220A welding circuit question
/ 220A welding circuit question #51
So wstf2 did we answer your question? I think things got a little muddy with all the answers but electricity is something you want to get right the first time.
/ 220A welding circuit question #52
Can you give me an NEC code reference for this color code, Black-Red-Blue?
While you're at it, can you give me a code reference for this one too?
The NEC I read every day says the grounded conductor must be white or natural grey/gray.
My error, i was thinking of one while referencing another. to correct myself, "grounded" conductors are to be white or gray, while "grounding" conductors shall be bare, green or green with a yellow stripe.
NEC code references for phasing colors can be found in the chapter wireing methods and materials while grounding requirements will be in the grounding section. (I don't have my code book in front of me to reference specific chapter, section and verse)
Note too, for high voltage, phasing array would be brown, orange, yellow which is standard color coding for 277/480
/ 220A welding circuit question #53
Color coding may be "industry standards" or "industry practice" but it is not a code requirement. Unless there are two different voltages present in the same building. Then you need to identify the conductors by separate color coding, marking tape, tagging or other approved means.
Tomorrow morning, I'm ripping out the #6 four wire feed (it's only about two feet long) and replacing with #6 three wire, happens to be black, white and bare copper. I just want to be done with the four wire/clipped white neutral. If and when we sell the place, I want it to be right for the new owner.
/ 220A welding circuit question #55
If you are that concerned about the neutral to the plug being in the panel, just clip it off as short as you can.
/ 220A welding circuit question #56
It's done all the time. As long as you clip both ends and cover them, no big deal. No need to replace with the same size wire unless there are other problems in the setup...
/ 220A welding circuit question #57
WSTF2 : That is How my welder / plasma cutter plug is wired . It is about a 18" run from breaker box to plug . Since most welder type extension cords and plugs , like the one's I listed previously , Are 3 prong , 3 wire's are all you need .
Course , if you did sell your place , the next person may be color blind and not know WTF anyway . :thumbsup:
( Seriously , my Father-in-law was color blind and after we purchased the place , some of the wiring I had to figure out was a serious WTF situation .)
Fred H.
/ 220A welding circuit question #58
I am an electrical contractor. Heres how it works. In the MAIN panel (the first panel just after the meter) the neutral and the ground can be landed on the same bus bar within the panel. Heres where it gets tricky. If there is another panel fed from this main panel, then the neutral bus MUST be insulated from the ground on the second panel(IE: The neutral bus will be mounted on a plastic spacer - all neutral wires go to this bus only. the grounds go to the ground bus.
Now, certain appliances are required to have 4 wire receptacles, such as ranges, dryers.2 hots , a neutral and a ground.
Welders only require 3 wires (2 hot and a ground). The typical welder plug will be rated 50 amps, 240 volts and have 3 prongs only.
The reason the neutral wire was added to dryers and ranges was due to the fact that these appliances have computers, light bulbs, clocks etc that required 120 volts and the older units were getting a fake 120 volts by using the ground as a fake neutral.
All you need to do is run a 6/2 copper romex to a 50 amp breaker in the panel. 2 hots and one ground.
then again, if your unsure....hire an electrician. beets getting fried.
/ 220A welding circuit question #59
The way I learned it was that you only need 2 hots to run a welder?.the ground wire is a safty factor and the neutral is not needed. I think the plug and recepticle are specific to welders.
Don't want to hijack the thread but I do have a question.
Since there are some electricians here I have a bonding question. I live on 5 acres and have been running wire to different buildings. I have a 200 amp service panel that is bonded (ground to neutral). From there I ran 1/0 w/#2 ground to a sub panel 115 feet away, then through a 4 foot high bank and out the other side about 10 feet (installed another sub panel) away from the first sub panel (again 1/0). From this sub panel I have 2 feeds. One is 75 feet of #2 and the other is 200 feet of 1/0 to my metal building. So I have 1 main panel and 4 sub panels. Three of the sub panels are not bonded. An electrician said to treat the metal building as a new structure and to bond it and use a grounding rod. The ground wire to the metal building is #6 copper and is connected to the main panel ground. Everything is 240/120 volt, 2 hot, 1 neutral, 1 ground.
My question is does the metal building " panel bonding and ground rod " seem ok since it is actually a sub panel .........only 325 feet away?
Mike
after the 2008 NEC code revision, ALL other buildings fed from one panel to another building HAVE to have a ground wire run to it along with the power and neutral legs...period.
You are also to install a ground rod at the other building in addition to the ground wire. However, if your buildings were wired prior to 2008, no worries. your not required to change anything. just make sure the other buildings have a good ground rod or rods (i always set at least 2). The reason for the bonding wires are due to the earths high resistance. The overloaded circuit cant find its path back to the source to open the circuit in a fault situation. The ground (bond) wire allows for a lower resistance path back to the breaker to open the circuit.
A fancy way of saying...more work for me.
/ 220A welding circuit question #60
Some of you seem to be confusing "grounded conductor" with ground.
GROUNDED = neutral
GROUNDING = ground
They are not interchangeable! What the OP needs is two hots (black and red) and a ground (green or bare) connected to his welding receptacle. The neutral (white) should not go to his welding receptacle. He should not use 120v romex (with a white).
That's it, period.
KJ K2545W 46'x25' Metal Garage (A60463)
KJ K2545W 46'x25'...
Bobcat A770 (A60462)
2011 WESTERN STAR  4900 SB (A60736)
2011 WESTERN STAR...
1992 VIM TRAILER MFG CRUDE TRAILER (A60736)
1992 VIM TRAILER...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
2015 Komatsu HM400-3 (A60352)
2015 Komatsu...
