Diggit EM15 notes, mods, etc.
/ Diggit EM15 notes, mods, etc. #1
boinger
Fairview, CA
Kubota BX23S + Diggit EM15
I'm a new EM15 owner, and while I've distilled a lot of excellent info from @dfkrug 's epic thread, I wanted to just publish a pile of info specific to the Diggit EM15s.
OEM is LeKing (Link: Mini Excavator Mfrs and Suppliers-Shandong LeKing Machinery) and OEM model is "Mini Excavator-KV13Plus" (Link: Mini Excavator-KV13Plus-Shandong LeKing Machinery)
Machine specs (some of which are listed differently in two places, so I'll include both), in case that page goes away:
Dimensions:
Wheelbase923mm or 930mm
Bucket Capacity0.03m³
Track Length1250mm
Minimum ground clearance385mm
Chassis width1100mm
Maximum digging radius2900mm or 3084mm
Track width180mm
Maximum excavation depth1735mm
Maximum digging height2545mm
Gyration radius1635mm
Shipping/delivery length2400mm
Maximum unloading height1708mm
Full vehicle height2230mm
Other info:
Total weight1000kg or 1100kg (based on bill of lading info, I think 1100kg is correct)
Rated power7.0kw/13.5hp
EngineKoop 192 (diesel) or Briggs & Stratton 420cc (petrol) or [unlisted] non-B&S 420cc (petrol)
Other specs/notes:
Tracks180 x 73K x 41
Hydraulic fittings(mostly) metric 24D-Cone
SwitchesCarling L-Series spec
Switch adapters (to a more standard size, i.e. all the Nilight-brand switches on Amazon)Best: OTR Switch Guys V-Series Rocker Switch Adapter (narrow side bezel to allow side-by-side switches without modification)
Okay: METRA - Carling Switch Adapter @ Amazon.com (if you have a belt sander, you can shave down the side bezels to make them work...or if you don't need to add enough switches that you care about side-by-side issues)
Grease tools for those needle greaser ports (until I swap them out for zerks)Link: https://amzn.to/3x2wgfz
Mods I've made so far (I'll post pics in separate posts to this thread):
Add-on fuse box
- Fuse box itselfAmazon link
(note the integrated relays to simplify everything)
- Mounting plateAmazon link
(drilled 4 holes to match the hinges on the left door, bent the plate a bit to both direct some air and avoid the battery cut-off switch, mounted using the door hinge bolts/nuts)
- hook-up cablesAmazon link
- Other stuff for wiring things inWire: red: Amazon link & black: Amazon link
Terminals: spades: Amazon link & rings: Amazon link
Cooling fan
- 10" fan (zip-tied to the inside of the left "door")Amazon link
- switch (needs switch adapter, above)Amazon link
HourmeterAmazon link (I prefer mechanical, non-resettable)
Voltmeter + USB ports (needs switch adapter, above)Amazon link
Oil drain extensionAmazon link
Traction tapeAmazon link (added on the edge of the platform and "step")
I'll add to this as I do more work on it. For example, I currently have the unbranded 420cc gas engine -- I have a Koop 192f on the way from the manufacturer and I'll document swapping that out.
Fuse box (with the cover off) mounted to the stainless plate using pop rivets:
Note the jumper on circuit 4 -- this is because I don't want the voltmeter / USB ports to be switchable (other than the ignition, which controls the whole fuse box via the ACC post [bottom right])
Cooling fan (radiator fan):
Connected to circuit 1 on the fuse box, switch positioned in the left side pilot controls switch panel. Luckily, this fan comes arranged as a puller, so it's just a matter of crimping on terminals and zip-tieing it in -- no flipping the fan over (not that it's a huge deal to do so).
Fan viewed from the outside:
Hourmeter:
Just popped off the panel, drilled a couple pilot holes, used a coping saw to cut it out (jigsaw was too violent for such a flimsy piece of plastic) and then used a rasp to refine the hole. Wired to an unused circuit that I confirmed was ignition-energized (the one labeled [somewhat ironically] "cooling fan" according to my translation app on my phone).
Traction tape:
I have a roll of this that I bought to do the same treatment to my tractor -- rolling it over the edge is key.
/ Diggit EM15 notes, mods, etc. #3
I like the Diggit product, I would like to try the Pilot Joysticks, but so used to leaning forward now.
I used a Tach/Hour Meter on my units. Not that RPM is that important but nice to know, easy to install.
/ Diggit EM15 notes, mods, etc. #4
2 thumbs up on the hour meter installation. I also like the electronic tach/hour meters. I have used them before on 2-stroke equipment. The mechanical hour meters do not seem to be waterproof, so be careful about washing.
Someone needs to ask Leking directly about the pilot valve RV spec and test port location.
