Echo CS-356 leaks bar oil
/ Echo CS-356 leaks bar oil #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
Echo CS-356 leaks bar oil when it sits, anybody know why and how to fix it?
Thank you in advance
/ Echo CS-356 leaks bar oil #2
I have I think about 5 chainsaws now that I've accumulated through the years. Every one of them leaks bar oil...just the way they are designed. I've learned to either drain the oil out of the saw or keep it in a leak-proof container.
I thought I read about a fix once but I can't remember exactly what it was. Something in the oiler delivery? I'm not real fluent in saw mechanics.
/ Echo CS-356 leaks bar oil #4
I have a runny saw as well. Added a bottle of STP to the gallon of chainsaw oil and that slowed it down
/ Echo CS-356 leaks bar oil #5
Scoot, they all 'leak' bar oil no matter what brand they are and why I store my saws on an absorbent cloth always.
They inherently 'weep' bar oil simply because temperature changes will cause the bar oil tank to pressurize to a small extent and that pushes the bar oil out and through the bar oil pump and it drips so I counter that with them sitting on something absorbent. I use one of my wife's old whipped out bath towels and when it gets 'soaked', it goes in the burn pile.
Don't matter what make the saw is, unless the bar oil tank is completely empty, they will all pee to some extent.
My 075 and 090 Stihl shelf queens don't leak at all simply because both are totally devoid of both pre mix and bar oil.
Well, shoot. Good to know
I'll continue storing on many layers of heavy cardboard. Tossing out the top layer as needed.
Thank you
/ Echo CS-356 leaks bar oil #7
Thank you
You might as well just pour it out on the ground before you put the saw away. I'm cheap--I pour the oil back into a container. Mine is like a squeeze ketchup bottle with a nozzle. It goes where my saws go.
/ Echo CS-356 leaks bar oil #8
I just bought a 194T that slobbered oil.
I took it back and got a new one, it stays dry.
My 261C seeps a bit. My 500i stays dry.
/ Echo CS-356 leaks bar oil #9
My Husqvarna 545 Mark II leaks a fair amount of oil. More than I would expect for such saw but it is what it is.
My 25+ year old Shindaiwa didn't leak much at all until I sent it for repairs and receive a box with it all taken apart, piece by piece. Then since I could no longer get the gasket for the two half cases, it leaks the bar oil from there. I need to fix that but I keep putting it away since I mainly use the Husqvarna.
/ Echo CS-356 leaks bar oil #10
I think it’s crazy that a saw leaks oil continuously after use. I could see a little right after shut down, but this one I just took back leaked like a 1/4 cup while sitting. I’m not paying for that.
I tried a DeWalt 60V battery saw and it leaked oil from day one badly. Glad to see that thing gone.
/ Echo CS-356 leaks bar oil #11
I have one of those as well, restaurant style squeeze bottle with a snout on it/ Makes for much easier filling the oil tank and less mess too.
They all leak a bit, like I said do to temp swings and expansion of the bar oil inside and unlike the carbs that are impulse fed, there isn't much between the oil tank and the oil tank and the oil pump except some hose and the pumps aren't positive displacement so the oil can dribble out.
/ Echo CS-356 leaks bar oil #12
My CS-400 stays dry. It sits in a case, but it's always dry.
/ Echo CS-356 leaks bar oil #13
Down here in hot as Hades Florida, everything leaks, chainsaws, grease guns etc. I lay everything in a large size disposable aluminum cooking tray.
/ Echo CS-356 leaks bar oil #14
I store my leaky saws (which is all of them) on adult diapers.
/ Echo CS-356 leaks bar oil #16
My 40V 14 inch Ryobi chain saw doesn't leak at all.
I was surprise at this.
/ Echo CS-356 leaks bar oil #19
I think it may depend some on the bar oil as well.
My old Stihl 031AV, when my mom had it, it leaked like crazy in its case... but then she and later her handymen just ran 30 weight oil as bar oil. Since I've had it, I put a slightly more proper bar & chain oil in it (TSC's store brand stuff) and there's barely any leaking now (and surprise, the chains don't go dull as quickly lol)
/ Echo CS-356 leaks bar oil #20
The surefire way to prevent oil leakage is to drain the oil after use. Every saw I've owned leaked bar oil if it was left setting with some in the tank.
2019 Chevrolet Silverado 2500 Pickup Truck, VIN # 1GC1KREG4KF129755 (A65563)
2019 Chevrolet...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
New/Unused Electric Winch (A65583)
New/Unused...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A59914)
2016 FORD TRANSIT...
