WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 15,396
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Yes, all UPS's had already been set to widest possible tolerance range, or in APC parlance, "lowest sensitivity". But given how shady APC is with all of their specmanship and vague literature, I'm honestly not sure what parameters are being adjusted. Voltage bounds only? Frequency? THD? No idea...One, see if you can adjust the input power acceptance settings on your UPS to allow a larger input power spread (+/-VAC, and a larger frequency spread).
Being the classic engineering nerd, you just know that I adjusted the governor on my genny to hold 60 Hz.Two, spend a little time with your Firman to make sure the frequency is set correctly (my suggestion would be to try for 61.5-62Hz unloaded), but try to see what works with your loads, and to dial the voltage up a bit to allow for the distance from the generator to your load and for the resulting voltage drop.
I'm not aware of any voltage adjustment mechanism. The onboard display reads 245 volts, so a hair high, but still in 240 ± 5% tolerance range. I have not checked balance on this one though, nor have I checked to see how equally both legs are loaded.
I also haven't gone so far as to hook up and check THD, spurrs, or noise, but I easily could with my o'scope. That said, hopefully I won't be relying on this stupid generator much longer.
Are any of the installed generators of the inverter type, or are they all old-school induction motor types?So, I can't guarantee that your new generator will make the UPS happy, but possibly, even probably, as the new generator probably has a better voltage regulator, and probably a larger rotor, which adds to the stored energy, which helps keep voltage and frequency within specifications. Adjusting the UPS parameters will probably help a lot, and may even completely solve your issue of the UPS switching on/off line faster than it can charge.
I should look at them, when it comes time to replace the current fleet. I actually used to buy very large industrial 3-phase UPS's, so I'm quite familiar with the options and technologies out there. I used to really like the 3-phase inverter type UPS's made by JDSU, as your equipment was never connected to the mains, there was no switching and no possibility of transient pass-thru. But they cost like $25k each for small rack-mount units 25 years ago, I can't even imagine what they'd cost today.I recommend Eaton UPS units. They aren't inexpensive, but they are in my experience rock solid, and have the ability to adjust a wide variety of parameters for the specific needs of a site.
I used to also buy 100,000 - 300,000 VA UPS's to run our test labs. They were the size of Euro refrigerators.
I went with APC here, because they were quick and cheap, when I was starting a new self-funded business. They get the job done, but maybe aren't the most robust option when trying to run off a dirty generator.
