Another lightning strike another Well Control Box
/ Another lightning strike another Well Control Box
Still could be an issue with the pump.....
True , and I hope not. But the only way to know is to deal with the pump controller problem first. If the pump is bad, then that is a whole different level of suck
/ Another lightning strike another Well Control Box #22
Grew up watching the fireballs, from lightning, run the high power lines in our backyard. They let homes be built way too close back in the 60s.
One of those fireballs jumped to our transformer and followed the line to our house. Neighbors thought we were all dead. It exploded the house where it hit. Lost a lot of TVs in that house over the years. Dad and the neighbor cut down the locust trees. No strikes or surges since.
Had a 3 1/2 foot diameter poplar hit and exploded. Split the trunk in half. My lab still aint over it.
Had a spec home that the plumbing and electric had just been completed take a hit. All the wiring was fried and the copper water lines were shot. Any nails that were close to a water line arced and burnt holes in them.
At 7:29 I got a message that The box was delivered to the front door or steps. I drove to the front of the property and the box was sitting in the driveway at the gate. Not perfect, but I’ll take it. (I still gave “Jose” a thumbs up review for being on time.) I came back and installed the box. While I was doing so, my daughter asked if I needed help. Her mother washed her hair in the sink with water we brought from the tote that we have down at the barn and she wanted to be able to take a real shower again. Got it installed and we are back in business. Had to jump thru some hoops with my water heater. I keep the water set at 138 and for some reason it had changed to 177 degrees. I only found that because the pressure was low for hot water. I reset the temperature and cleaned the spin filter (hot water has it’s own filter. ) It has been an interesting 24 hours. Every time something like this happens I am confident that I know less about electricity than I thought I did.
/ Another lightning strike another Well Control Box #24
@WoodChuckDad congratulations on diagnosing the issue and getting it fixed. But, wow 177F seems like a dangerous default for the water heater to jump to.
Isn't rapid shipping wonderful?
All the best,
Peter
/ Another lightning strike another Well Control Box #25
I have surge protectors on my TV and Computer, but I'm not familiar with a whole house surge protector. Does it go before or after the breaker box? Can it handle a direct hit from lightning? The house that I mentioned earlier had the breakers that didn't stop the lightning from going through them. I'm guessing there was too much electricity for them to trip, or something like that. Maybe it just jumped across the breakers? I really don't know how that works or what lightning does when it's inside a house.
My power company installed a whole house surge protector on my house and they charge me $5/month extra on my bill. They installed it on my meter box beneath the meter. They replace it every 3-4 years.
/ Another lightning strike another Well Control Box #26
Nice DIY, guys on this forum are inventive / creative.
My service guys are on call 24/7. One of the wives used to ***** at my service guy for having to go to work on Sunday. One Sunday he shut her water off before going on a service call. She never bitched again.
/ Another lightning strike another Well Control Box #27
We live at a geographically high spot. Years ago I lost several pump motors when lightning struck a tree in the area. At some point talking to a plumber, he said I needed to ground the well casing. At first it seemed to be illogical since the well casing should be a big ground rod. But when a tree is struck the current radiates through the soil and the deep metal casing is a low resistance path, but bear in mind that the grid is a much better ground. If the case is not bonded the high voltage can arc over in the pump motor which has a better ground path to the grid through the utility box. I ran a #4 wire connected to the well casing and in the house connected to the ground connection in the box. That connection in the box also connects to the house ground rod. Since that addition I have never had a motor issue in over 20 years.
/ Another lightning strike another Well Control Box #28
After last fiasco with lightening and electricity issues I had the power company come check the lines and had electrician come out here and check my grounds and my panels. He recommended a lightening bar across the roof I dont think it actually struck the house, but I dont know how this keeps happening.
Your electrician is correct. You need a grounding bar to direct any and all lightening strikes away from the home and the well itself.
You need a flag pole away from the home or a tall tree with a lightening spiked rods. This will draw the lightening away from the home and the well area on the ground.
At the base of these devices, you need one or multiple leads to direct this high energy AWAY quickly.
Solid heavy gauge wire is required. $$$. At the ground level, you will need 9-foot thick rebar in the ground, sticking 3 to 6-inches out of the ground. Each rebar 12 feet away from each other AND at equal or closely equal wire lengths away. Energy will split evenly if the wire length is the same.
On the wire going down, it MUST be held with stand-offs from the building or tree or flag pole or telephone pole (used).
Last time I prices out a 2,000FT sized home for protection, the cost was $900 for all the parts.
