Please explain this difference between diesel and gasoline engines
/ Please explain this difference between diesel and gasoline engines #41
CalG Gasoline engines don't need spark ignition to burn,
Then why do gas engines have spark plugs???????????
willy
Gasoline engines will Knock , I.E. auto ignition due to Hot spots or excessive compression.
Some folks call it dieseling. As I wrote, the engines will not last long under these conditions.
The spark plug is a great way to get the ignition off to a good start.
/ Please explain this difference between diesel and gasoline engines #42
Speaking of Diesel engines:
Did you know “Diesel” should always be spelled with a capital “D”?
The inventor of the Diesel engine was Rudolph Diesel.
Also, did you know Rudolph Diesel, who was almost as significant as Elon Musk back in the early 1900’s disappeared mysteriously from a passenger ship and was never found? His Diesel engine technology breakthrough was taking the world by storm. Rumor has it he was sharing his diesel technology with the British Empire to install in Royal navy submarines.
Many think he was murdered as he was costing billionaire moguls who produced coal fired ship engines their livelihoods as the diesel engine could produce much more power and for much less money. Or perhaps Der Kommisar from Germany wanted him gone for sharing diesel technology to Germany’s chief naval rival, the British.
Back then, it took many men in dangerous conditions to keep large coal fired ship engines running. Those men on the ships, sometimes as many as 200, had to housed, fed and paid to shovel coal and keep the engines running. Diesel engines made more power and took a smaller crew to keep running.
Diesel was taking over and still to this day 100 years later is still the go-to power source for most heavy tasks.
Rudolph Diesel is a very under rated inventor who changed the world forever with his Diesel engine technology and it’s still going strong today.
Another Glenn Beck listener!
I'm sure it helps with all that seat time.
Good Luck!
/ Please explain this difference between diesel and gasoline engines #43
Gasoline air fuel mixture compressed and ignited heating the air which then pushes the piston. Diesel compresses air only, then fuel is injected over time giving a continuous push on the piston instead of a sharp push falling off. The diesel will pull better because of the constant push.
Examples illustrating the cycles. Gasoline is giving the piston a quick kick at the top, diesel is like standing on the piston. Simplified.
/ Please explain this difference between diesel and gasoline engines #44
Diesel engines bring in a fixed volume of air per stroke, compress it anywhere from 14:1 to as high as 25:1 and then a very precise amount of fuel is injected under very high pressure to atomize it on the piston to combust. So, “the air fuel mixture is not all over the place”.
Diesel engines do bring in a fixed volume of air every stroke. It is only the fuel volume that varies. So the air/fuel mixture is all over the place. Because the fuel volume changes while the air volume does not. You post makes no sense.
Eric
My understanding from my fluid dynamics course (a long time ago) was that despite the piston displacing a certain mathematical volume each stroke, the air charge density (which is what really counts from a AFR perspective) is going to vary considerably dependent on temperature/outside air pressure, as well as turbulence/shear effects in the intake tract. The piston is not at full downstroke long enough for pressure to equalize with outside air pressure, so the charge density is also going to be variable by RPM. Intuitively, it would seem that the higher the RPM the less time to equalize and thus the lower the charge density prior to the start of the compression stroke.
In mechanical diesel injection, more throttle means more fuel per stroke is injected which results in higher RPM. So assuming the charge density does indeed decrease with RPM, this would indeed lead to even greater variability of air-fuel ratios. In a common rail ECU controlled solenoid injector system, injector on-time still controls RPM so AFR would still have substantial variation.
