ANOTHER ELECTRICAL QUESTION
   / ANOTHER ELECTRICAL QUESTION #11
If I understand the situation (and I may not) there are twelve pairs of wires exiting your sub panel to go "wherever". It would be unusual for these wires to be in NM cable (Romex) inside a conduit. Actually it would be unusual to have rigid conduit at all. Are you sure it's not EMT? Anyhow, all these neutrals probably come from one neutral bus. Why would you even WANT to identify which neutral goes to which circuit?
   / ANOTHER ELECTRICAL QUESTION #13
Romex in conduit, bad idea. Yikes
   / ANOTHER ELECTRICAL QUESTION #14
Without going into a long explanation why, I have a need to know which neutral goes with each hot wire
Please go into the long explanation of why you want to know which of the neutral wires go with which of the hot wires. Because several things you have said don't make any sense. Not the least of which was you state the wires are in rigid conduit and that they are romex. So please sit down and tell us the why.
   / ANOTHER ELECTRICAL QUESTION #15
You could of course find the neutral and hot wire pairs with nothing more than a screwdriver and a lot of time, simply step one : shut off the main. Step two: unhook one of the neutral wires, Step 3 restore main power. Step 4 go around facility and find the outlet or lighting circuit that no longer works. Step 5 shut down main power, and restore the neutral wire. Step 6 flip breakers until that same circuit goes dead. Now you have found the neutral and hot black wire that matches for one circuit. Rinse repeat.
None of this make much sense to me. WHY do you want to know this?
   / ANOTHER ELECTRICAL QUESTION #16
You can match the current. By that I mean turn off all other loads on the circuit in question. Then put a heat gun or other known load on that circuit and if it pulls 9 amps on the hot, 9 amps will be coming back on the paired neutral.
You can buy a clamp style "AMP" meter that will clamp around the wire and do this testing safely and quickly. Follow mwayne's direction.
   / ANOTHER ELECTRICAL QUESTION #17
I have a subpanel with 12 - 120v circuits. The sheathing on the romex wires coming into the panel was cut back so far that I cannot determine which hot wires are paired with which neutral. Without going into a long explanation why, I have a need to know which neutral goes with each hot wire. Anybody got any suggestions on how I can determine that? Thanks.
FLUKE meter..
   / ANOTHER ELECTRICAL QUESTION #19
I've run Romex inside thinwall for short distance when I didn't have anything else on hand. But we don't know the situation here. It's probably THHN and we'd know more if the OP told us if what is visible is solid or stranded wire.
   / ANOTHER ELECTRICAL QUESTION #20
Stranded wire inside an AC Panel? More YIKES
1999 Freightliner Century Class 120 Sleeper Truck, VIN # 1FUYSSEB6XL968818 (A57453)
1999 Freightliner...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
New/Unused 2025 CFG QK18R Mini Excavator (A57453)
New/Unused 2025...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