2 weeks ago, my neighbors pole barn built in 1975 got lightening hit from a 2:45am storm. He lost 3 tractors, 2 Polaris UTVs, and a classic Ford Mustang GT. The blue Honda Civic got melted tires to the gravel driveway and the plastic trim burned away. When each of the propane tanks exploded, it was worse than being at an airshow as the sonic booms came thru. The reason why the firefighters couldn't get in there fast enough.
/ Another lightning strike another Well Control Box #30
My great aunt had an old lightning rod system on her old farmhouse. It had the globe on each rod and twisted wrought iron all the way down to the ground. Come to think of it she had the old standing seam metal roof too.
/ Another lightning strike another Well Control Box #31
Is this what you are suggesting?
Yes, but the wire looks too THIN to really do anything. 6mm or 1/4-inch wire is NOT going to save the building from a strong violent lightening strike. 3/8 to 5/8 thick will survive multiple hits before needing a replacement. Think of the wire as a fuse. The thicker the wire, the more power can run thru it. 5A fuse vs 20A fuse. In this case, what can withstand a bad strike and function if the storm hits 2 or 3 times more!
Another option to save cost is, buy long threaded black pipe, run it up along the house with standoffs, and connect the THICK cable from the lightening rod mast to the pipe.
The black pipe acts as the down conductor.
The image above needs stand-offs. WHY? well, who wants to scrub or repaint the wall after the strike happens! Even plaster outside walls will show the char.
So stand-offs saves you from plenty of cleaning and painting.
/ Another lightning strike another Well Control Box #32
Metal roofs for down conducts are done this way. I laugh when being inside a building with them as the whole place shakes violently when it takes a strike.
/ Another lightning strike another Well Control Box #33
For people who need more into to protect their homes, workshops, garages, barns, or solar installation, this here is an easy read.
Lightning Protection Overview - Lightning Protection Institute
IF the wire needs to BEND, it has to be a certain minimum radius, else it will not move the energy properly.
Once you are educated in the simplicity of how these work, make a parts list and make one for your needs.
/ Another lightning strike another Well Control Box #34
Sounds to me like you need to install some type of clamping device on your input feed to the control box.
/ Another lightning strike another Well Control Box #35
And to be in the opposite ground field from the lightening strike earth ground field drawn away from the house.
The higher the joule clamping rating the better the protection on electrical powered devices.
/ Another lightning strike another Well Control Box #36
When the national electrical code made us ground motors in 1990 and casing in 1993, we thought lightning strikes would multiply, they did not, they deminished.
/ Another lightning strike another Well Control Box #37
The one I see goes by the main breaker box, have to have a open spot for a breaker for the surge protector.
some wire them in with the mains incoming, some people will piggy back on a breaker. maybe not code, but works the same.
All the best,
Peter
Very dangerous. Pex tubing is rated to 180 degrees at 100 PSI
I’m not sure what you mean.
It happened again last night. Lightening storm took out the well control box. I’m not sure if I should just start a new thread or roll with this one.
I have a spare capacitor that I bought when I bought this new well pump control box
This is a two horsepower franklin brand 230 V control box. The original capacitor is BMI brand 105-126 UF. 220 VAC. The replacement is SeaKnight brand. 105-126UF 250VAC
When I bought the control box, Amazon recommended this capacitor as a replacement.
First Question
how do I know that I am connecting it properly? The Prongs are not marked. The only marking on the underside of the original is a number 4. Using the white hole as a reference point, I connected the replacement identically as the original.
In a prior incident, I used a capacitor that appeared to be rated slightly lower than the original and it blew a hole in the top, venting a gas or smoke into the room. I would very much like to not do that again. It scared me
Is the way I did it correct?
This is oroginal
This is the replacement
Second question
I could see an electrical storm rolling in so I turned off the breaker to the well pump. The storm was very dynamic with lots of loud lightning strikes. None seemed to be extremely close, but at one point we heard a distinctive electrical crack from the mechanical room. Easy to hear from bed because the master bath is unfinished, with no doors and the mechanical room is on the side of master bath. When that happened there was a corresponding flash outside but not a loud boom that would indicate a close strike
This morning, I turned the breaker back on, the pump came on and within a few seconds I heard a click that made me think the well box was turning off- the click sounded like when the reset buttons have tripped in the past. But the pump kept working. About an hour later, I was in bed and heard another click and soon there after my wife informed me that there was no water.
In a nearly Saint-like manner, and without any profanities I told my wife that I would take a look at it.
How could the storm take out the control box if I had the breaker turned off? Is it possible that a lightning strike went thru the ground and voltage came up from the well? How did this happen?
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
1043 (A60430)
1043 (A60430)
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
2022 EZ-GO ELITE...
