How big of a slab could I do by myself?
/ How big of a slab could I do by myself? #31
Do you have your heart set on concrete? If all you want is a fairly smooth stable floor, you could do what my FIL did.
He had a 20' x 30' steel building on a fairly remote section of the farm. It was accessible only by tractor and used to store implements. It had a level stone floor but he wanted something smoother. Costs estimates to do concrete were very high due to the location, so he used this product instead.
He brought in sand with the FEL, used it to choke off the stone and raked it level. He then brought in the pavers, laid them out and filled them with stone dust. He soaked the surface with water and it dried hard and fairly smooth.
That was 5 years ago and the surface has held up well under heavy equipment. It cost significantly less than concrete and he was able to do the job himself in 4 days.
I like the look of it but wouldn't consider it for a finished garage. For an out building though, IMO, it's an acceptable alternative to concrete.
Looks interesting.
I wonder how much they cost?
/ How big of a slab could I do by myself? #32
I like the idea of doing pavers, I could see that being easier.
But my biggest objection to the gravel floor that's in there now is that it's not good for working on the tractor. If I drop things they get lost, and crawling around under the tractor is uncomfortable. If I spill something I can't wipe it up. It doesn't seem that pavers would address any of those complaints.
Large cardboard boxes split open do wonders for laying on in stones or cold concrete. Seems with our kids moving so often between colleges, apartments, etc, we always have plenty folded flat in the garage rafters. I use them fairly often. If they get oil soaked, I throw them out. Otherwise, fold em up and back in the pile they go.
/ How big of a slab could I do by myself? #33
When my kids remodeled their home I asked them for all the old carpet. The floor installer cut it up into approx 4'x6' pieces and I have them stashed all over the place. They are quite handy to lay on snow or gravel etc. If they get dirty throw them away and if they get wet just dry them out. I regularly use them on my cement floor as they keep my clothes a lot cleaner and keep me warmer. The carpet also gives you a lot more room under a vehicle than a creeper does.
Edited to add: Oh ya and if you drop something it doesn't bounce or roll anywhere.
/ How big of a slab could I do by myself? #34
Concrete is the way to go for a garage-shop kinda floor. No worry about the jack settling into the gravel, no rocks in you butt crack, easier to find that little pin you drop, and when we look at what our OP is proposing, only about $500. Paver can look good, but they don't work well with a floor jack, cost as much (or more), and don't really offer an upside, other than maybe the ability to do a few and then do some more the next weekend.
If our OP wants to, he can divide his pour into as many as 3 or 4 pours, and not kill himself.
/ How big of a slab could I do by myself? #35
I saw the OP proposing about a 100+ bag (80lb) pour (mix it himself and he doesn't have a mixer), or perhaps the same amount ready mix.
My pricing at HD is ~$5.50 a bag plus tax.
Are prices in Coastal Rhode Island that much cheaper?
/ How big of a slab could I do by myself? #36
I stand corrected, 2.5 Cy= $621.60 at Home Depot, using 60# bags of Quikcrete brand. We might get cost down to $600 if we use 80s
/ How big of a slab could I do by myself? #37
OP is unique in that Rhode Island is so small, any company there is close.
Concrete Quick LLC, advertises 0.5 to 4 cy delivery, no load minium. It's atleast worth calling to get a price
I would ask for price of 2.5 CY, 3000 PSI, 5" slump, with delivery. Than you have a base line price to compare pallet mix, and the work/time involved
/ How big of a slab could I do by myself? #38
I've done quite a bit of concrete work by myself. I'm not the best at finishing it, but it's one of those things that I can live with "good enough" it's smooth enough to sweep, but nowhere near as nice as what the pros can do.
For bigger jobs, I always hire a crew. The biggest that I've done by myself in one day was 12x12 with footings and a bit of a slop that made part of it thicker then other parts. I had three pallets, and used around 2 1/2 of them. I only buy 60 pound sacks. They get really heavy once you get started.
The wider the pad, the harder it will be to get it flat and smooth. For your pad, I would do it in thirds. Nothing is easier then walkways.
Set your mixer right next to the forms, and have your pallet of concrete as close to the mixer as you can get it. Mix, dump, add concrete and water to the mixer, pull the concrete to the farthest part of the pad, and repeat. Once you get enough concrete to screed it, start working on that every time you pull concrete there.
Do not try to get it all poured and then work it. Work on leveling it off with your screed board as soon as you have enough material to do so!!!
This is an easy DIY project if you are in decent shape, and you understand that once you start, you cannot stop until it's done. The last pad that I did was 10x30. I did it in three sections that where 10x10. That's about the biggest I like to go by myself. Each section took about half a day, and I did it in Summer, so finishing before it got too hot out was also a factor.
So the slab is 12x17, the door is in the 12' end. So would you recommend three pours of 4x17 or three pours of 12x 5'+?
If it doesn't matter, it seems to me the 4x17 would be easier, I can roll the mixer between them the whole way. Do the two sides and let them harden and then roll the mixer in on one of the sides to do the middle. It also would mean I never have to drive over the joints.
/ How big of a slab could I do by myself? #40
I picture three pours the 12’x5+. That might also eliminate need more joint or maybe there needs to be one joint in the middle of the 12’.
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC 1500...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2014 FREIGHTLINER CASCADIA 125 6X2 MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
