MF 1835M loader support collapsed on tractor
/ MF 1835M loader support collapsed on tractor #141
Doug62, have you had a chance to contact the dealer to see where you stand on this? I think everybody that read this post is keeping an eye on it.
/ MF 1835M loader support collapsed on tractor #142
Even Massey owners that don't have this specific model :)
/ MF 1835M loader support collapsed on tractor #143
For those that seem to believe that Kubota never breaks, well, Kubota loader mounts break too.
Anything can break, that's why I don't loan my tools. I don't think anyone has said XXXX brand wouldn't, just that the quality is better, which is a point anyone can argue till their blue in the face and it wouldn't make a difference to either party in the argument. Do the best you can, with what you got, where you're at.
/ MF 1835M loader support collapsed on tractor #145
If warranty doesn’t cover it that would be the last MF I would ever buy. I suspect there were some serious mistakes made when it was built.
I would one up that response and use "designed" instead.
I never really looked at the modern loader frames. I didn't know they made some with no nose bar. The nose bar on my Farm Hand loader would stop that from ever happening. Mine looks like this one, just not as pretty.
Same with the older Koyker's, Fords and they also run back to the rear axle.
These new single vertical support per side are good looking but not near as strong as the old designs that run to the front engine / axle main mount and rear axle.
Those main verticals also look way to thin and under braced wonder if that is just mild steel?
Something tells me there will be More of these models failing...
Hope no one gets hurt.
Massey doesn't make 'em like they used to (I mean back when they were still headquartered in England). Anyway, it's clear that the welds had inclusions that rusted after the paint failed at the top of the bracket, the region most exposed to sun, water and abrasion from falling dirt and rock. It's also likely the steel is poor quality. Good quality, high carbon steel doesn't rust fast or deep even when unpainted and exposed to weather. Nowadays most of the steel used in the manufacture of consumer level products is smelted from the recycled junk we ship to China. It's got rust baked-in at the foundry. Buy an orange one next time.
May be some design problems but, the steel was sub standard to rip apart like it did. Looks as though the welds were good, they never failed, One side has been breaking for a while you can see this by the rust in the old crack and the shine on the new rip apart. Maybe substandard steel in my metal working years we often seen in foreign made steel voids inside steel plates ( you could not see those until you cut into them ) what a pain to work with. Is that voids around the subframe sticker?
At any rate the design should be rated far above the lifting capacity of the Hydralics.
I agree but from the limited pictures, I think it's a very poor design fault. The entire load appears to be transferred to that 4"x4" sq tube that's at a extreme mechanical disadvantage from what's essentially a difficult highly leveraged rotational load.
Clearly under sized for these loads to be transferred to such a small cross section.
I'd look around for a group or forum of model specific "talk" to investigate others experiences with this tractor/loader .
That design reminds me of the "VM" FELs except some of those did at least have some extra supports.
I feel bad for the OP , Here is Hoping Massey gets him a new updated redesigned and stronger FEL main frame and supports.
/ MF 1835M loader support collapsed on tractor #146
Shoot, who from this thread hasn't at least cast one extra glance at their loaders no matter the brand.
Until now I never thought to look at that part of the supports for tell-tail signs of cracking at the welds. I probably would not have looked at this thread if it didn't have "MF" in the title. Glad I did, just one more thing to add to my inspection list during maintenance.
Like someone else said. To me it looks like there was a bad weld at the top where the rust started and it slowly got worse until it failed. Rust seems to progress in severity along the break. I don't see how anyone could put enough stress on an FEL in the direction needed to break the weld at the top of the support. In my opinion you'd really have to ram something hard enough to jar your teeth outa your head while the bucket was swinging into the direction of the side of original break.
/ MF 1835M loader support collapsed on tractor #147
I'm still sticking with my Chinese steel theory. It's inferior metal. I feel bad for the OP. Massey has always been a proud name for tractors. It's too bad we have to cut corners to make a profit.
