FF Industrial FF18R Mini Excavator
/ FF Industrial FF18R Mini Excavator #1
Sidwuffler
Parker County, Texas
Kioti CX2510 HST
Hi Team,
I recently purchased an FF Industrial FF18R mini excavator from the auction, this is the model with the RATO 420cc engine. The unit has the pilot controls and I decided to remove all the panels ready for a complete check of fittings and a fluid change as most have advised with these Chinese units.
Please can anyone advise me if this location of what I believe is the voltage rectifier regulator, hanging loose on a small lug next to the bottom of the gas tank is safe ? it was only held in position by one hex cap screw which was not even threaded into the aluminum lug,just poked in ? I am now wondering if I will have to extend the wiring and relocate away from its present location which will be a frustrating exercise as I am no electrician.
Does anyone with an FF15 /FF18 running the RATO420cc engine know the correct location where it should be fitted in the engine bay ?
Has anyone installed a cooling fan in this FF Mini ?
Thanks in anticipation, ;)
/ FF Industrial FF18R Mini Excavator #2
I signed up for this because I saw your question. I have no idea if that is what you say it is but I can tell you this I had less than an hour on mine and it started on fire yesterday one of the hydraulic hoses on the bottom wasn't tightened all the way. if you come across a manual or any information about a wiring harness could you please let me know. Thx a million and whatever that thing is move it if you can.
/ FF Industrial FF18R Mini Excavator #3
@dkrug posted this a while ago.
The mini is all back together now, thanks for the replies. I am trying to smooth out the jerky controls, I have carried out the usual remedy for removal of air in the hydraulics but suspect I will have to carry out some more tweaks to smooth out its operation?
Would any one know the fitting size for an elbow for my FF18 hydraulic take off for a Thumb attachment which is in photo. Thanks ?
/ FF Industrial FF18R Mini Excavator #6
Have you looked at or tried the pilot control spring mod?
TBN forum post here: Pilot Control Spring Mod
/ FF Industrial FF18R Mini Excavator #8
Just ordered a set of Gen2(y)
Thanks! I see it and will get the kit on its way to you in the morning.
NOTE: While you wait for your kit to arrive, I recommend a non-petroleum based grease (e.g. Silicone or Lithium).
/ FF Industrial FF18R Mini Excavator #9
If you have not already secured your regulator/rectifier, it has vibrated loose from its mounting on the engine.
I like to relocate the Reg/Rect to the firewall of the machine. This avoids vibrating loose again, and it helps it stay cool.
Thanks for your reply. I did end up relocating and securing onto the battery platform. , see photograph.
(2) Firestone 420/80R46 Tires w/ Rims (A60463)
(2) Firestone...
Bobcat A770 (A60462)
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59908)
2006 CHEVROLET...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
SDlanch 20'x20' High End Carport (A60463)
SDlanch 20'x20'...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
Here are some similar links:
