Echo 590 or the X Series?
/ Echo 590 or the X Series? #122
Ever see the bow type bars that guys used to run down south? They'd be useless for a lot of what I do, but I believe the marketing behind them was almost entirely aimed at your situation, cutting logs on the ground from a standing position.
Talk about a large kickback zone! Of course, any kickback force would be far less violet, due to reduced angular velocity around a larger radius. More of a "pushback" feel than the usual snap-action behavior you get off the upper quadrant of a small bar tip.
Back in the mid 1960's we had a McCulloch with a bow on it. Everyone says they are dangerous but we lived without injury and everyone I knew used one. Some had bar saws too but bows were very popular.
/ Echo 590 or the X Series? #123
The Husqvarna XP saws are in a whole different league than most saws. I've had my 550XP (50cc saw) for about 5 years now and it's been a perfect saw for my firewood needs. I modified the muffler, so it has a little more power than normal. I run a 20" bar with a .325, .050 chain and it pulls really well when buried in a log. I wouldn't normally run a .325 chain, but it seems to be well matched to the 50cc saw. It's a very well thought out saw, with flip up caps, fuel level window, felling sight indicator, retained nuts, easy open top cover, good bucking dogs etc.
A step up to a 562XP would probably suit anyone's needs. When I used to do forestry work in the 80's, all our saws were Husky 266XP's and they were beasts, running 20" bars. 60cc saws are a real sweet spot for power to weight.
The only issue with the Husky brand, is you don't have a prevalence of servicing dealers like Stihl does. It seems like Stihls are sold everywhere, at every tractor dealership, ag supply store etc. But I haven't had good luck with any of the newer Stihl products. They seem to be extremely finicky to start and stay in tune. I do have a 25 yo old Stihl 011 that starts on 3 pulls, even when it sits for years. It has some incredible compression for a little saw. Great for cutting mesquite.
Husky kind of sold out to the big box stores. You see the Husky homeowner/Rancher saws being sold at Tractor supply, Lowes etc, but those saws are not at the same level as the XP line. If you follow any arborist or logger forums, Husky XP's are one of the industry favorites. The good news is I've never needed to have my XP saw serviced.
/ Echo 590 or the X Series? #124
I saw this photo on another site. Cool use of cull trees for a firewood shed.
Eddie, I found your next project. Do you have any of these trees at your Tyler place?
/ Echo 590 or the X Series? #125
I love the XP line as well and have both the 562XP and the 550XP. But Huskys don't start near as easily as the Stihl pro series of saws do. My Stihl 261CM starts way easier than either of my Huskys do and the huskys are newer than the Stihl. All of these saws got the muffler modded the day I brought them home and all are screamers. In a 50CC saw, the Stihl 261 is by far my favorite of them all but that 550 aint no slouch!
/ Echo 590 or the X Series? #126
Pretty cool, but I wouldn’t trust that in a strong wind storm.
/ Echo 590 or the X Series? #127
I have a brand new Stihl MS311 out in my shop that I've only used 1x. My brother-in-law was visiting, and he found it laying in the middle of the road. It must have fallen off a service truck, no wear on the bar, no wood chips under the cover etc. Brand new, with just a scuff where it hit the pavement. I used it once when I had a spark plug issue with my 550XP.
I tried cutting one felled tree and couldn't keep the MS311 running, the fuel was boiling in the tank that it kept stalling out the saw. I mean seriously boiling, you could hear it and see it when you opened the tank. It was TX in the summer, but I've never had a saw do that before. Any idea what would cause that or how I fix it?
After I replaced my 550XP sparkplug, I've been back using that saw because the weight better suits me.
/ Echo 590 or the X Series? #128
Wow what a find! That's a homeowner line of saw from Stihl but I'd certainly take a free one! That's an odd issue, maybe vent related?
/ Echo 590 or the X Series? #129
Maybe it didn’t “fall“ off the truck, but was “thrown” off the truck. ;)
I remember feeling like I won the lottery about 20 years ago when I found an expensive Echo forrestry weed whacker along a country road. Brought it home and it would not start. Tinkered with it and realized it had very low compression. Emptied the fuel tank and saw someone ran regular fuel (not mix) in it and ruined the piston/cylinder.