/ Diggit EM15 notes, mods, etc. #6
I have a diggit as well and really appreciate all the info and stats you put one here along with the work you completed so far. I am trying to find a Hydraulic thumb that will fit our excavators. Have you looked into that and if so, do you have any leads? Thank you
/ Diggit EM15 notes, mods, etc. #7
If your machine has the pivot brackets on the dipper, they are designed for the mechanical thumb. Unfortunately, an hydraulic thumb will not work well with those pivots.
To do it properly, you need to remove those pivots and weld new ones on the dipper so the lower one is closer to the end of the dipper, and the upper one allows the hyd cylinder the proper stroke so that it retracts out of the way.
/ Diggit EM15 notes, mods, etc. #8
Thank you very much for the info. I appreciate it.
/ Diggit EM15 notes, mods, etc. #9
Here is the write-up I did, if you want some ideas.
/ Diggit EM15 notes, mods, etc. #10
I am looking at a Diggit EM15 with 20 hours and one bucket. Haven't seen the machine in person yet. I think I have this information correct. Machine is 43 inches wide, rather than 36 so it should be a little more stable. It has a bigger hyd pump than most 1 ton machines, so it should be a little more powerful. After market hyd thumb will not work without fabrication. How well does the manual thumb work? Are service manuals available? Will I find a rake? a ripper? a wider "toothless" bucket, about 24-30 inch? (to clean ditches) for it? Does $8000 sound about right?
/ Diggit EM15 notes, mods, etc. #11
You will find it cheaper at the auctions. It is wider and longer than the usual 1-ton-ish units. Fits all the same implements.
Last Saturday's local auction saw even some of the similar AGT H15 machines with pilot controls go for only $2800 final bid. About $3500 total cost.
/ Diggit EM15 notes, mods, etc. #12
Will the mechanical thumbs work if you are just picking up brush and poles? How about service manuals?
/ Diggit EM15 notes, mods, etc. #13
A mechanical thumb does work. I have installed and used the one that is sold with these units. Sure beats no thumb at all. When not it use, can remove it or pin it up to make digging easier.
Service manuals? Shirley, you jest.
/ Diggit EM15 notes, mods, etc. #14
Glad I found this thread, very good information on the EM15. I'm interested in hearing how owners of the EM15 find the foot pedals. Personally I have really struggled with the side ways foot pedals especially for the blade. I have a hard time controlling blade height when back blading. I find the foot pedal is not very granular and I was constantly having to stop to adjust the height. I opted to remove the foot pedal and turn it into a handle. I added a 3d printed grip and am much happier with this setup. Interested in hearing others experiences with the side ways foot pedals. Thanks.
/ Diggit EM15 notes, mods, etc. #15
Dimensions:
Track Length1250mm
Chassis width1100mm
Track width180mm
Other info:
Other specs/notes:
Add-on fuse box
Cooling fan
Thanks for this great info, especially the fuse box, that looks like a nice simple mod and easy to integrate.
/ Diggit EM15 notes, mods, etc. #16
Good modification.
I have operated the EM15, but not for very long. Like you, I did not like the foot control for the blade. I very much prefer my hand lever control on my Rhino, but I attributed some of that to being used to it.
/ Diggit EM15 notes, mods, etc. #17
Anyone know where I can get a new one? After 58 hours the red wirte just broke
/ Diggit EM15 notes, mods, etc. #18
Pretty much any 3-wire regulator/rectifier for 1-cylinder Honda-clone engines will work. Or you can just order the Briggs part.
I like to remove them from the engine and mount them to the firewall to reduce the vibration they experience. Also helps with heat dissipation.
/ Diggit EM15 notes, mods, etc. #19
/ Diggit EM15 notes, mods, etc. #20
View attachment 874216Connected to circuit 1 on the fuse box, switch positioned in the left side pilot controls switch panel. Luckily, this fan comes arranged as a puller, so it's just a matter of crimping on terminals and zip-tieing it in -- no flipping the fan over (not that it's a huge deal to do so).
Hourmeter:
View attachment 874219Just popped off the panel, drilled a couple pilot holes, used a coping saw to cut it out (jigsaw was too violent for such a flimsy piece of plastic) and then used a rasp to refine the hole. Wired to an unused circuit that I confirmed was ignition-energized (the one labeled [somewhat ironically] "cooling fan" according to my translation app on my phone).
Traction tape:
I had a bad starter. After repalcing it, nothing will operate. Charges the battery and still nothing. Pretty sure it is the wiring all going through the starter solenoid. Did you bypass the wires in the starter solenoid and hook them up to the fuse box? Trying to determine how to sole this issue so I can run my machine. Thank you
Here are some similar links:
