Tractor Causing Stress on Neck
/ Tractor Causing Stress on Neck #41
These are typically found in vineyards in the east and west. There are good dealers there. If you're in the mid-west, you might be farther from a dealer than is practical
/ Tractor Causing Stress on Neck #42
I agree 100%. I was actually pretty serious at one point about getting an Antonio Carraro and putting a heavy-duty flail mower on it and do custom brush mowing. Maybe they would be a bit small for your application. They import up to 75 hp models. They have bigger ones but those arent imported due to emissions reasons. Those are the ones i really want. Also, check out their Mach 4 model. It's basically the same tractor, but a quad-track. In my mind, it's one of the coolest tractors in its size category.
Nearly all the Antonio Carraro models have the option of turning the seat and steering wheel around so you're looking out over the 3 pt/pto. The visibility is phenomenal.
Just wondering, but why would you want a very complicated and expensive to repair Antonio Carraro over a US Built, component part, Power Trac that doesn't use a difficult to connect 3pt hitch and can lift all the attachments up higher then the AC which is nice when using lift forks, lift boom, front hoe, brush grapples, tree pullers and cutters, or even the rotary cutter to cut brush back that tends to invade along all the edges of fields growing to the light? The Carraro can't do any of this without buying a loader and then it is just like a standard tractor trying to look over a long hood.
/ Tractor Causing Stress on Neck #43
I can’t believe these tractors haven’t exploded in popularity here in the states. Small, tough, maneuverable, stable on steep hills.
I could literally build another business division cutting steep banks with one of them.
Have seen a few for sale at VERY affordable prices, but dealer support would be very difficult.
From participating on mainly US forums over the years, I realized that there is this huge misconception that a tractor without a loader can't do much. Which couldn't be further front the truth.
Being that Antonio Carraro tractors don't make very good loader tractor at all as it was never designed with that in mind, I really think that's why they don't sell better in the US.
/ Tractor Causing Stress on Neck #44
This portable camera system work wonders for my stiff neck:
It's powered with cordless tool batteries so there is no wiring and the magnetic mount cameras can be placed on any metal surface.
I place one on the outside edge of my rotary cutter deck so I can see to line up with the previous cut row. Also works well on the rear mount snow thrower.
/ Tractor Causing Stress on Neck #45
This is the loader I would get if I needed one. These tractors weren't really built with a loader in mind, like was mentioned already. There are loaders that mount on the front but I wouldn't want one of those. I really don't see how their hoods are that much longer or harder to see over than American tractors. But more to the point, OP mentioned mowing and neck strain related to that which is why I suggested this machine. If he had said he needed something for loader work, I wouldn't have recommended it
/ Tractor Causing Stress on Neck #46
Could you use a side mounted mower that doesn't require turning so far, like a sickle mower or flail mower?
Yeah, this thread reminded me of working on a farm in Concord MA in the 1940s. I was the little kid so I got to rid on the sickle-bar cutter (intended to be horse-drawn) behind Dad driving the Allis Chalmers tractor. The wheels drove the sickle-bar, chop-chop. My job was to raise the bar when necessary. I needed both hands to do it. Earned 25 cents/hour in 1943, 30 cents in 1944, and a near-adult 35 cents in 1945, the last summer of the war and therefore the last time Mister Laughlin needed to pretend he was a farmer in order to get unlimited gasoline for his 12-cylinder Lincoln Continental.
What fun it was, haying in August!
/ Tractor Causing Stress on Neck #47
It is NOT a loader. CAT coined the term "Tool Carrier". The PT is just a better designed machine. The implement, in this case a mower deck is right out in front of you where you can see and because of articulation, can even move sideways just by turning the steering wheel. If all you want is a mower, then that is what it is...just pick the type: brush, finish or boom or all of the above. The VERSATILITY allows you to use as a loader too, but again, it is not a loader. AND it is much easier then a 3pt hitch to connect, all can be done without leaving the operators seat except for connecting hydraulic hoses when applicable. Forget about struggling with a large PTO shaft between the lift arms!
I owned a Goldoni which is just like the A Carraro and they don't hold a light to the Power Trac in versatility. The the cost to buy these tractors, why not have one that can do a lot more work easier. I have attached 2 pics of my Goldoni and 2 of my PT similarly equipped.
/ Tractor Causing Stress on Neck #49
Maybe adding this with your existing rear rotary or Flail behind you might do the trick? If you want front only, could probably rig up a front mount with some fab work & a prince PTO hydro pump off the back if your flow isn't enough..
/ Tractor Causing Stress on Neck #50
Looking for suggestions, if there are any. I've had 2 tractors in the past, both of them are gone now. I am contemplating my next purchase, but I fear there is no good solution. 1st tractor had a 6 foot brush hog and I found myself turning my neck way too much trying to keep the cutter in line with the last pass so as to not leave anything uncut. 2nd tractor was much larger with a 12 foot flex wing. I had mirrors on that tractor which helped, unless I got too close to the trees and it would knock the mirrors out of whack - so that didn't help much.
4 years ago I had neck surgery, so I've got a fusion already on 2 vertebrae in my neck. I'm not willing to stress my neck just so I can keep my fields cut. I already have them cut for hay twice a year, so the only time I really have to brush hog is once during the year after the 1st frost. I have hired out someone to cut in the past, but it costs me at least $1K every time, and that's if I can find someone to do it.
Ideally, it would be nice to have a setup where the cutter is on the front instead of in the back but I don't know of any US tractors that have a front mounted PTO. The other option is a skid steer, which would be nice, but they are extremely expensive as are the cutter attachments.