They just threw it off the truck because it was junk
/ Echo 590 or the X Series? #130
Where did I get that from? Many years of running both hand saws as well as mechanical cutting systems from 3/4” to 404” and doing testing for chain/bar manufactures. When speaking to their engineers they say exactly that only grease when first installing by greasing well in service you are more likely to grit up the bearing. Most or the mechanical systems have gotten rid of the grease holes in the tips for that exact reason.
Interesting. Never would have thought that to be true but are the bars with no grease holes sealed so that no dirt can get in?
/ Echo 590 or the X Series? #131
They still get stuck and jammed full of crap.
Have them come in and try to get the crap out of the tips for locals. I also soak them during that time to help during getting unstuck. Most of them I have been able to save for folks.
/ Echo 590 or the X Series? #132
Especially those who noodle big rounds. Those long-grain shavings can sometimes wrap around the sprocket bearing, and really jam up the works. Without a grease hole, you have no way to hydraulically eject them. That's how my one and only nose sprocket failure occurred, many years ago.
I'm down to one greaseless bar now, a 36" Stihl Rollomatic ES (now called "E Super") that only really gets used for felling real big trees. I don't put enough hours on that bar to bother replacing it, I suspect the nose grease or bearing seals will dry out and fail from age, before I ever wear the thing out.
/ Echo 590 or the X Series? #133
No it’s flushed with bar oil in harvester application a bar tip on a dangle head is pretty exposed compared to even a chainsaw. Well cutting a tree you have a little bit of lift and a bit of push out in the direction of the cut so there’s always a chance of the bar being pinched or the tip to be sat on.
I put the grease in the hole at the end of the bar before using it over the weekend. I did it on both sides, and I put a little in at a time, then rotated the chain and did it again and again. I don't know if I got too much in there, or if there is such a thing as too much.
I didn't notice any difference using the chainsaw. But it's simple and easy enough to do that I will continue to do it.
I also bought another gallon of the Husqvarna premixed gallon cans of gasoline. I'm still on the first can, and I wanted to have another can here so I don't run out. It might be my imagination, but I think it's part of why I like this chainsaw so much better then my Husqvarna and Stihl chainsaws. It's also lighter, starts easier and it has more power.
/ Echo 590 or the X Series? #136
You can't do too much, it just pushes out between the cheeks of the sprocket tip. It can be messy if you overload it, but that's it, no damage.
You won't notice any difference in the saw, unless it had been bound up with debris before and greasing managed to eject that, just like your truck doesn't drive any different after changing the motor oil.
/ Echo 590 or the X Series? #137
It's funny: I've heard reports form some users that their saw runs better on the canned stuff, while others say it doesn't run worth a damn, and switch back to gas from their local station. I'm not sure if it's just a matter of the saw needing to be retuned for the different fuel or something else. The effect described is so dramatic that I would not have thought the difference between premium ethanol-free gas and canned gas would throw off the tuning that much.
I've also heard some complaints about quality problems with TruFuel. I have no idea if they are correct or not, but the reports have come from more than one source. (I don't use canned gas, other than the couple of cans I bought with my saw to get the warranty extension from Husqvarna.)
/ Echo 590 or the X Series? #138
The octane rating of gasoline drops with time, esp. once the seal on a canned gas container is broken, or in a regular gas can. There's no reason that a saw would not run as well or better on canned gas, so those observing otherwise might just be trying to use fuel that's been opened too long.
/ Echo 590 or the X Series? #139
As long as the octane is above the minimum needed to prevent auto-ignition/knock additional octane does not improve performance. One of those reporting an issue was my neighbor. He normally runs non-ethanol pump gas. He had an unopened new can of 50:1 fuel that came with some other implement he purchased. Put it in his chainsaw, it ran like crap. Went in to town and bought fresh, ethanol free pump gas, mixed up a gallon at 50:1, and it ran fine. I have no idea why it happened, but he is not the only one reporting this problem. I did not catch what brand of canned gas he was using. The problem reports on the Trufuel were from other sources.
/ Echo 590 or the X Series? #140
That's correct. But note that some chainsaws spec 91 octane minimum, and it's realistic to assume that canned gas might drop below 91 if left open for some period of time.
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
1996 Ford F-350 Pickup Truck (A64194)
1996 Ford F-350...
2019 Kawasaki Mule 4010 EPS (A62613)
2019 Kawasaki Mule...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2007 Freightliner Columbia 120 Single Axle Day Cab (A62613)
2007 Freightliner...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