/ Please explain this difference between diesel and gasoline engines #45
I know someone here can help me with this question. Maybe the question should be spark ignition versus compression ignition, but I will just use gasoline spark ignition vs diesel compression ignition. Anyway, gasoline engines are very sensitive to air/fuel ratios. For example, gasoline engines when run too lean can run way too hot and this can result in pre-ignition, burnt valves, and melted pistons. I have personal experience with a melted piston crown, darn it. So the air/fuel mixture is closely controlled. Diesel engines don't control the air at all, the engines are always sucking in as much air as possible. This means that the air/fuel mixture is all over the place. So why is it that a compression ignition diesel engine can tolerate the very lean condition at low throttle settings? And, from what I have read here, diesel engines run hotter at higher throttle settings and running them at too low of a throttle setting, such as excessive idling, can cause problems such as "wet stacking". The reason being that the engine is running too cool and all the fuel is not burning completely. It's just idle curiosity on my part and I figure a good answer is likely to be found here.
Thanks,
Eric
Hello Eric, that's a good question you asked. Did you ever get an answer that you feel comfortable with?
If so...what?
rScotty
If so...what?
rScotty
I have not yet. Many answers did not address the question. Others tried to justify incorrect statements or had faulty logic. Like applying conditions to a diesel engine but ignoring the fact that a gasoline engine would have the same conditions. I guess I'm gonna need to really learn how the two different types of engines work and then post my findings. It looks like the library is in my future. Or I could get Chat GPT to write me some BS that I could then post here. Strike that. I'm heading to the library.
Eric
/ Please explain this difference between diesel and gasoline engines #47
I believe Direct Injected Gas motor introduce the gas before the compression is near completion. But I've been wrong before and will be again :unsure:
Beside tech moves to fast for me, these days.
They do funny things with DI, that is why they go to the effort to implement Direct Injection. They can inject multiple short bursts to control combustion speed for better efficiency and emissions.
Ford did same starting with the 6.4L Powerstroke diesel. Controlled the timing of the injection(s) up to 5 per cycle. Eliminated the traditional diesel rattle. But the really nasty thing they did was use DI during the exhaust cycle to dump raw fuel into the DPF for regeneration. Much of this fuel washed the cylinder walls and diluted the oil.
Fuel dilution of oil is a common malady of gasoline DI engines.
My F-150 has DI and traditional port injection. My Subaru has only DI
/ Please explain this difference between diesel and gasoline engines #48
Eric
In a spark ignition engine the fuel is mixed with air before the compression stroke. Near the end of the compression stroke, the spark plug(s) fire and ignite the mixture. The engine designer's goal is to make the fuel/air ratio the same throughout the combustion chamber at the time of combustion. There are a lot of ways to help that including tumble or swirl intake ports which encourage the fuel/air to circulate in the cylinder as they're being compressed, and squish bands which help the fuel/air mix as TDC approaches. The more homogeneous the mix the better it burns but that also makes detonation possible.
In a diesel, the air is compressed and then the fuel is injected near the end of the compression stroke, using a high pressure injector which atomizes the fuel. This makes a cloud of fuel/air in the middle of the chamber. Due to the high compression the air is already so hot that the atomized fuel spontaneously ignites where it's the right (stiochiometric) ratio with air. (Compressing air heats it up as anyone who has touched the fins on their air compressor knows). But the mix across the entire chamber is not homogeneous. There's a cloud of fuel, which is surrounded by air.
Spark engine detonation happens when the engine gets too hot. Something inside the chamber can overheat and serve as an ignition source. But ignition can also happen spontaneously due to the heat of compression, if the air in the chamber started out too hot. This early ignition puts more heat into the combustion chamber cylinder and piston, which compounds the problem for the next cycle.
Diesels are resistant to detonation because the fuel cloud burns up as its being sprayed out, so there's not unburnt fuel/air in far corners of the chamber to be ignited by a hot chamber. Compared to a spark engine the pressure rise is slower, which reduces the likelyhood of detonation. They can get detonation if there's too much fuel injected or the timing is off but those usually only when those are well outside the normal operating parameters.
/ Please explain this difference between diesel and gasoline engines #49
I'd like it if someone could answer the original question which in a nutshell is this: Why is a lean mixture catastrophic for a gas engine but not for a diesel? So far the majority of the discussion has not been about this.