We are new to the farming community and I've talked to alot of the farmers around here and was surprised to learn many of the older ones have neck and back issues. I don't want to be another statistic, so I either need to find something that cuts in the front or pay someone to do it. Any advice would be greatly appreciated.
What about a camera and monitor system ?
/ Tractor Causing Stress on Neck #51
/ Tractor Causing Stress on Neck #52
I still don't entirely understand what you are looking for. More specifically, I don't understand what all you want the machine to do. It sounds like you have roughly 40 acres of pasture that you mow once a year to keep the brush and trees from taking it over. If that's the case, I don't understand why you're spending hardly any time looking backwards.
With 40 acres of pasture, you're only looking backwards when you are backing up which shouldn't be very often. A couple of big mirrors should do the trick for that. Yes, they get knocked around by tree limbs. Buy a pole saw and trim the tree limbs back. If you don't next year those limbs are going to be slapping you in the face. You also don't need to mow it every year. Mow 30% to 50% each year. Yes, it will get some brush and small trees growing over the course of 3 years, but it's good habitat and a bush hog will still make sort work of it. If you want to keep it looking better than that, rent it out for hay.
If you're only going to mow with the machine, a Kubota F series mower has the deck in the front, similar to an old Grasshopper. In the 90s I used to mow roughly 15 acres per day with one (F2100) and they are impressive machines. A couple of years ago I bought a used F2880 for the house. I have less than 2 acres, but I don't like to spend a lot of time mowing grass :) They are extremely durable machines, most are 4wd, and they are good for mowing wide open spaces but can also make relatively tight turns (not as good as a ZTR). Other attachments are available, including an aftermarket flail mower and cab (very $$$), but they are best suited for mowing. It would likely take 3 days to mow the 40 acres, but it would also do a fine job of mowing the other 5 acres depending on how many obstacles you're mowing around. Basically, you're buying the machine for the 5 acres, and then a flail mower attachment for the other 40. If you want/need and FEL, box blade, or an actual bush hog, you would need to buy an actual tractor for that.
/ Tractor Causing Stress on Neck #53
I put a set of cameras front and rear plus some good size rear view mirrors It works pretty good. you could probably put two cameras on the back to get a wider view.
/ Tractor Causing Stress on Neck #54
Just curious if Power Trac requires proprietary attachments. I'm a little familiar with them, but not enough to know what attachments they take. The Antonio Carraro tractors hook up to any regular 3 pt hitch attachment. I wanted the Carraro because they still offer a gear-drive transmission. They have the option of front and rear pto. My application might be different than other people's, but I do think those tractors have more potential than people give them credit for. Having said that, my intended use didn't involve a loader so that would factor into a person's decision on what tractor to purchase
/ Tractor Causing Stress on Neck #55
Skid steer with front mounted brush mower. Several iterations of such tools.
/ Tractor Causing Stress on Neck #56
IF I understand the post correctly.....the 40 acres you are having cut twice a year for hay.....but you choose to mow it after first frost anyway. I would ask WHY? Dont mow it after first frost. Maybe they can get first cutting of hay sooner....or even 3 cuttings a year?
/ Tractor Causing Stress on Neck #57
That's the question a lot of folks are asking... (y)
/ Tractor Causing Stress on Neck #58
Yes they use proprietary attachments mostly due to the quick disconnect from the seat. On a somewhat negative look, the attachments don't interchange between sizes, as it would be a waste of capacity to have a 65hp attachment on a 25hp machine.
For my 30hp and 65hp machines, I made adapters to go to standard skid steer and also the mini coupler as the purchase price of generic tools can be cheap from places like Titan where I bought my flail shown in previous post's pictures. Just an FYI, I have attached a pic of the PT to skid steer adapter I made.
If money was no consideration, I would have a A Carraro, but I fix all my own equipment and a hydro Italian tractor needs factory training to get in deep. The PT is just a pump and motor and easy to replace. Unfortunately only one range.
The first PT I bought for brush work about 5-8 years ago, was the PT180 for $5500 (before building back better). For that price could you walk into a John Deere dealer and come out with a new tractor with 4x4, power steering, loader w/quick attach?
The older PTs had a rear PTO and 3pt, but they found once you use the front quick attach, there was not much reason to use the rear 3pt. You can change a front attachment in less then a minute if no hydraulics, so why fumble with a rear attachment you cant see well?
/ Tractor Causing Stress on Neck #59
Sorry to hear of your neck troubles.
Get out the paper and pencil...
Let's say you find a decent condition tractor and 12' mower for $20K (ha! good luck, but we're optimistic).
Now compare that to paying someone $1K to mow once a year.
You could invest $20K at 5% and it would give you $1K in interest every year.
So you could keep your $20K and pay someone $1K every year for eternity and never have to mow it again ever in your remaining lifetime.
Or you could not invest it, and just pay someone to mow it every year for the next 20 years.
Or you could buy the used tractor and mower, pay upkeep, fuel, etc., do it yourself every year, and eventually sell the tractor and mower and recoup some of your investment after 20 years.
If your neck is that bad, I'd pick a hybrid combination of setting aside some money in a CD, using the interest and some of the principle to pay someone $1K each year for about 25-30 years.
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
Landhonor Quick Attach Adjustable Hydraulic Pallet Forks (A66408)
Landhonor Quick...
2013 WESTERN STAR  4900 SB (A65643)
2013 WESTERN STAR...
(4) Texas Built Stand Alone Livestock Panels (A66408)
(4) Texas Built...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
