Battery powered chainsaw
/ Battery powered chainsaw #1,005
I like having choice.
However am not too fond of having a multitude of incompatible batteries. So I keep things down to EGo 56V and DeWalt 20V.
Same here... except Stihl AP series.
/ Battery powered chainsaw #1,007
The sure way to store a 2-stroke is to drain the gas tank, put a few ounces of 2-stroke oil in the tank, pump the primer to fill the carburetor with oil.
When you need it again drain the oil from the tank, fill with premix, prime to get the oil out of the carburetor. Your first tank has a little more oil than normal but it will store this way for years without gumming the carburetor or the diaphragms getting stiff.
This is interesting. I never thought of oil for a preservative in the carb. Frankly I don't think the kind of oil is that big of deal but because I love it, it would probably be marvel MO
/ Battery powered chainsaw #1,008
The idea is to use 2-stroke oil which is the oil the carburetor is used to.
/ Battery powered chainsaw #1,009
I Buy Stihl MSA 160 Chainsaw with 14 inch(35.56 cm) from online one year ago, i still use it without any major problems, This has quick chain tensioning system (B) makes tensioning
/ Battery powered chainsaw #1,010
I Buy Stihl MSA 160 Chainsaw with 14 inch(35.56 cm) from online one year ago, i still use it without any major problems, This has quick chain tensioning system (B) makes tensioning the
SurajitN,​
Welcome to TBN Glad to hear that your battery powered saw is working for you.
Richard
/ Battery powered chainsaw #1,012
Used my battery powered chainsaw last week and today to cut firewood . Probably have about a cord and a half cut so far. I used my Greenworks 60 volt with a 20 inch bar to cut the larger trees down and cut them into chunks and it worked really well and had plenty of power. The largest tree was about 18 inch and it cut it up like a knife through butter. Really impressed with it and the battery lasted longer than I did.
/ Battery powered chainsaw #1,013
Stihl now offers battery powered blower/vac but only AK battery and not AP battery.
There are times a leaf vac would be helpful but not going to start a new battery series or buy gas to sit for 11 months
/ Battery powered chainsaw #1,014
I have to say that my battery leaf blower is my most used tool during the summer.
/ Battery powered chainsaw #1,015
Had my Kobalt battery powered chainsaw for I think 3 or 4 years now. It has even surprised me the jobs it has done. I absolutely love it. Ready to go in any temperatures, no pulling on a starter rope. Safer because it's not running until you're cutting. Lighter. No nasty fuel to carry around. And if the chain is sharp it'll go through an oak tree like a hot knife through butter.
/ Battery powered chainsaw #1,016
I never had one but when I went to the AP Stihl line the shop said it’s popular and not that much to add as already have charger and batteries.
I probably use it the most of all the AP tools.
/ Battery powered chainsaw #1,017
The adjectives you use to describe the support structure tells me a battery powered tool is right for you.
Wind up , if it were available might be something to consider. ;-)
/ Battery powered chainsaw #1,018
I have a 24V 12" Kolbalt and amazed at what it will do.
I have taken down several good size cedar trees last one 18" where I cut it.
Batteries seem to just keep on going.
/ Battery powered chainsaw #1,019
Very impressed with my 18" EGo. And since then they have introduced even more powerful saws.
The original 14"/16" EGo (same saw, different bar) were not impressive. Could chew something down but nothing like the 18".
/ Battery powered chainsaw #1,020
I’m always using it to clean off the patios, porches, and sidewalks. It’s also nice to blow of the tractor and mowers after cutting.
2027 . . (A67714)
2027 . . (A67714)
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A67148)
2017 FREIGHTLINER...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2016 CATERPILLAR 289D SKID STEER (A65056)
2016 CATERPILLAR...
RIDGID AIR COMPRESSOR (A68842)
RIDGID AIR...
2012 MACK CHU613 (A67714)
2012 MACK CHU613...
