Will DEF harm a CUT?
/ Will DEF harm a CUT? #61
Next time you need D.E.F. , just pee into the tank ! Problem solved.
Good luck with that, some folks have tried. The DEF sensor is pretty sensitive and built into the tank. Hopefully it would be a no start or derate situation before damage occurred, but I bet the sensor would be shot and it is not cheap.
/ Will DEF harm a CUT? #62
Let’s be clear here, once again I realize everybody doesn’t read the entire thread, but I think at this point the OP is 99.9% sure the DEF nozzle and the diesel nozzle were seperate. There was just confusion because the DEF nozzle was hidden.
/ Will DEF harm a CUT? #63
But...but...what about the pumps where (supposedly) the same hose and nozzle are used for both?
I've never seen or heard of that kind of setup before, but apparently some have. Oddly enough.
/ Will DEF harm a CUT? #64
I’ve been to 48-50 states and parts of Canada and I’ve never seen that setup. I’ve never seen a picture of one either. Until I do see a picture I’m going to file that one under internet rumors.
/ Will DEF harm a CUT? #65
I think there are several reasons nobody has ever seen such a setup. Somewhat like Bigfoot.
And if there is one in real life, there must be a funnel available on the pump, or some sort of reducer, to make the diesel nozzle fit the tiny DEF filler.
/ Will DEF harm a CUT? #66
Why would that be? Can't they still charge different prices for regular and dyed fuel? You might get a few ounces of dyed in your pickup, but no big deal.
Why would you fill up at 50/50 is the question
/ Will DEF harm a CUT? #67
That’s what I was about to comment next. You couldn’t get a diesel nozzle in a def tank.
/ Will DEF harm a CUT? #68
Much like that you can't put a diesel nozzle in late model gas filler neck.
They do try to make things somewhat foolproof, but that hasn't stopped people from putting gas and DEF in diesel tanks.
Haven't heard of anyone putting DEF in a gas tank yet, but give it some time.
/ Will DEF harm a CUT? #69
A BIG "thank you" to the morons at the EPA!
/ Will DEF harm a CUT? #70
HA!
Yes, we will keep everyone "safe" by limiting/controlling the functionality of everything.
Just wait till AI chips are added to tractors (or everything) to solve problems and keep everyone safe?????
/ Will DEF harm a CUT? #71
Agreed. There aren't pumps that pump diesel and gas out the same nozzle. There aren't pumps that pump diesel and DEF out the same nozzle. The pumps draw from a holding tank, there isn't some sort of solenoid that switches between which tank the fuel is drawn from.
Anyone who says they've seen pumps that pump both out of the same nozzle don't know what they're looking at.
/ Will DEF harm a CUT? #72
What if the person before you got DEF and you ask it for diesel? I KNOW that if a gas pump offers Regular, Mid, and high test that if the person before you got high test and you ask it for regular, you so in fact get *some* high test. How much I don;t know. I would certainly speak to the manager immediately. I would convince the place to shut that pump down until a proper answer is known.
/ Will DEF harm a CUT? #73
There is no pump out there that's dispensing gas and diesel from the same nozzle, let alone diesel and DEF! The DEF is behind a door to protect it from freezing. Go and look at the pumps and you'll see that! The OP even admitted that he didn't see the door for the DEF.
If there was such a pump, the lawsuits would be through the roof!
Having different grades of gasoline from same nozzles is fine as it's the same type of fuel.
Rant over.
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
Cub Cadet Pro Z 972 (A64127)
Cub Cadet Pro Z...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
CSI SLASHER GROUND SAW (A64276)
CSI SLASHER GROUND...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
John Deere 1530 Tractor (A66285)
John Deere 1530...