I'm going to venture a guess that it has to do with the differences in burning characteristics between gas and diesel. But I have no idea if I'm right or not. It's just a hunch at this point.
Your statement above makes some sense. I'm gonna need to think about it and learn about how diesel burns compared to gasoline. I think the way the fuels burn is the reason, or main reason, for the differences in temperature. You also stated that when the diesel is injected it starts to burn when the right (stoichiometric) ratio is achieved. I think you are partly mistaken. I think the fuel starts to burn as soon as it can and doesn't care about the stoichiometric ratio. I still am trying to learn why the very lean burn condition of a diesel engine doesn't lead to the very hot conditions that very lean burning gasoline engines experience. And just to be clear, I am not talking about diesel engines with electronic controls, but instead diesel engines with mechanical injection. Like the engine in my 43 year old Yanmar. As near as I can tell even gasoline engines with fuel injection still burn too hot when running too lean.
Thanks,
Eric
I think you are correct in that it is the burning characteristics that make the difference. And thanks for bringing up my original question.
Cheers,
Eric
/ Please explain this difference between diesel and gasoline engines #52
Yes. The DoD procured "multifuel" trucks after WWII that had a lever to select gasoline or diesel. GIs found it ran like a scalded dog with gasoline in diesel mode... until the engine grenaded.
/ Please explain this difference between diesel and gasoline engines #53
Thanks,
Eric
Diesels are only "lean" if you think about them like gas engines where the air and fuel are completely mixed. They're not. Think of a diesel idling. It's still getting a full flow of air (no throttle plate) but only tiny squirts of fuel. Only the area right around the injector will have fuel concentrated enough to burn. The rest of the chamber's mostly air, with maybe a small amount of unburnt fuel. When the fuel droplets are too far apart there's no chain reaction to maintain combustion.
I dont think EFI vs MFI makes a difference in the basic theory of how the two systems differ in combustion. Same with IDI and CVCC.
Modern EFI gas engines can run pretty lean compared to the old days but they're nothing like diesels. And they can only do it with knock sensors and the ability to fine tune the fuel and timing.
/ Please explain this difference between diesel and gasoline engines #54
Injection timing is critical to a strong running engine. Diesels ignite the fuel due to heated air when it is compressed, this makes compression critical. A lot of diesel engines produce only 300 to 400 at a compression test (crank over, no start) but once running develop 1000 psi, some even more, depending on the particular engine. The fuel burns longer, usually down a longer power stroke than a gasoline engine.
Now, the injection system for fuel times the combustion event for optimum power based on RPMs, throttle input, or computer depending on the fuel system. Piston crown shape helps burn the fuel easily. Sometimes they rely on a prechamber, that may be in the head or built into the top of the piston.
Add a turbocharger or blower to the system, you get more air than you need, helping produce the ignition event. This produces more power. Remember, internal combustion engines are a air compressor.
Hope this help you understand a little more.
/ Please explain this difference between diesel and gasoline engines #55
Second that.
So at low fuel , the Diesel can tolerate the extra air ( that it needs to achieve enough compression ) because its mix is not homogeneous at the instant of ignition, burning wherever it can near usual propagation speed. At high fuel, the mix moving closer to ideal stoichiometric.
A lean petrol/air mix , already homogeneous, burns slower & down the stroke thru to exhaust so appears "hot" since its energy isn't as largely absorbed displacing a piston.
/ Please explain this difference between diesel and gasoline engines #56
This is a tough crowd!
Just some statements off the cuff as pertains to I.C. engines.
First, "The High Speed Internal Combustion Engine" by Ricardo 1923 IS a MUST READ!
Gasoline engines don't need spark ignition to burn, but the uncontrolled flame front propagation will kill the engine in no time.
