Importing and modifying a new mini excavator from China
/ Importing and modifying a new mini excavator from China #1,041
The H15 may be considered 1.5 ton and may have Kubota engine. the h12 and qh12 are very similar. the L12 is better IMO. I didnt see the h15 on the website but I will look again.
/ Importing and modifying a new mini excavator from China #1,042
A buyer wanting more than one unit will be able to buy all that he wins at the same price. So, if his winning high bid is say, $4000, and he is willing to take say, 10 of them, he will get that price for each, and have priority over any other bidder at $4000 who wants fewer units. Live auctioneers have explained it that way when last I attended a live auction.
Secret reserve bids are also used at some auctions. I hate that.
What was your winning bid for your new Tria, and when/where?
The auction I referred to does not do that. Its 1 item at a time even if there are 100 same things. The auction is live online and if someone placed a high bid early, that is tossed right in once another bidder gets to that amount. They actually start the bidding 2 weeks before the live auction starts. You can see the bidder number when they bid each time. I get it on the wanting them all deal, but that's not what happened. Winning bid on the Tria was 3800 in Sacramento Cali. I got the articulating bucket at a different auction a couple weeks ago for 280. 3600-4200 on the mini's is the norm there. Sometimes lower but rare. 600-900 is normal on the accessory lots that include 2 buckets, ripper, rake, mech thumb and auger set.
/ Importing and modifying a new mini excavator from China #1,043
/ Importing and modifying a new mini excavator from China #1,044
Welcome to the forum Schmecky! What size machine are you considering?
I just got the Tria 1 ton. It's the same as the agt, mms, agro...etc. Just need to fix the road going into my new property and do some culverts. Lots of runoff...lots. Is there a dedicated forum for these little buggers?
/ Importing and modifying a new mini excavator from China #1,045
Old rusty - I can see the difference now and there are 4 or 5 L12's in this auction.
- :12 have hyd lines in boom and appear to be "cleaner" in execution
- The QH and H12 seem to be a different mfg?
Then I looked at AGT web site and there seems to be a new model out DMC-12C with new controls 2024 Upgraded 1 Ton Mini Excavator DM-12C W/ SIDE SWING BOOM | AGT Industrial
All the ones you mentioned are AGT, I think they are just different stages of improvement. the DY14 looks somewhat better than the L12 and is 5000 dollars off now, 6999. It seems they are constantly upgrading and improving.
/ Importing and modifying a new mini excavator from China #1,046
Yah, FB, there are several.
thousands of posts discussing agt differences and fans and auction prices etc etc etc
/ Importing and modifying a new mini excavator from China #1,047
This has not been confirmed, and I may be wrong, but I would want to know this if I was looking for a cheap baby-X again. I have noticed there seems to be a big difference in build quality with the AGT machines. Some people have had multiple issues, [ loose bolts. defective hydraulic lines, house falling off frame etc], and my L12 has yet to show me a single loose bolt.. Not saying mine is perfect but its better than some.. My serial # starts : L1223xxxxxxxxxx... I have noticed the same model with a suspicious looking serial# starting 422xxxxxxx. IMO, there may be knockoffs of the baby diggers. That would explain a lot. the pic is of a serial# I know 20231125_164752.jpg to be legitimate. I would only buy from an authorized dealer that stocks parts.402861800_10159179759682691_2775186044493143803_n.jpg The 2nd serial# is off the Briggs engine. The plate is different also. Both are from a 2023 AGT L 12.
/ Importing and modifying a new mini excavator from China #1,048
This has not been confirmed, and I may be wrong, but I would want to know this if I was looking for a cheap baby-X again. I have noticed there seems to be a big difference in build quality with the AGT machines. Some people have had multiple issues, [ loose bolts. defective hydraulic lines, house falling off frame etc], and my L12 has yet to show me a single loose bolt.. Not saying mine is perfect but its better than some.. My serial # starts : L1223xxxxxxxxxx... I have noticed the same model with a suspicious looking serial# starting 422xxxxxxx. IMO, there may be knockoffs of the baby diggers. That would explain a lot. the pic is of a serial# I knowView attachment 841321 to be legitimate. I would only buy from an authorized dealer that stocks parts.View attachment 841327 The 2nd serial# is off the Briggs engine. The plate is different also. Both are from a 2023 AGT L 12.
