ANOTHER ELECTRICAL QUESTION
/ ANOTHER ELECTRICAL QUESTION #1
TBone
Platinum Member
LA (Lower Alabama)
Kubota L-2501 HST
I have a subpanel with 12 - 120v circuits. The sheathing on the romex wires coming into the panel was cut back so far that I cannot determine which hot wires are paired with which neutral. Without going into a long explanation why, I have a need to know which neutral goes with each hot wire. Anybody got any suggestions on how I can determine that? Thanks.
/ ANOTHER ELECTRICAL QUESTION #3
I have a subpanel with 12 - 120v circuits. The sheathing on the romex wires coming into the panel was cut back so far that I cannot determine which hot wires are paired with which neutral. Without going into a long explanation why, I have a need to know which neutral goes with each hot wire. Anybody got any suggestions on how I can determine that? Thanks.[/
probably the only solution is to cut out an area above the panel.
/ ANOTHER ELECTRICAL QUESTION #4
An electrician that does neat work will have the Sheathing cut back close to the cable connector. He/she will also form and layer the wires neatly in the panel.
So you need to KILL the power to the panel, trace the hot wire from the breaker to where it comes in the panel and then pull out the neutral.
/ ANOTHER ELECTRICAL QUESTION #5
I would turn the power off to the panel and disconnect all of the white, neutral wires and all of the ground wires. Then I would do a continuity test from the hot wire to the neutral wires. If one of them goes to a light, the switch will have to be on. If they all go to outlets, then the meter will make a sound when you have continuity.
How To Test For Continuity | Fluke
I can see where the light switch trick would work but if the circuit only went to outlets there would have to have a load on them wouldn't they? I don't think you would get continuity between the hot and neutral on an open circuit. I do have a good multi-meter.
/ ANOTHER ELECTRICAL QUESTION #8
They are in rigid conduit.
If they are in conduit then they should not have the outer wrap of Romex cable but just single strand wire such as THHN. To put romex in conduit I believe would be a code violation.
/ ANOTHER ELECTRICAL QUESTION #9
You can match the current. By that I mean turn off all other loads on the circuit in question. Then put a heat gun or other known load on that circuit and if it pulls 9 amps on the hot, 9 amps will be coming back on the paired neutral.
/ ANOTHER ELECTRICAL QUESTION #10
Just plug in a 110 v heater or something.
/ ANOTHER ELECTRICAL QUESTION #11
If I understand the situation (and I may not) there are twelve pairs of wires exiting your sub panel to go "wherever". It would be unusual for these wires to be in NM cable (Romex) inside a conduit. Actually it would be unusual to have rigid conduit at all. Are you sure it's not EMT? Anyhow, all these neutrals probably come from one neutral bus. Why would you even WANT to identify which neutral goes to which circuit?
/ ANOTHER ELECTRICAL QUESTION #13
Romex in conduit, bad idea. Yikes
/ ANOTHER ELECTRICAL QUESTION #14
Please go into the long explanation of why you want to know which of the neutral wires go with which of the hot wires. Because several things you have said don't make any sense. Not the least of which was you state the wires are in rigid conduit and that they are romex. So please sit down and tell us the why.
/ ANOTHER ELECTRICAL QUESTION #15
You could of course find the neutral and hot wire pairs with nothing more than a screwdriver and a lot of time, simply step one : shut off the main. Step two: unhook one of the neutral wires, Step 3 restore main power. Step 4 go around facility and find the outlet or lighting circuit that no longer works. Step 5 shut down main power, and restore the neutral wire. Step 6 flip breakers until that same circuit goes dead. Now you have found the neutral and hot black wire that matches for one circuit. Rinse repeat.
None of this make much sense to me. WHY do you want to know this?
/ ANOTHER ELECTRICAL QUESTION #16
You can buy a clamp style "AMP" meter that will clamp around the wire and do this testing safely and quickly. Follow mwayne's direction.
/ ANOTHER ELECTRICAL QUESTION #17
FLUKE meter..
/ ANOTHER ELECTRICAL QUESTION #19
I've run Romex inside thinwall for short distance when I didn't have anything else on hand. But we don't know the situation here. It's probably THHN and we'd know more if the OP told us if what is visible is solid or stranded wire.
/ ANOTHER ELECTRICAL QUESTION #20
Stranded wire inside an AC Panel? More YIKES
Truck Tractor (A61568)
2012 John Deere 6170R (A57148)
2012 John Deere...
Kuhn FC400RG (A60462)
2008 Lexus IS250 Sedan (A61569)
2008 Lexus IS250...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
2021 CATERPILLAR 262D3 SKID STEER (A62129)
2021 CATERPILLAR...
