Importing and modifying a new mini excavator from China
/ Importing and modifying a new mini excavator from China #441
You guys sure don't make those things sound like a good deal!!
SR
I wouldn’t buy one. They’re not even that good of a deal after all the fees are paid. Sany is supposed to be a good machine and I probably would have one of those but they’re not priced low enough under a Deere or Kubota to appeal to me.
/ Importing and modifying a new mini excavator from China #442
Yeah, I think in the big machines the price difference gets bigger and bigger but for anything I've priced(6ton or less) the price difference isn't nearly enough to go chinese for me.
/ Importing and modifying a new mini excavator from China #443
Yes Track Motors make the heat faster, I noticed that. The Temp gauge in the tank is impossible to read so I was assuming the darkening of the Oil was from Heat because Yes they do get Hot.
The hyd oil is getting brown? That should never happen. One of the first things I did (see above) is get rid of OEM fluid. You don't know what they used, it flushes out manufacturing dirt, and it is likely the cheapest stuff they could get.
Next is install a temp gauge. I use a passive capillary style, and try not to exceed 50C. The hyd motors for the tracks heat the oil fastest.
Finally, any cooler will help, but choose wisely for where you can install it and the current it draws is less than the capacity of your alternator.
If your hyd filter is properly installed, it is on the return path to the tank, which is low, but positive pressure. The inlet side of the pump can be subject to slight negative pressure, so sturdy hoses must be used. This location or either side of the filter will work if installed properly.
My Briggs has 10A, so I should be ok with this unit, but then I was thinking, working at an Auto Dealership with a Body Shop, I will try a fractured vehicle Elec. Fan and cool everything in the Dog House. Free so no loss if it doesn't work.
Looking at Pictures of my machine (it is at the Cabin) it appears that my Spin On Filter might be NPT anyways. Fitting measurements might require a smaller cooler anyways. But Flow might be a concern. kind of why I was considering the 13 gpm Cooler initially.
/ Importing and modifying a new mini excavator from China #444
A 2006 Bob Cat 323 with 600 hours available locally for $22500+HST. So only 2x's+ what I have invested.
For basically a Shovel. Personal, at the Cabin. Sure I realize that there is Resale Values also, but $13K in my account is comfortable too.
The calculation remains the same as when I started this thread: you can get a beater Kubota or Tak or IHI 1-ton for $10-12K + shipping, if you can find and inspect one Or you can get a new and tight China 1-ton for about $7500, with fewer features.
I have had a lot of beater tractors, and I eventually stopped fighting it and went with new and tight.
Somewhere in the backwoods of Shandong province, some one or a group of engineers/technicians designed the basic 1-ton mini, maybe 5-10y ago. It was well thought out in terms of cooling, using copies of the older small Yanmar L100 500cc diesel thumper. I was impressed how they ducted the cooling fan to take outside air into the house. This design sold all over the world where they don't care about emissions. Some were even sneaked into the US.
Flash forward to a few years ago where Americans (like me) talked to several factories about importing their units with an EPA- and CARB-legal engine. So some of the factories started shoe-horning the B&S XR2100 gas engine (a good engine made in China) into some units. Poorly.
That's really too bad, since I have shared with them how I installed my gas engine a much better way. My vendor (Xiniu) was not interested, since they are a big factory selling much larger excavators.
Many other smaller factories now offer a poorly-integrated gas engine. All fixable for the DIY user, but needing some fixes right off the boat, IMO.
One more thing: those crate motors you get from B&S, Honda, LCT, HarborFright, etc. are not really designed to be all closed up in a compartment. They need to breathe to stay cool. If the inside of the mini's house gets up to 150F, that is not really good for the gasoline tank. Vapor pressure will skyrocket, which is not good.
/ Importing and modifying a new mini excavator from China #446
Very factual. Some of the units I have seen have the B&S angled to fit the engine compartment, yet extended housings to hold the Hydraulic Pump. I would like to compare the heat from a slow rev'ing small diesel compared to a B&S, but it is what it is. It is easy just to leave some covers off if needed.
While searching for a Machine for the Cabin, I thought of a little Bota, and was told EPA regs weren't needed below 25hp Diesel, I wounder why the KOOP couldn't just stay in place?
There are EPA and CARB regulations for <25hp engines, just less stringent than regs for >25hp engines, where you run into "TIER IV" diesel standards that require EFI, rather than mechanical FI. (And soot burners, DEF, etc.)
Even your simple 1-cyl gas engines have EPA and CARB requirements, tho they are met using EM (engine modifications), PAIR (pulsed air), TWC (three-way catalyst), and/or a vapor canister.
And most important, you have to have the EPA (and CARB for us Californians) label on the engine.
/ Importing and modifying a new mini excavator from China #448
I fully understand people hating CE machines if they cant work on their equipment , but rebuilding a clapped-out name brand is even worse. I've done it.
