Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #221
Wow these Chinese mini excavators seem like a lot of hassle. Doesn’t a nice used Kubota run around $10,000 in a similar size? Thank you for sharing the info with us.
10k for a excavator will pretty much get you a clapped out project around here.
Not sure about the Chinese ones, but for how much I use it, and the fact I already have some good engines, it might be worth it.
   / Importing and modifying a new mini excavator from China #222
I assume these are open center hyd. systems? How do they do with multiple functions at one time?
I dealt with my search for a used mini above.
Just 2 weeks ago, I did an inspection on a used IHI IS10 diesel that a local guy just bought for $9200. It is maybe 30yo and has no hour meter. It has a nice running 2-cyl Isuzu engine, but tracks are worn out, and the boom-swing cylinder cross-tube is broken. Its rod it bent, too. Can't access hyd system unless panel(s) are removed. Has not seen the business end of a grease gun in years.
Not sure if it was mentioned earlier in this thread, but can you buy one without the engine? I have a couple 16-34hp Kubota diesels sitting around that should work well in one of these.
That was half of the point of this thread. My first unit I bought with no engine. Currently, at least 4 companies will sell you a unit with EPA gas engine installed. Multi-cyl engines will be tight fit.
Hydraulics are like those on a tractor: single gear pump, open-center, direct-control joysticks. Feathering takes practice.
   / Importing and modifying a new mini excavator from China #226
Shows how I shouldn't rely on my memory, I was following this thread when you first started it but lost track a while ago. For some reason I was thinking you bought it with an engine and changed it out for a different one, guess I should have refreshed my memory!
The hydraulics are a little disappointing, no better then my backhoe. Guess I could always upgrade them to multi pump, but at some point the cost savings go away.
True. To get piloted servo-valves and more than one pump, you have to go to the next size level up, even with Kubota, Cat, etc. Same with the Chinese machines.
To sell a much less expensive machine, these units have a cheap engine, no boom-swing, fixed track width, and direct-drive wheel motors (no planetary final drives). They DO come with an AUX valve, plumbed to the dipper, and very inexpensive replacement parts.
   / Importing and modifying a new mini excavator from China #228
I'd even be happy with multi pump and seperated valves so I could operate multifunctions without having to play the joystick juggle!
   / Importing and modifying a new mini excavator from China #229
See Post # 47 above.
You may also want to add filtration, as I did. See above.
From my picture on post # 213 it looks like there may be some clearance issues for an air duct. I will get a better look in the next couple days since the machine isn't near me at the moment. I am also going to contact the manufacturer to see if they can at least tell me what size fitting I would need to adapt a cooler and filter. Or if they have something they can send me. Did you ever install an oil cooler? Or run into any issues of getting it hot?
   / Importing and modifying a new mini excavator from China #230
I guess it depends on what part of the country you live in.
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
207276 (A52708)
207276 (A52708)
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
