw #371
I've got the 62V DR electric chainsaw and a couple of 2.5 AH batteries. I love it but it has a few bad points.
Bad:
1) possible to start it accidentally by grabbing it wrong. Probably its worst feature. Found out when I unloaded the pickup in the dark one nite. Knew what happened immediately & shifted my grip before any damage occurred.
2) It's heavy. But its not an all-day saw.
3) good for a few 3-4" cuts on a fresh battery, then only good for light stuff until batt goes dead. Shuts itself off midcut if batt voltage drops too low. After a 'resting' period, you can continue the cut.
4) Takes a couple seconds to get up to speed. Seems to use a fair amt of pwr doing so.
Good:
1) very convenient to use. Part of what makes it easy to accidentally start.
2) excellent for trimming nubs and small branches off firewood. Excellent for trimming in general...if you don't mind the weight.
3) Oregon bar and chain w/greasable bar nose
4) always starts if batt good
5) tell-tale lights on batts tell how much power is left
6) batts charge fast.
My usual complement when hitting the woods (no heavy stuff expected) is:
1) DR saw with extra fully charged battery
2) Jonsered 2240 14" saw with gas and oil
3) Echo 10" polesaw
4) Bug repellant
5) lunch
Both the Jonsered and the Echo are good at starting and re-starting.
Thinking of getting DR's electric polesaw.
Bob
/ Battery powered chainsaw #372
Bob, if your DR is anything like my DeWalt, the battery is the problem. Mine won't do much with a 2 amp battery but will cut like crazy with a 5 or 6 amp battery.
/ Battery powered chainsaw #374
I just retired and no longer will be heating with wood. My only wood cutting will be for sitting around the fire pit. So I sold my 044 and will be selling my MS361 and 036 and buying a Milwaukee electric due to already having batteries. I'll keep my hopped up 026 pro for cutting campfire wood. ( being retired is amazing )
If your 361 is in good shape and you want to sell it...let me know.
/ Battery powered chainsaw #375
As I had mentioned earlier in this thread, my new Ryobi 14" chain saw was overheating the battery. I sent a note to the Ryobi help desk.
Here is the e-mail I sent to them:
RYOBI Customer Service
Ticket Information
Email: XXXXX@msn.com
Model Number: OP40404-06RGVNM
Serial Number: XXXXXXXXX
Subject: Battery model OP40404
Message:
Hello,
I am using this battery in your 14" chain saw model RY405010. Several times now I have had the saw quit. Upon checking the battery display lights I see that it was indicating "battery overheated" Is this a faulty battery? I am not continuously sawing, taking small breaks now and then.
Please let me know if this is a common thing or if this is a faulty part.
Thanks,
Richard
Here is the response I got:
From: RYOBI Tools Support <ryobi@support.ryobitools.com>
Sent: Friday, July 21, 2023 1:53 PM
To: XXXXXXX@msn.com
Subject: Re: RYOBI Customer Service [002007]
Dear Richard,
Thank you for contacting RYOBI. We apologize for our delayed response.
Unfortunately this can happen when using the saw in the summer heat, I always suggest having a couple other batteries to swap out when this happens. And throw the others in the shade while allowing them to cool down.
Sincerely,
Jesse Bridgeman
RYOBI Digital Support
So keep your batteries out of the sun and in a cooler if possible.
Richard
/ Battery powered chainsaw #376
I have two mini Makia saws and love them but one thing they can't do is heavy cutting for X amount of time. These are very light, tinny little things and found them more handy every time we've had them out. (professionally) To keep the battery from over heating we usually bring 4 to 6 full batteries with us. As other have stated the larger amp-hour ones are less prone to over heating than the small ones. We generally bring two of these saws along so if one overheats its drive motor which does happen, I simply switch to other saw.
/ Battery powered chainsaw #377
Yes it's in great shape and no saw out there is tuned better. 20" bar and a couple mid aged chains. The 036 is a great saw too but sat too long without use so I need to throw a new carb on it. I'm not sure what I would ask for the 361 I really don't. People are nuts. I see them from $250-$400. Not sure why.
/ Battery powered chainsaw #378
Gee, I own a pristine 090 as well as an 075, bought them both new when I bought my 028 about 42 years ago. I was flush back then, not now. Dang 090 sounds like a motocross bike...
Juist sold an MS290 in mint condition for 400 bucks with a 20" bar and 2 loops.
/ Battery powered chainsaw #379
Lets see some pictures of it.
/ Battery powered chainsaw #380
I have been considering one of those. Mainly for convenience. Convenience includes not needing too much redundancy at increased expense.
After two saws, 6 batteries and a charger maybe another brand like Stihl might work out just as efficiently, as long as you don’t NEED to have two people using the saws at the exact same time.
CATERPILLAR C1.5 LITER (CONDITION UNKNOWN) (A68842)
CATERPILLAR C1.5...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
DYNAPAC  CP271 PNUEMATIC ROLLER(INOPERABLE) (A67714)
DYNAPAC CP271...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2010 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A66736)
2010 Chevrolet...