Honda experimented with "Radical Burn" technology and there are several "lean burn" schemes that have come and gone over the years. (as mentioned here by others)
Gasoline engines also rely on the "heat of vaporization" to cool the intake charge.
Alcohol burning engines such as JAP or ESO speedway machines run VERY HIGH compression ratios without detonation due to their FUEL, Alky, but still rely on spark ignition.
Methanol is Alky, and has a HUGE heat of vaporization value, Speedway bike cylinder heads are sometimes insulated to keep heat IN.
Popular in England , and elsewhere for a time, were TVO engines. Thermal Vaporizing Oil.
The spark ignition engines were started on gasoline, and after a suitable engine warm up, the fuel tap was switched to draw from a kerosene tank. This was popular for ag tractors due to fuel costs and availability. Many Fordson tractors built in Cork and Dagenham were so fitted.
This "flex fuel" desighn was an option for the E27n that I run, though the one I have is gasoline only. IIRC the engine compression ratio is around 6:1. ;-)
There was little difference in the engine internals between the TVO and a gasoline only engine., but the induction track had a Heat Plate that was warmed by the hot exhaust. I'm quite sure the engine would run just fine on gasoline but perhaps there would be a tendency to knock under load.
I am not aware of any Diesel cycle engines that do not make use of direct injection. The pressurized spray being required to atomize the heavy fuel being necessary I suppose.
Ocean going diesels burning "bunker crude" require fuel heaters to liquefy the fuel to make it suitable for injection.
Compression ignition engines Diesels, come in both four stroke and two stroke designs.
The "Detroit Diesel" the flag bearer of the two stokes.
I have not seen any "rotary piston" compression ignition engines . Wankels would seem to be a great platform, but not yet ;-)
I could go on, Please add in any otherr gems you might be holding back. I have engoyed the IC engine all my life, I must have 40 of them all counted .
Now don't get me started on glow ignition. I can smell the "Missile Mist" now.... ;-)
There are many diesel engines that use a pre chamber in the head firing deck. It gives them a tighter area to burn the fuel at the beginning of the firing event. Direct injection sprays fuel directly on top of the piston on it's way up and they are shaped different to allow for this. The larger the engine the less use of pre chambers you find.
/ Please explain this difference between diesel and gasoline engines #57
Diesel fuel is much easier to store than gasoline. It doesn't degrade nearly as quickly as gas.
Most modern diesel engines use super high injection pressures in the 30,000 psi range. HPCR (High Pressure Common Rail) This allows the injectors to highly atomize the fuel. Also the computers are able to fire the injectors multiple times in one power stroke. Ever wonder how they got diesels to be so quiet? They actually spray a shot early to start the combustion so as not to create as violent of an explosion. Then the injector fires again, often multiple times. And yes in diesels there is fuel timing. It is similar to spark timing with respect to the timing of the injection relative to piston position. Timing is controlled by computer.
Another great advantage of HPCR is cold weather starting. Much easier to start.
I have 2004 Dodge Cummins. It is HPCR. The only cold start assistance it has is a ribbon heater in the intake horn. I can start that engine in below zero conditions without waiting or plugging in. Granted it will crank a few seconds longer but it always starts.
/ Please explain this difference between diesel and gasoline engines #58
Musk is not an inventor just an investor.
/ Please explain this difference between diesel and gasoline engines #59
The ribbon heater isn’t for starting just for emissions reduction while cold. Crank time is longer on HPCR because the injection pump needs some speed to develop the pressure.
/ Please explain this difference between diesel and gasoline engines #60
Thanks,
Eric
The simple answer is it’s the fuel characteristics.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MACK MDRIVE TRANSMISSION (A60736)
MACK MDRIVE...
MAGNUM POWER PRODUCTS LIGHT PLANT (A60736)
MAGNUM POWER...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A60736)
2013 POLAR TANK...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
2007 Ford F-750 Terex Hi-Ranger 5TC-55 55ft. Bucket Truck (A60352)
2007 Ford F-750...
