How would you fall this?
/ How would you fall this? #41
The guy says the top is 50' in the air. Ummmmm.......
I don't see where that was said.
I still think cutting at the base is the most dangerous. Even with clear escape route, too much uncontrolled happening at the same time. Those limbs could roll the log on you before you have a chance to move.
David
/ How would you fall this? #42
David
The top end is a good 50’ up in the air.
/ How would you fall this? #43
Agree with everyone about not judging this from a photo. Just like the pictures of steep land that does not look steep unless you can actually see it in person. You need someone in your area who knows what they are doing with trees if you are unsure.
I know of professionals who have died fooling with trees. Just be safe about it and again if unsure get in touch with someone who knows.
/ How would you fall this? #44
Hmmm, sounded like you said search remote tree felling on YT. Maybe I read it wrong.
Either way, the only thing more dangerous than a saw running in your hands is a saw running not in your hands. Let alone the damage that might happen to the equipment/saw if something doesn’t go according to plan and now your stuck with a damaged tree, damaged saw, and potentially no way to safely approach because you don’t know what happened with the tree. Seems like a really bad idea.
Thank you for explaining the risk of making things much worse if it doesn't go right.
/ How would you fall this? #46
Well - if your Cottonwoods are like those around here - it will rot off in a few years. If you are in no hurry - let it rot, fall to the ground - then take care of it.
I have only Ponderosa pines here. I've had a HUGE one tip over like that. I cleared a spot right at the base of the trunk. Made a chainsaw cut - at the base - about 1/4 way thru the trunk. Backed off and waited a couple day. Yes - the cut had widened slightly. I cut again - to make the initial cut deeper. Again - waited a couple day. Cut was widening nicely.
I just left it alone and in a couple weeks the top was tight on the ground. I cut the initial cut even deeper but NOT completely thru. I started chunking it up - from the top down to the base. Worked fine - little to no excitement.
/ How would you fall this? #47
My photo analysis was way off.
The top did not look 50' high and looked to me like I could drive near the end and whittle it down with my pole saw.
/edit - but based on counting pixels that would mean the log just over the "path" is about 7' in diameter.
/ How would you fall this? #48
2 comments. 1) DON'T cut from the top back. This unloads the root ball and it can catch you by surprise if it moves suddenly. Locally a farmer was cutting up a big old macrocapa tree (blow down) from the top when it dropped back into the root ball hole and threw him. His injuries were fatal. The coroner calculated the butt/rootball weighed 5 ton.
2) Hire a professional to cut the tree, you can finish the job once it is on the ground. Risk minimised.
I'm sorry but that's like saying you know someone who choked on a hotdog and died. Yes it happens but you're reaching for an excuse to have a nanny. There are a lot of things that you're leaving out of the story like where was his first cut? If he didn't cut from the top down obviously all the weight released at his first cut. Cutting from the top down MAY release the tension gradually and the ball stands up slowly, not at all, or still flops over quickly. There are a ton of variables but the risks can all be mitigated or if needed professionals can be called in.
/ How would you fall this? #49
Gotta see how it’s laying on the berm and what kind of clearance that you can make. Then make a cut location and method.
Probably cut near the base where the tree trunk is closest to the ground. Might consider cutting out wedges from the topside of the trunk to avoid pinching the blade.
Biggest thing is proper access and egress to the cut location And bar length.
/ How would you fall this? #50
This cottonwood pulled it’s rootball and leaned over. I say leaned because it’s roots and a whole lotta earth are still attached. Then about 12’ from that it’s resting (left side of pic) on a berm built as a range backstop. Then you see the rest of this up in the air still. It is not supported to any degree by the limbs. Most of them are barely making contact with the ground. its held in space like this by the rootball still attached to the earth on the side it hinged down, the weight of the earth attached to the side that came up and where the truck is resting on the berm. It’s a big green tree.
I think my plan is to clear out a spot on the back of the berm where I have lots of room to escape and work free of obstruction. Notch the underside about 8’ from the rootball. And then slowly cut from the top down towards the notch. At some point it’s gonna want to have the heavy top start to bend down to the ground and the weighted root ball snap back upright.
I don’t know that I want to limb the top as I don’t know how much pulling up the root ball is doing vs the weight of the limbs holding it down.
lotta energy stored in this mess. Anyone else have thoughts on approach?
