Tractor Causing Stress on Neck
/ Tractor Causing Stress on Neck #21
More information about how many acres and the terrain could be helpful in offering suggestions.
A wider cutter that allowed the OP to cut in fewer passes at slower speeds would seem the better option than getting jarred trying to go faster with a more narrow cutter.
Maybe the least expensive option would be mirrors and/or a rearview camera/monitor setup.
It would be great if there was an inexpensive PTO driven front mount cutter just from the viewpoint of cutting brush instead of having to drive over it to cut it first, but I guess they don't exist in the USA?
But regardless, a really good seat would seem to be a priority.
Maybe 40 acres. With a 12 foot batwing it would take me two solid days to cut. Lots of rolling hills. Nothing around here seems to be level or smooth. I had a 90hp JD with an air ride seat which made things easier, but it did not swivel. As I mentioned earlier, I had mirrors but I would oftentimes get them knocked out of whack if I got too close to the trees, which was more often than not. I am currently tractor less, got rid of the JD and the batwing. I want something smaller. I like the MF setup with a front mounted PTO but I haven't priced them yet.
/ Tractor Causing Stress on Neck #23
A shield could be fabricated for the mirrors similar to the shields others have made for their taillights.
/ Tractor Causing Stress on Neck #24
OP, I feel your pain. Spine surgeon who fused my neck said a spine is like an old log chain. If you weld two chain links together, then the adjacent links wear even faster. Fast forward a few decades and a lot of time on vehicles with no suspension and it made mine worse, even without trying to crank my head around backwards.
Could you use a side mounted mower that doesn't require turning so far, like a sickle mower or flail mower?
I just bought a flail mower for my Grasshopper mower, but I don't think I can mow 40 acres with it. It will mainly be used to do the 5 or so acres around the house and in the tree canopies. Side mount is a possibility, but I would prefer something out front. I had JD demo their skid steer but after buying an expensive attachment to brush hog I just couldn't justify the price. May have to just find these young guys and let them do it.
/ Tractor Causing Stress on Neck #26
For me, the bobble-head effect that also hurts a fused neck is worse on short wheelbased vehicles, like my tracked loader and zero turn.
Good luck.
/ Tractor Causing Stress on Neck #27
If you had to spend the same amount of time driving in the best riding car as you would spend cutting 40 acres, would it still hurt your neck? Tend to wonder if the sheer amount of acres being cut is a part of the problem?
It shouldn't be since I'm really only doing it once a year. I'm trying to save my neck in the coming years. I don't want to compromise my ability to articulate my neck. The neck fusion was due primarily because I sat in front of a computer to many years. Now that I'm retired, I guess I should have picked a more suitable vocation (such as retirement living) instead of trying to maintain a large amount of land..
/ Tractor Causing Stress on Neck #29
Is it clean enough that you find somebody to cut hay on it? Then they would keep it knocked down.
Aaron Z
/ Tractor Causing Stress on Neck #31
Two neck spinal fusion surgeries here, C4-C5-C6-C7 all fused into one piece. Also a tumor removed from the base of my neck, and a lower spinal surgery just to round things out. I had to make accommodations, and they turned out well.
For one thing, I bought very big glass golf cart mirrors, convex ones, and mounted two of them butted together side to side just above my line of sight, underneath my canopy. If I didn't have the canopy I would have clamped a framework to my ROPS. I get really good vision straight behind and pretty far out to the sides.
For another thing, I put a third one of these mirrors above and slightly behind me. It's basically horizontal. It lets me look down on the 3PT, the drawbar, the PTO, and the backs of the rears. It's especially useful for lining things up while connecting, and also for pulling roots. I tilt my head back about as far as I comfortably can to use it.
Though, these don't sound as good to me as any of the front PTO or reversible tractor options. There was a NH reversible tractor which looked almost symmetrical front back (I don't think they make it anymore but am not sure), a pretty big sucker too, and videos I've seen sure look nice.
You don't want to be one of those people who wind up needing to have their neck removed. What an ugly ugly procedure, and an ugly ugly way to have to live.
