FF Industrial FF18R Mini Excavator
   / FF Industrial FF18R Mini Excavator #1
Sidwuffler
Parker County, Texas
Kioti CX2510 HST
Hi Team,
I recently purchased an FF Industrial FF18R mini excavator from the auction, this is the model with the RATO 420cc engine. The unit has the pilot controls and I decided to remove all the panels ready for a complete check of fittings and a fluid change as most have advised with these Chinese units.
Please can anyone advise me if this location of what I believe is the voltage rectifier regulator, hanging loose on a small lug next to the bottom of the gas tank is safe ? it was only held in position by one hex cap screw which was not even threaded into the aluminum lug,just poked in ? I am now wondering if I will have to extend the wiring and relocate away from its present location which will be a frustrating exercise as I am no electrician.
Does anyone with an FF15 /FF18 running the RATO420cc engine know the correct location where it should be fitted in the engine bay ?
Has anyone installed a cooling fan in this FF Mini ?
Thanks in anticipation, ;)
   / FF Industrial FF18R Mini Excavator #2
I signed up for this because I saw your question. I have no idea if that is what you say it is but I can tell you this I had less than an hour on mine and it started on fire yesterday one of the hydraulic hoses on the bottom wasn't tightened all the way. if you come across a manual or any information about a wiring harness could you please let me know. Thx a million and whatever that thing is move it if you can.
   / FF Industrial FF18R Mini Excavator #3
@dkrug posted this a while ago.
The mini is all back together now, thanks for the replies. I am trying to smooth out the jerky controls, I have carried out the usual remedy for removal of air in the hydraulics but suspect I will have to carry out some more tweaks to smooth out its operation?
Would any one know the fitting size for an elbow for my FF18 hydraulic take off for a Thumb attachment which is in photo. Thanks ?
   / FF Industrial FF18R Mini Excavator #6
Have you looked at or tried the pilot control spring mod?
TBN forum post here: Pilot Control Spring Mod
   / FF Industrial FF18R Mini Excavator #8
Just ordered a set of Gen2(y)
Thanks! I see it and will get the kit on its way to you in the morning.
NOTE: While you wait for your kit to arrive, I recommend a non-petroleum based grease (e.g. Silicone or Lithium).
   / FF Industrial FF18R Mini Excavator #9
If you have not already secured your regulator/rectifier, it has vibrated loose from its mounting on the engine.
I like to relocate the Reg/Rect to the firewall of the machine. This avoids vibrating loose again, and it helps it stay cool.
Thanks for your reply. I did end up relocating and securing onto the battery platform. , see photograph.
2006 TK Equipment CM9 Towable Concrete Mixer (A55851)
2006 TK Equipment...
Utility Trailer (A52377)
Utility Trailer...
2013 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52706)
2013 GENIE...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
2006 INTERNATIONAL 9200I DAYCAB (A55745)
2006 INTERNATIONAL...
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
