Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #7,781
Hello BalaamsJackass,
Having the rear tires loaded with liquid ballast will also help you tremendously.
Leonz, I don’t follow your advising to load the rear tires for a flail. Please elaborate. Thanks.
/ Let's talk flail mowers #7,782
Hey y'all, looks I just joined the flail mower Nation. Just bought this at auction on a whim. It looks to be in ok shape, but I won't know until I get it home just what needs work.
Can anyone identify it from this pic?
Thanks for any info.
/ Let's talk flail mowers #7,783
Hello Johnnyvol,
If it is the model I think it is, it is a John Deere 7 foot cut model 25A flail mower.
Parts like V belts and knives and bearings are still available so no worries there.
/ Let's talk flail mowers #7,784
Hello JethroB,
Increased stability on mild slopes and adhesion.
/ Let's talk flail mowers #7,785
The dealer near me is Kubota. They handle Land Pride. I'll ask if they also have Maschio.
I would probably run with rear door open to eject clippings, so no real need for the rakes.
I have a loader, but often mow without it so I can maneuver between fences & trees. Yes, it does make the front end light, but then I can turn sharper using the steering brakes.
You should ask your dealer if the front suitcase weight bracket without the weights
will safely clear the loader frame on your mule when lowered.
/ Let's talk flail mowers #7,786
Hello Crazzy450z,
I want to welcome you as the newest resident member of the Flail Mower Nations from
the great City of Guelph, and the Province of Ontario, Canada.
Use the Zetor for the flail mower.
Thanks for the advice..
/ Let's talk flail mowers #7,787
Hello I need help with a 917 drum has muilti holes how many blades per row do I need and where to place them? Right now it has 14 scoop knives per row its unbalanced. Its 5 ft not sure if its fine or corse cut Bought it used any help would be appreciated
Thanks
Mike Henry
/ Let's talk flail mowers #7,788
I really like my Maschio. I am grading areas on my place so that I can make more use of it. One thing about it is that you can cut areas so fast with it. I'm an advertisement for Maschio.
/ Let's talk flail mowers #7,789
You make a good point. I have graded areas so I can mow them better. I've removed surface rock and limbs too.
This year I started mowing for some neighbors. They could all use a little prep for next year when our mowing season is over.
/ Let's talk flail mowers #7,790
How's you're Maschio holding up? How long have you had it? What kind of blades? (1,000 questions!):ROFLMAO:
/ Let's talk flail mowers #7,791
Haven't bought one yet, but looking in the Land Pride FM2560 manual, it says don't sharpen your blades or replace one if it's broke, buy a whole new set. This is supposedly to keep from unbalancing the rotor. Also sounds like they want to sell some blades. I saw one guy who sharpened each blade and then weighed it.
What say ye? Do y'all sharpen your blades and replace broken ones?
/ Let's talk flail mowers #7,792
Time to sharpen all the hammers on my mower - Going to figure out an easy way to do this with lying on the ground. Initially thinking of lifting it with the bucket and a chain.
Hate to repeat a post i just made, but the Land Pride FM2560 (of which i ain't bought one yet) manual says, don't sharpen the blades. Also, don't replace a single blade if you break it, for fear of unbalancing the rotor, buy a whole new set. Sounds like they want to sell some blades!
/ Let's talk flail mowers #7,794
Thanks
Mike Henry
It sounds like it is a fine/finish cut from the number of knives per row. I would remove all the blades then run it to be sure the rotor is in balance and not bent. Then if that checks out add one knife per row back until you have it repopulated.
A fine/finish cut should have a total of 81 stations/places for knives, a standard cut 27.
/ Let's talk flail mowers #7,795
I have big 3 inch wide hammers. I replaced the whole set after the first year. Now I'm just sharpening them. 2 or 3 times so far. The result is no noticeable vibration. Just improved cutting.
/ Let's talk flail mowers #7,796
Just bought a Woodmaxx flail mower for my pasture! Can't wait for it to get here and get to mowing! (Currently chopping down little black locust trees and thistles with a nearly 30 year old Kubota G1900S ha ha)
/ Let's talk flail mowers #7,797
Got my auction find flail mower home today. It looks to be in pretty good shape overall, just a bit neglected. It needs a belt and the tractor side of the pto. Anyone know a good source for half, or is it best to replace the entire pto?
Can anyone confirm the model from this serial number tag?
Thanks
/ Let's talk flail mowers #7,798
Thanks
Mike Henry
Mr. Henry you have a coarse cut flail mower and it is unbalanced condition you may have a bad bearing,
you need to talk to a ford dealer about your flail mower.
/ Let's talk flail mowers #7,799
Thanks
You need a new complete PTO Shaft to cut it to the right length
/ Let's talk flail mowers #7,800
Mine is a Tigre 300 with hydraulic side shift. It's a 10' flail with hammers and not blades. It's holding up fine. I think I just bought it new last year, maybe year before last.
(2) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(2) 380/85R28...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A62130)
UNUSED SWICT 60"...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59909)
2019 FREIGHTLINER...
New/Unused Pallet of 5 Binders and 10 Chains (A61166)
New/Unused Pallet...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63118)
Greenworks...