I had a few loose bolts, the throttle lever was nearly falling off, the choke cable was a mess at the motor, and it took some time to find the fuel shutoff on the B&S, and I ended up pulling the floorboard to put protection on all the hoses that would rub themselves raw against the sharp flat cut iron at just about every point. I also noticed right off that the plugs they put on the aux hose ends were backwards. They had the o ring side outside the cap and the beveled side on the inside. Strange both those hose ends didn't spray when I operated the aux stick. The hour meter was disconnected. The only grease I found used was on the turret. Not a spec on any other point. Half the grease fittings were finger tight, the other half backed out hard. The tracks were somewhat loose, the hyd oil looked like some psycodelic cool aid. But the manual I found said to change the hyd oil immediately. Most the manuals are generic. I got mine by emailing the co that makes the Vicsec (I have the Tria) and when the manual was emailed, it came from MMS! So, I assume nearly all these different makes are made by 1 or 2 companies and they all copy one another one way or another. Groundhog claims all these companies copied his machines. I would just like to know how to up the hyd flow, and how to adjust that flow to the track motors. No one seems to know, or they won't disclose. I plan on tearing one of the motors down to see. I have never seen any hyd operated anything that didn't have some adjustment for flow...especially motors. 1 seems to turn at a slower rate than the other. Sorry for the long post, its the way I am ;)
There is no adjustable flow. That is fixed by the gear pump. There IS an adjustable system relief valve, and I give that 95% chance it is set too low.
One wheel motor will run slower than the other when operated simultaneously, due to the system having one pump, and a single main open-center stack valve.
Yeah, change the hyd oil right away.
/ Importing and modifying a new mini excavator from China #1,050
Thats a nice-looking machine, great price. the only things I don't like is the hydraulic lines exposed along the boom and the lack of accessibility to the engine area. Looks like access is under the seat or remove a panel. Probably small things to most people.
Well, it's time for an engine oil change, and Rhinoceros was nice enough to provide this drain hole in the base of the house. Looks like I have rats. Nuts. :-(
I think they get in around the hyd hoses entering the house from the boom. It is a good time to do some more inspection of hoses for rub wear, and protection.
Plus, I need to get underneath to replace a leaky blade hose.
/ Importing and modifying a new mini excavator from China #1,052
Interesting,, My L12 has what appears to be the exact same drain hole. The drain for the engine oil misses the cutout by a few inches so I may install a flexible extension hose. I had oil running everywhere when I changed it.
You can try my tipping trick. I tip the whole machine on a slope, then open the drain plug, insert a hose, then tilt it back up to drain.
I fantasized about installing a drain valve, like you see on some riding mowers. But I just could not get it to fit. So my machine has had some spills inside the house. At least that makes it less attractive to rats.....
/ Importing and modifying a new mini excavator from China #1,054
I remember seeing your method in pics. I think I have a place with a similar slope that maybe ideal, thanks for the reminder.!
/ Importing and modifying a new mini excavator from China #1,055
Poor little rats..... They only want to help you with some mods on your machine. :oops: :confused: They are real good at cutting wire and hoses.:mad:
I try to rat-proof my poor machines that don't sleep indoors. I usually use 1/4" steel screen, but I do not see how to safely screen off the open place in front that hoses go thru.
I once actually had a rat chew into the transparent plastic fuel filter on my UTV.
/ Importing and modifying a new mini excavator from China #1,057
Any machine I leave outside will be gnawed on by squirrels or chipmunks. the odd thing is, they always go for a fuel line or a gas cap.. I am convinced they like the smell of gasoline.
They even chewed through a neighbors fuel line on his Tacoma,$1400 in repairs.
/ Importing and modifying a new mini excavator from China #1,058
Indoors or outdoors it doesn't matter the damned rodents will get to everything in one way or another. Either chewing defecating or nesting.
/ Importing and modifying a new mini excavator from China #1,059
And where is that relief valve adjustment? The only thing I have found was under the right stick valve body (boom up/down, bucket in/out) but left it alone until I get more into it. No other visible adjustment for anything else other than the tracks. Also, this system here does not send me notices when someone posts or replies? My settings say to do it, but...............
/ Importing and modifying a new mini excavator from China #1,060
For me, the worst thing is when they get in a camper. I cant stand the smell. I have given away 2 campers in my lifetime because a mouse got in. You hear lots of proven ways to keep rodents away. Irish spring was one thing I tried. Didnt work, a mouse ate half the bar and pooped all over the other half.. Rodents get NO mercy from me.. :mad:
2023 VOLVO VNL760 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2023 VOLVO VNL760...
2019 VOLVO SD115B SMOOTH DRUM ROLLER (A62129)
2019 VOLVO SD115B...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2000 Dodge Ram 1500 4x4 Ext. Cab Pickup Truck (A61568)
2000 Dodge Ram...
2023 New Holland C327 Two Speed Compact Track Loader Skid Steer (A61567)
2023 New Holland...
