4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,124
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
If you have a water recirculating pump like I do, tankless don’t work without some juryrigging a small standby tank or some such nonesence. I have twin 40 gal direct vents that are 10 years old, have replaced anode 2 times. Have another set sitting in WH room. I’m thinking about getting another pair of them and storing them because I don’t know what nanny state will do in near future with propane water heaters.i don’t want heat pump or elect units. Ive been called out to too many heat pump water heater failures over the years. And while elect units are ok, my standby isn’t large enough to add two elect water heaters to it.
I’ve installed tankless gas water heaters on new construction jobs that have factory supplied recirculating pumps. I like electric water heaters for the main reason they don’t require ugly vent pipes. They’re cheaper as well. The downside is they’re not easy to operate in a power outage.
