Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,322
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
That makes me wonder that if fluxcore wire was used, perhaps there would have been complete root fusion throughout, since it is said that fluxcore does penetrate better than solid wire?
Yes that would be interesting. But I think in this case (flat, butt-type weld, 60deg groove) most of the "penetration" that you will get is with your grinder (pre-weld joint prep) so in this case it's not much related to the wire. If unable to groove the weld, you may have something there.
For a fillet weld, joint prep becomes more difficult and penetration more important.
Isn't that the truth. I have a Lincoln SP125+ with .035 flux core. If i get a chance this weekend I could try welding up a joint. I would have to make a jig to bend it on, but I do have the 20T press.
Can you recomend a type of joint/thickness. Not sure what I have on hand though.
I think members want to know what to do with 1/4" and 3/8" as these materials are encountered at times in 120v welding projects. No rocket science here, the same techniques are used for smaller 220v machines welding 3/4" and 1" but these details are strangely withheld from 120v users, who appear to be hungry for the tips.
I'd sure like to see how someone "experienced" would do it rather than "going all pioneer" myself. I'd like to see it & qualify it on the forum, so folks can bank & it put into use. Understand this is time-consuming, so thanks for the effort (to anyone who can find the time) ,,,,and face the grumpier members too.