/ MF 1835M loader support collapsed on tractor #148
And unfortunately everything is like that now. Go look at an old Caterpillar excavator. Everything was thick heavy steel. The engine bay body panels on my new 330 are made from sheet metal I think they stole from an office filing cabinet.
Every time the machine shakes it sounds like someone is dumping a scrap bin beside you.
/ MF 1835M loader support collapsed on tractor #149
will warranty cover repair/replacement ?
/ MF 1835M loader support collapsed on tractor #150
I don't know, maybe I'm wrong? But I just looked at the pics of the way the Massey loader stands are built and had to go compare to my way smaller B2620.
Look at the design. Not just a thinwall square tube. It is full of gussets and bracing. And the round tube is actually tied right back to the frame at the rear axle.
You would think the bigger tractor would have more beef to the loader stands than that.
/ MF 1835M loader support collapsed on tractor #152
So I stopped by my Massey Dealer and all the 18M's had Rev 1 loaders on them, all 3 of them.
Also, not only do the 18E series use tube shaped loader mounts, but so do the 2800 series, so I don't know why it's changed up for the 18M.
The steel looks very rough. Poor quality? China?
/ MF 1835M loader support collapsed on tractor #154
Those frame assemblies are probably shipped in from China. That older/rusted area at the top is the area with the most load when carrying material with the bucket and hitting some bumps along a traveled area. Looks like it came that way and covered with black paint. Yellow is nice, cracks are easier to see.
Automated production and not enough inspection.
Someone mentioned that the hydraulic relief valves are not used except when the lever is pulled. I haven’t seen the valves on this machine model but all the ones I have worked on in the last 55 years had circuit design with relief valves being in the circuit at all times. Kinda useless otherwise.
All in all that is a defect that they should jump on!!
I've worked on a lot of loader valves that have load checks. A load check is to combat settling but it also effectively isolated the down circuit from the relief. At any rate the material in those towers is so minimal that a cold weld is very possible because the slightest amount of undercutting would certainly be an invitation to failure.
/ MF 1835M loader support collapsed on tractor #155
Yes, but he cuts out a lot and replaces damaged steel with good steel. He is quite an amazing craftsman.
Referring to the uTube channel IC Weld....
He is indeed an amazing craftsman and yes, in most cases the repair involves new steel, gussets, backer plates, etc. It was interesting to find out the large excavators usually had a failure on the boom. Most likely the heavy equipment he repairs have thousands of hours on the clock so breakage is more or less part of the total cost of ownership.
/ MF 1835M loader support collapsed on tractor #156
The OP in that thread also stated:
When I use the backhoe I lay the FEL bucket flat on the ground so that it will slide when I reposition with the hoe.
/ MF 1835M loader support collapsed on tractor #157
Is that suppose to be an issue? Anyways, there is another thread that I couldn't find the other day where someone in Australia also had the same breaking issue and he didn't have a backhoe.
/ MF 1835M loader support collapsed on tractor #158
Having a backhoe digging an moving side to side with the bucket on the ground can't be good for the loader arms over time.
/ MF 1835M loader support collapsed on tractor #159
Kubota cautions against lofting the tractor with the BH outriggers and the bucket with the entire tractor off the ground as it puts undue strain on the tractor cases, especially if the BH is a 3 point mount with no subframe. More than one owner is incurred a very expensive repair bill from cracking the cases by doing just that as in the picture. I happen to know someone that did just that to the tune of 10 grand.
Kubota suggests keeping the wheels on the ground at all times and never moving the tractor around with the BH bucket.
/ MF 1835M loader support collapsed on tractor #160
That's funny. My Kubota backhoe owners manual says to lift tractor off ground and put loader bucket down with pressure.
And that's the way I have done it my whole life with full size backhoes.
2017 Hyundai 53' Dry Van (A62613)
2017 Hyundai 53'...
2017 PETERBILT 579 (A65643)
2017 PETERBILT 579...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
