Generator install - where to start
/ Generator install - where to start
If you heat with oil get a diesel, a real generator . Not a 3600 rpm pos...
lol... I was leaning the other way, for a few reasons, in order of importance:
1. Location of propane tank is more favorable than location of oil tank.
2. Concerns with oil performance in cold weather. It's often below 0F when we lose power.
3. The relative ubiquity of propane-fired generators. Face it, they're everywhere, and options abound.
I'll admit we could bury the oil line deep to manage freezing, although we'd be snaking thru a half-dozen other utilities in that area. But still, the last several feet and the generator itself are in the cold. With our oil tank being in our basement, it's totally un-treated for cold weather.
If diesel genny could be installed in basement, instead of outdoors, then there would be many advantages of going that route. But does anyone do that?
/ Generator install - where to start #62
I've seen a few commercial generators installed inside a building. Either on ground level, or in a basement.
/ Generator install - where to start #63
People do install diesel generators in basements, often for cogeneration use, where the generator provides heat and power to the house.
However, noise/vibration and diesel odors in the house are issues to contend with. There were a few companies in New England offering that service a while back, but I have not looked recently. Addressing noise and vibration is not something that many folks are terribly good at in my experience.
For your uses, it may not make a difference, but is your house, and your call.
All the best, Peter
/ Generator install - where to start #64
Well then at least look into this...
/ Generator install - where to start #65
You might consider a little auxiliary garden "shed" to keep the generator and it's fuel tank at your desired generator location.
(Like I did) Mine is just sitting on a gravel foundation just like the shed guys sell. You will need to supply ventilation and a linear air movement thru the radiator and over the generator portion.
I handled this with just a hinged panel and "picture framed" them just like a window and simply prop them open.
I ran power to it for lights, the block heater and battery tender.
My system is 100% manual. I don't want to rely on a bunch of automatic equipment and I have very simple 3-4 step starting instructions on the refrigerator magnet for my wife to follow if she needs to.
Treating a little 100g fuel cube for winter temperatures is not a problem providing the you're diligent about it, and with a block heater you have no worries. It's also handy having fuel on hand for your tractor. 😉
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
2023 Chevrolet Express 2500 Cargo Van (A61568)
2023 Chevrolet...
2010 DMI 3200 Fertilizer Applicator (A63116)
2010 DMI 3200...
John Deere 750C Dozer (A64047)
John Deere 750C...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
