Please explain this difference between diesel and gasoline engines
   / Please explain this difference between diesel and gasoline engines #11
Unless you have ideas about improving the design it isn't important. What is important is keeping engines in their power band as much as possible. One reason diesel engines have a reputation for longevity is because a high percentage has traditionally been operated by professionals and operators with training. As witnessed by the number of posts here about overheating, armatures are rapidly changing statistics.
   / Please explain this difference between diesel and gasoline engines #12
The non control of intake air is not set in stone.
RAM with Cummins added an intake throttle valve under ECU control on the newer 6.7's and as soon as they did, a market was created to remove them. Diesel air fuel running ratios are much wider than a gas engine. See shot at 1:50 for a throttle valve being removed.
   / Please explain this difference between diesel and gasoline engines #13
Fairly easy to explain the difference. 3 of them. The fuel, second is ignition and third is fuel pressure. Diesel fuel has more has more energy than gas. Second, Gas needs a spark diesel just uses high compression. To push fuel into a combustion chamber of a diesel engine takes more pressure since compression is so high. Everything else is a wash…
   / Please explain this difference between diesel and gasoline engines #14
Diesels need: Air, fuel, compression, & proper cam/crank timing.
Gas need: Air, fuel, spark, compression, proper cam/crank timing, & proper ignition timing.
All in all...it comes down to the volatility of the fuel. Diesels need heat to help combustion. Gas engines try and shed all heat. Because heat has energy, diesels harness and use the heat better.
Diesel engines bring in a fixed volume of air per stroke, compress it anywhere from 14:1 to as high as 25:1 and then a very precise amount of fuel is injected under very high pressure to atomize it on the piston to combust. So, “the air fuel mixture is not all over the place”.
Diesel engines do bring in a fixed volume of air every stroke. It is only the fuel volume that varies. So the air/fuel mixture is all over the place. Because the fuel volume changes while the air volume does not. You post makes no sense.
Eric
So why do gas engines run hotter when running lean but diesels do not? Is it because diesel, when volatilizing, cools down the combustion chamber? I don't care about efficiency, or torque, or longevity, I just want to know why the two types of engines burn differently. I know that if diesel is pre-heated it can be used in a gasoline engine. If this is done will the gasoline engine still exhibit the same lean running behavior? And will this be because the diesel is hot when introduced into the combustion chamber? Maybe I need to buy a book.
Eric
   / Please explain this difference between diesel and gasoline engines #17
Eric
air is a gas and gasses burn hotter than a fluid.
-thermal dynamics 101
I'm sorry, I don't understand your response. Air is certainly a gas but it is the gasoline or diesel that is burning, the air is just the oxidizer. And air is being used in both engines. When the gasoline is first introduced into the cylinder it is a fine mist and/or vapor. The diesel is a fine mist. I don't know but I imagine that some of both the gasoline and the diesel turn into a gas during the combustion process. Does this phase change in a diesel engine cool the air and diesel charge in the cylinder so much that running lean doesn't lead to high temperatures like it would in a gasoline engine?
Thanks,
Eric
   / Please explain this difference between diesel and gasoline engines #19
This is a tough crowd!
Just some statements off the cuff as pertains to I.C. engines.
First, "The High Speed Internal Combustion Engine" by Ricardo 1923 IS a MUST READ!
Gasoline engines don't need spark ignition to burn, but the uncontrolled flame front propagation will kill the engine in no time.
Honda experimented with "Radical Burn" technology and there are several "lean burn" schemes that have come and gone over the years. (as mentioned here by others)
Gasoline engines also rely on the "heat of vaporization" to cool the intake charge.
Alcohol burning engines such as JAP or ESO speedway machines run VERY HIGH compression ratios without detonation due to their FUEL, Alky, but still rely on spark ignition.
Methanol is Alky, and has a HUGE heat of vaporization value, Speedway bike cylinder heads are sometimes insulated to keep heat IN.
Popular in England , and elsewhere for a time, were TVO engines. Thermal Vaporizing Oil.
The spark ignition engines were started on gasoline, and after a suitable engine warm up, the fuel tap was switched to draw from a kerosene tank. This was popular for ag tractors due to fuel costs and availability. Many Fordson tractors built in Cork and Dagenham were so fitted.
This "flex fuel" desighn was an option for the E27n that I run, though the one I have is gasoline only. IIRC the engine compression ratio is around 6:1. ;-)
There was little difference in the engine internals between the TVO and a gasoline only engine., but the induction track had a Heat Plate that was warmed by the hot exhaust. I'm quite sure the engine would run just fine on gasoline but perhaps there would be a tendency to knock under load.
I am not aware of any Diesel cycle engines that do not make use of direct injection. The pressurized spray being required to atomize the heavy fuel being necessary I suppose.
Ocean going diesels burning "bunker crude" require fuel heaters to liquefy the fuel to make it suitable for injection.
Compression ignition engines Diesels, come in both four stroke and two stroke designs.
The "Detroit Diesel" the flag bearer of the two stokes.
I have not seen any "rotary piston" compression ignition engines . Wankels would seem to be a great platform, but not yet ;-)
I could go on, Please add in any otherr gems you might be holding back. I have engoyed the IC engine all my life, I must have 40 of them all counted .
Now don't get me started on glow ignition. I can smell the "Missile Mist" now.... ;-)
Your post reminds me of something I fooled around with about 40 years ago. I was just window shopping in a place that sold all sorts of glow plug engine stuff. And also exotic airplane engines. Really cool engines with all sorts of different valving schemes. Some engines were 4 stroke, others two stroke. There were engines that used sleeve valves and others that used cylindrical valves and others that used disc valves. The best part was that many of the engines used nitro methane fuel. The nitro was mixed with oil and MEK by the customer. For glow engines the MEK was used for ignition timing. I guess the more MEK, up to a point, advanced the timing. Anyway, I wasn't buying any of these wonderful engines, they were way too expensive of a hobby for a newly married guy with a baby and a wife in school and buying a house at 11.75% interest. But I did buy nitro methane in quart bottles to play with. I would machine the heads on my lawn mowers to raise the compression. These were side valve engines so there wasn't the ability to raise the compression as much as overhead valve engines. But I would also relieve the head where the valves went and would shape the valve pockets in the heads to help the air/fuel and exhaust flow. Then with some nitro mixed in with premium gas I could get way more than 3.5 HP out of the motors. They didn't last long but boy could they cut tall grass. It was all for fun. My brother was amazed at how the lawn mowers could mow down the tallest grass without any problem. I had a lot of fun goofing with those engines. But I still want my original questions asked about diesel vs gasoline engines.
Eric
2016 DORSEY FC48 48FT FLATBED TRAILER (A58018)
2016 DORSEY FC48...
30ft Highway Trailer Co. Lowboy (A56435)
30ft Highway...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
Kubota M108S (A53317)
2016 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2016 CATERPILLAR...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