Good plan.
So - yeah - to get the whole tree in frame I had to use the macro lens on the iPhone so it's a bit distorted I think. And - the tree is about 2.5 - 3' over the path there... your pixel math is off becasue the bottom line is "high" because I didn't mow the 5-6' tall grass down - so you are to the top of the grass - not the ground. If the limb infront of the target you see wasn't there - I could drive under this with the L4760 - and not be remotely close to the trunk. And while it looks like the trunk is supported somewhat by the links (because they are in the grass) - they are just barely touching the ground - the tree is held here by the trunk on the berm and the massive sized root ball still attached to the earth.
I'll post more pics when I get back down there to assess a bit more. We have a whole house generator going in later this week - so the priority is moving things in the basement where the panel is and doing some prep work where the generator will be located before install day Thursday.
That said - I do like the one idea above... notch less that 1/4 thickness of the trunk underneath at the berm. Then make a cut on the top maybe 4-6" in... and walk away - wait a few days - come back - see how much it opened up - make another little nibble - walk away - wait a few days... etc... AND that approach actually works in my schedule for this week!
Also a few guys were suggesting nibbing at the top with a pole saw... I think I might be able to hid behind some MASSIVE trees and pole saw at the top - so if anything went sideways - all that would be at risk would be the pole saw itself - and i can live with that.
/ How would you fall this? #52
I'd probably go with a 100ft of 6" wide semi sling strap and a heavy truck to pull with.
Tie on about 2/3 of the way up the tree and pull on it on a 90 degree angle driving down the existing path. Take it super slow the first couple pulls to see what it does, gradually increase the pulls until it twisted and laid flat on the ground. Then start digging out the rootball if needed.
No access with a truck - end of field in swampy area.
/ How would you fall this? #55
I'm retired, I'd take my time.
First of all - did you trim everything on the upside? Or did it grow that way.
I'd start at the top with chainsaw and pole saw. Cut a bunch away, haul it off, repeat. Keeping a clear path in case it moves. Trimming the branches back to clear 5' or so of stem at a time, then cutting off that part. And might put a good stout rope "down trunk" so if it stands up it would help cutting down more pieces.
If it "stands up" during the process I could easily get out of the way, then cut it at the base and have a rope to assist.
Take lots of picture or videos please.
I second this, this the way I would do it. Maybe it’s a retired thing, or experience.
/ How would you fall this? #56
First fill in the hole behind the root ball so the tree won't stand back up.
Then cut on the berm so the top falls to the ground.
@hslogger - I have doubts every tree I drop - probably why I have managed to not get hurt. I have ideas on this one - I just get extra wary anytime something isn't "clear cut" because of how much stored energy these things can have. And I always have a plan and a second plan for the third plan.
Case in point - we had a maple (maybe 18" at the base) that was right next to my wifes shed. Had a split trunk and was clearly not doing well...
Wide open space - easy hinge fall away from the shed. Ran a rope up to the top and hooked it on the tractor way out before cutting. My wife kept asking why are you doing that - you have dropped 100's of trees with no rope. I said better safe than sorry.
I cut the notch to hinge the tree over... and out of nowhere on a clear sky sunny day - the wind picked up. Not a breeze - like full on gusting. And of course it was blowing right up the field - into the tree - against my wedge cut - trying to push it over backwards into the shed... and becasue it was split - it was making progress...
Had her slowly drive the tractor away - and the split half of the tree came down where I wanted it - in the midst of a wind storm. Wind stopped - dropped the other side right on top of the first.
So - yeah - I'm always concerned cause of the insane things I have seen when people are dropping trees and not paying attention... Like an 8N chained to a tree going airborn when the trunk snapped and the rootball flicked the trunk back up like tent pole.
/ How would you fall this? #59
Cost you post a picture of the root ball. Be easier to give you a better answer.
/ How would you fall this? #60
I’d try a can or two at the base with a long fuse
CATERPILLAR GC25K STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR GC25K...
2018 Towmaster TC-16 10 Ton Tag A Long Trailer (A61568)
2018 Towmaster...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
1990 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 2J4FY29T5LJ516997 (A61165)
1990 Jeep Wrangler...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
