SCORE - Quick Hitch H-F
/ SCORE - Quick Hitch H-F #41
What CAD format? DXF or STEP214 ?
Pretty sure it's a DXF, I'll dig up the file.
Yep, I attached the file.
  • MMtillerBracket (4) - Shortcut.zip
/ SCORE - Quick Hitch H-F #42
Would that need a longer driveshaft?
For tilling only a couple of times a year, it's not that much trouble to take off the QH to install the tiller in place of it. But making the tiller QH-compatible does sound attractive!
/ SCORE - Quick Hitch H-F #43
I was able to use the one it came with that was never fitted to my tractor.
/ SCORE - Quick Hitch H-F #44
My old style Overrun had a pin you had to line up and punch out. PITA! If I had to ever remove it anytime now I'd replace it. The RS1400 came from Fredricks and it was the last one they had. Hard to come bye back then. I was told By my local dealer I better go get it. I had Drive shaft problems on it also. Had to shorten the Org. they Gave me. Didn't take a day or so for them to send me another and told me to keep the old one. Another Member may still have the old one. I put a major Ghetto rig on it. They may still be using it. Think he cleaned it up since It did have a bearing problem also? Welding was Ugly no doubt but Hey!! it worked. ;)
/ SCORE - Quick Hitch H-F #45
I spent part of Sunday getting the QH and box blade adjusted. All my dragging attachments have bushings installed, so I had to buy another QH.
Wife hadn’t used her account recently, so HF sent her a 30% off coupon. $113 out the door.
Kinda like the extra weight on the back with such a heavy loader bucket. Pulled the 5 ft box blade around pretty good on a hard pan field. Very rarely use the box blade on the Mahindra.
Did you need to use a farm jack or reverse pipe clamp to widen the opening by 1/4 to 3/8 inch? Mine was a tad under size like others had mentioned. It was a quick fix of 5mins and all was good.
My BB can't use the QH due to the top-link hook interface on the BB. I rarely use it now as the straight blade can do all sorts of things.
Oh, you need the Harbor Freight rear work light. Your YM186D has the rear fender mount for it. It's PERFECT to mount there !
Go to the towing attachments and the LED lights. right in the transition of those two sections you'll see the work light there for only $9.90. :)
/ SCORE - Quick Hitch H-F #48
@bmaverick
QH fit just fine. Wish I bought a smaller top link though. May trade them on tractors.
If you look close I only have 1 bolt in the top hook. Plan on puttting a pin to support behind. I use pins in my other set up, to make it easier to change attachments on the fly.
Lights are something to be addressed. Currently nothing. I have some LED lights on an off road Vehicle that are close to the original headlight size. Good idea with back up light
This tractor was restorable, but time frame i need it is in 6 months. I dont think I could track parts down in that framework. Got a lot of glaring issues solved in 2 months
Need something usable, got 6 months to make it that
/ SCORE - Quick Hitch H-F #49
I solved that problem with:
1) The Speeco replacement hook with its holes offset to get the hook away from its mount.
2) Slide-in pins with clips, to make adjusting the hook height simple.
and 3) Not shown. Its simple to mount the hook upside down over the implement's pin if the hook can't slip under that pin.
20190125_162235rqh-speecohook4-jpg.603428
Here's an old photo showing the adjustable pins and their clips.
This also shows the adapters I made so the towbar can't roll over. The tabs are welded to sleeves, then those assemblies are bolted, removable, to the towbar's pins. With these, the trailer ball remains on top, simplifying hitching on my watering trailer. This doesn't look strong but in several years use the tabs haven't bent.
kimg1766rqh-toplinkpins-jpg.475243
And as couple more photos contrasting how the Speeco hook extends farther out.
/ SCORE - Quick Hitch H-F #50
Since this is a QH thread I'll include another QH mod photo I've posted before. Maybe some haven't seen it.
My implements when they are idle, are parked where there can be tall weeds. Dropping a Clevis pin or small clip in dense weeds while hooking up, was a PIA.
I cut down a HF magnetic tool bar and welded it to the top of the QH. Nothing has fallen since. Recommended!
20190721_153609rmagnetbarweldedtoqhitch-jpg.613928
And finally, the photo shows part of the forks assembly I welded up from scraps on hand. Angle iron in the QH's lower hooks avoided the need to buy real 3-point pins.
/ SCORE - Quick Hitch H-F #51
I park my implements next to the barn where I had dug out because water flowed in the barn clean outs. A couple of bags of crusher stone, sitting on pallets, an occasional spray of Glyphosate, It’s the perfect place.
Oh no, toxic tractor implements. :D
Hope you are not looking for a big million dollar settlement. ;)
When the weather isn't so cold out, the next project for the quick-hitch will be this. All I need is a 30-gallon plastic barrel. Those are $8 on CL out here. (y)
The 30-gallon fits like a glove for the quick hitch. This should be about 240-lbs of rear ballast.
Reading the Reddit post, the 30-gallon is not filled to the top.
Mark the inside of the 30-gallon barrel to 26-inches MAX.
Time to cure is 7 - 10-days above 70F.
I just have to find a good 1-inch solid rod.
/ SCORE - Quick Hitch H-F #55
Check neighborhood sales or marketplace for old weight lifter bars.
Some one made it as a lawn roller. Just keep the outer plastic barrel over the concrete.
/ SCORE - Quick Hitch H-F #58
Have you considered a design that would allow it to roll, if wanted? E.g. 1.25 pipe as a sleeve, and a 1" axle?
All the best,
Peter
/ SCORE - Quick Hitch H-F #59
American threaded Pin on the L.and the Org. Yanmar R.. The small Metric Threads wear out. Standard threads screw right in and I Locked with a Locking Washer and Nut so it doesn't come loose anymore. Actually fell out before mowing so I had to lock it up!
You can SCORE a huge deal right now, this price has not been seen since 2020 !!! Even better than the last Black Friday sale!
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
2016 PETERBILT 365 DAYCAB (A63569)
2016 PETERBILT 365...
2011 WESTERN STAR  4900 SB (A63569)
2011 WESTERN STAR...