Don't be fooled by thinking name brands aren't sourcing their parts from China.A lot of name brand " small " equipment is completely made and assembled in china. Yes they have all the bells and whistles , but i enjoy the challenge .
I'd rather install some small needed pieces than disassemble an old dipper arm, ream out the sleeves, pay the cost for new oem ones, purchase oem pins, then reassemble the whole mess. As to resale most of us will never sell. We will let our kids deal with that problem when the time comes.
/ Importing and modifying a new mini excavator from China #449
Do you really believe that "that's" the only two choices??
Personally, I wouldn't choose either one of those two choices.
SR
/ Importing and modifying a new mini excavator from China #450
SR
Life is full of "Choices" but most time, way more "Choices" than Bank Accounts.
I remember Twisting Wrenches at a Ford Newholland Farm Store back in the 80's. A Local Contractor came in and purchased a 5610 MFWD, Cab. I was installing an Allied Loader when one of His workers stopped, I asked if he was excited to get a New Machine? He scoughed "He will get laughed right off the Job Sites, it's not Yellow" (Industrial).
The 5610 outlasted that worker's career there, and the Contractor's life, moved on to his Son's running and then selling the Business. I am sure it was still an Asset on the Books.
The basic Bones are there on these CE Hoes, would they get Laughed off a Job Site? Definitely, Will they respond better than the Wife being handed a Shovel and saying "Lets dig that Basement you wanted" LOL
Yes My BiL and I dug a Basement by hand for my Sister. Then when the last shovel of dirt was done, we shoveled the Cement into forms 2, 8' forms/night
/ Importing and modifying a new mini excavator from China #451
I often wonder, "Who runs EPA" I mean Emission Cheating 50mpg Volkswagens, being Fined, repurchased, and replaced 25-30mpg Gassers. While those repurchased 50mph Oil Burners are running around still, just not here.
GM and Stellanis, just now being Fined for not meeting 2016 CAFE Standards. B&S Engines passing because of a Charcoal Gas Cap EVAP System that doesn't work. Even Above Ground Septic Systems because of Ground Water Contamination?
We had a Flooding situation here last year 100's of thousands Sand Bags were deployed. Those Sand Bags weree to be retrieved because they were now considered Contaminated?
/ Importing and modifying a new mini excavator from China #452
My pockets are about as deep as the ornamental pocket on my wife's fancy jeans. Just big enough for one sleeve of Pennies.............
My next door neighbor is about to turn 97.He remembers everyone on the road got together for barn raising, hog butchering, plowing ,etc.
The farm across from me was sold and now has 40 homes on it. The new paved road ends at my property line. I know some of these new folks, and wouldn't trust them with any tool more sophisticated than a screwdriver.
Quite a few gleefully waved as I came home with my New Mini X on the trailer. They could care less it's from china. I'll be digging for them for a fee in less than two weeks along with success on my own projects.
I'll never be ashamed of any of my "Chinese Junk Tools" as some appear to see them here. Besides I was under the impression this thread was "ABOUT" importing and modifying Chinese mini excavators.
Lots and lots of choices here , everyones entitled to their own opinion . I think i'll try to stay on topic from now on .
/ Importing and modifying a new mini excavator from China #453
Hose wrap installed. For anyone who needs an estimate, I used a total of 50 feet.
/ Importing and modifying a new mini excavator from China #454
Put exhaust wrap on the Briggs muffler. Only deceased the temp by 25 degrees. I'm gonna put the cage bake on for safety.Double safety wired it on. Also made an extension for exhaust pipe to get it out side the machine.
/ Importing and modifying a new mini excavator from China #456
How does that hose wrap work?
It is just slit open down the length and snap over the rubber hoses?
Some of my "Chinese junk tools" are made better than my American junk tools.
Have you done any digging yet?
/ Importing and modifying a new mini excavator from China #457
This is what you find when you disassemble the Briggs gas cap. The round canister is full of charcoal. Unfortunately " all the charcoal fell out and I couldn't figure out how to put back all the other bits back either ". I "mistakenly " drilled some more holes in the canister to let some of the smell out.
/ Importing and modifying a new mini excavator from China #458
Ive had motorcycle headers burn out before their time .So duly noted, but your kind of turning it in a poor mans cat converter.
The wrap is cut in a spiral.You just wind it on the hose clockwise. It is cheap insurance against uv break down of the hoses. Measure your hose and add about 18" to length of wrap for your long hoses.
Yes done some digging but house gets so hot am waiting on fans and radiator before it will be ready for prime time. Digs better than I hoped.
/ Importing and modifying a new mini excavator from China #459
I just tossed the Charcol Cup out, and snapped it back together. Left the Red Nipple and cloth screen in place
/ Importing and modifying a new mini excavator from China #460
My cap had a 1/16" hole in the cup and not even compressed air would go through the cap. I did save the parts though just incase.
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
2004 Rockwood Freedom 1640LTD 18ft. Pop Up Camper Trailer (A61569)
2004 Rockwood...
(2) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(2) 380/85R28...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
