Echo CS-356 leaks bar oil
   / Echo CS-356 leaks bar oil #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
Echo CS-356 leaks bar oil when it sits, anybody know why and how to fix it?
Thank you in advance
   / Echo CS-356 leaks bar oil #2
I have I think about 5 chainsaws now that I've accumulated through the years. Every one of them leaks bar oil...just the way they are designed. I've learned to either drain the oil out of the saw or keep it in a leak-proof container.
I thought I read about a fix once but I can't remember exactly what it was. Something in the oiler delivery? I'm not real fluent in saw mechanics.
   / Echo CS-356 leaks bar oil #4
I have a runny saw as well. Added a bottle of STP to the gallon of chainsaw oil and that slowed it down
   / Echo CS-356 leaks bar oil #5
Scoot, they all 'leak' bar oil no matter what brand they are and why I store my saws on an absorbent cloth always.
They inherently 'weep' bar oil simply because temperature changes will cause the bar oil tank to pressurize to a small extent and that pushes the bar oil out and through the bar oil pump and it drips so I counter that with them sitting on something absorbent. I use one of my wife's old whipped out bath towels and when it gets 'soaked', it goes in the burn pile.
Don't matter what make the saw is, unless the bar oil tank is completely empty, they will all pee to some extent.
My 075 and 090 Stihl shelf queens don't leak at all simply because both are totally devoid of both pre mix and bar oil.
Well, shoot. Good to know
I'll continue storing on many layers of heavy cardboard. Tossing out the top layer as needed.
Thank you
   / Echo CS-356 leaks bar oil #7
Thank you
You might as well just pour it out on the ground before you put the saw away. I'm cheap--I pour the oil back into a container. Mine is like a squeeze ketchup bottle with a nozzle. It goes where my saws go.
   / Echo CS-356 leaks bar oil #8
I just bought a 194T that slobbered oil.
I took it back and got a new one, it stays dry.
My 261C seeps a bit. My 500i stays dry.
   / Echo CS-356 leaks bar oil #9
My Husqvarna 545 Mark II leaks a fair amount of oil. More than I would expect for such saw but it is what it is.
My 25+ year old Shindaiwa didn't leak much at all until I sent it for repairs and receive a box with it all taken apart, piece by piece. Then since I could no longer get the gasket for the two half cases, it leaks the bar oil from there. I need to fix that but I keep putting it away since I mainly use the Husqvarna.
   / Echo CS-356 leaks bar oil #10
I think it’s crazy that a saw leaks oil continuously after use. I could see a little right after shut down, but this one I just took back leaked like a 1/4 cup while sitting. I’m not paying for that.
I tried a DeWalt 60V battery saw and it leaked oil from day one badly. Glad to see that thing gone.
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2011 Ford F-150 Platinum 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2014 Dodge Grand Caravan Van (A50324)
2014 Dodge Grand...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