/ Tractor Causing Stress on Neck #32
Looking for suggestions, if there are any. I've had 2 tractors in the past, both of them are gone now. I am contemplating my next purchase, but I fear there is no good solution. 1st tractor had a 6 foot brush hog and I found myself turning my neck way too much trying to keep the cutter in line with the last pass so as to not leave anything uncut. 2nd tractor was much larger with a 12 foot flex wing. I had mirrors on that tractor which helped, unless I got too close to the trees and it would knock the mirrors out of whack - so that didn't help much.
4 years ago I had neck surgery, so I've got a fusion already on 2 vertebrae in my neck. I'm not willing to stress my neck just so I can keep my fields cut. I already have them cut for hay twice a year, so the only time I really have to brush hog is once during the year after the 1st frost. I have hired out someone to cut in the past, but it costs me at least $1K every time, and that's if I can find someone to do it.
Ideally, it would be nice to have a setup where the cutter is on the front instead of in the back but I don't know of any US tractors that have a front mounted PTO. The other option is a skid steer, which would be nice, but they are extremely expensive as are the cutter attachments.
We are new to the farming community and I've talked to alot of the farmers around here and was surprised to learn many of the older ones have neck and back issues. I don't want to be another statistic, so I either need to find something that cuts in the front or pay someone to do it. Any advice would be greatly appreciated.
you dont look back very much except to check on the mower just every now and then..if the mower is making a noise,etc
your front wheels should be spread open while mowing so you should line up the mower by watching where one of the front wheels is depending on which way you are mowing..if you keep the mower serviced regularly to grease the fittings , especially the pto shaft universal joints, and making sure it has oil in it before each use,the mower should hardly ever have to be looked at while mowing..
/ Tractor Causing Stress on Neck #34
you dont need to look back very much except to check on the mower just every now and then..if the mower is making a noise,etc
also when mowing keep your hand close to the lift lever in case you hit something not seen like a piece of metal, brick,etc to quickly raise it up the second it whangs and bangs and tears up the blades,gearbox,etc...practice this by hitting the lift lever when the tractor if off and you close your eyes while going to the lift lever...one half a second or less to pull the lift lever to lift it quickly can save you a lot of money in repairs...i learned all this by having 329 years of mowing starting when i was a puppy...
/ Tractor Causing Stress on Neck #35
Antonio Carraro tractor with the reversible platform could be another option.
I can’t believe these tractors haven’t exploded in popularity here in the states. Small, tough, maneuverable, stable on steep hills.
I could literally build another business division cutting steep banks with one of them.
Have seen a few for sale at VERY affordable prices, but dealer support would be very difficult.
/ Tractor Causing Stress on Neck #36
Yep, you never know when you might hit something to bend a blade….
/ Tractor Causing Stress on Neck #37
I had the same problem with arthritis and long hours of forward/revers while using a rotary cutter and other implements. I tried numerous tractors starting with Steiner which ended up too small, no ground clearance, no lift height (I never tried the loader).
Then I moved up to a Goldoni reversible tractor, it was a gear drive and after all day, my knees hurt.
I then tried a Power Trac it is a hydrostatic articulated tractor with a quick attach loader and has a hydraulic PTO for dozens of implement, all on the front of the tractor. I liked it so much I bought three sizes (18hp gas, 30hp diesel {now replace by a 30hp gas} and a 65hp diesel). I use the 18hp with a rotary cutter in tight spaces and it couldn’t be better. They are low to the ground so very easy to get on and off yet the bottom is steel plate so you can use 110% of the ground clearance not like Kubota’s etc with delicate hoses and linkage to hit, even know it is much higher. I seldom use my conventional tractors much anymore.
If you’re interested I could tell you more about them.
/ Tractor Causing Stress on Neck #39
What would happen if you didn't mow once per year? Is the 40 acres still manageable when being cut for hay?
/ Tractor Causing Stress on Neck #40
I agree 100%. I was actually pretty serious at one point about getting an Antonio Carraro and putting a heavy-duty flail mower on it and do custom brush mowing. Maybe they would be a bit small for your application. They import up to 75 hp models. They have bigger ones but those arent imported due to emissions reasons. Those are the ones i really want. Also, check out their Mach 4 model. It's basically the same tractor, but a quad-track. In my mind, it's one of the coolest tractors in its size category.
Nearly all the Antonio Carraro models have the option of turning the seat and steering wheel around so you're looking out over the 3 pt/pto. The visibility is phenomenal.
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
