What kind of tree is this?
/ What kind of tree is this? #41
Someone suggested that Bois d' arc trees make good bows. Bois is wood in french, arc is bow; so the French knew what tree to use for bow making. Strong, everlasting, rot proof fence posts too.
This thread is both funny and a little scary. I think the O.P. might have a project way above his skill set, and it might not end well. Or maybe when he's finishes he'll be a master woodsman with some high end chainsaws and no serious injuries.
My goodness man, Sketchers Slip Ins for sawing up a thorn covered Osage Orange?!? What were you thinking? Put on some thick soled high top work boots!
I have learned my lesson. Didn't realize what kind of evil monster that tree was.
RSKY
Not really above my skill level. Definitely above the son in laws which is why I was there. I wasn't really going to cut as much down as I ended up doing BUT it happened. We ended up cutting and dragging about a dozen large limbs/trunks. Much more to do to clear that one spot.
/ What kind of tree is this? #44
Hope you'll post more pictures
/ What kind of tree is this? #46
Yeah, it's a long end game.
With that said, I planted several thousand trees back in 1989 and they're all over 50' tall and I'm still here. 🙃 (knock on wood).
I've never seen Hedgeapple trees that were 50' tall. Most of them are a tangled mess when they get about 25' tall.
/ What kind of tree is this? #47
A late friend of mine was a gunsmith, bow and gun stock maker. He used Osage Orange for his bows, and was famous for them. FWIW, back in our poverty days, we used the apples...cut in two...to kill the multitudes of cockroaches in our rented apartment.
/ What kind of tree is this? #48
Not that far from you and @MossRoad, I remember we used to have some huge specimens that were in the 50'+ range, 80-120 year old trees, based on the age of the houses around them. I think in the 1880s they were a popular ornamental tree in parts of the Midwest. I always thought they were a bit of a sleeper tree; no showy flowers, or scent, and then these cryptic fruit that suddenly were yellowish monsters.
All the best,
Peter
/ What kind of tree is this? #49
After cutting and disposing of hundreds of these things, I'm finally down to 5 in the pasture that are trimmed up to look like decent trees. Too big to cut down completely, but the ones I have left don't produce hedge apples for whatever reason. They can make pretty shade trees if you keep up with the pruning.
They are SO hard to kill. Any stump left will have new sprouts coming out of it and 5' high in a few months, even if the stump is treated with Roundup. The stumps really all need to be ground out, but unfortunately, I can't get to some of them with my grinder.
Pro Tips: Hedge chips make good mulch, takes forever to decompose. Use cheapo HF welding gloves to handle those thorny branches while you are chucking them into the chipper or burn pile.
That's interesting I have never seen any type of tree stump that could survive the straight roundup treatment when applied around the cambium layer right after cutting, but I have never seen one of these down here in the deep South, you learn something everyday.
/ What kind of tree is this? #50
We have a whole farm of them in western Missouri. We still have a huge one used for shade located where the old farm house sat and my Grandpa said it was the only thing worth visiting Missouri for (he was from Kentucky). Since we didn't have air conditioning in those days we spent most of the day under the tree.
When we first moved to the farm we heated with wood (Mom still does at 91) and we tried using hedge. It got so hot that we ended up burning the cast iron grates out of the stove. That was an expensive lesson. You can use it with a stove with fire bricks but you still need to be careful of the heat. It also tends to pop a lot so you need to have a screen if using in a fireplace.
My brother and his friend had a small business cutting fence posts from the thousands growing in the fence rows here. They make the best fence posts but you need to let them sit for a bit or they will sprout.
/ What kind of tree is this? #51
Tordon will kill them pretty reliably. My Mom spent many a day in the pasture cutting and painting them. If you do not apply it immediately after cutting you most likely won't kill it.
/ What kind of tree is this? #52
All the best,
Peter
This is a friend of ours house... the entire north side is osage orange. Huge trees, some well over 2' in diameter and 60+ feet tall. We know, because they fall on his yard every year.
/ What kind of tree is this? #53
Here are a couple that have been trimmed up to look decent.
The branches tend to curl down toward the ground, you you have to keep after them... As mentioned, stumps just keep re-sprouting, even after multiple Roundup applications. I think these things would survive a nuclear attack. Note that even the tiniest little sprouts already have thorns on them.
Even if you grind them off, the sprouts come up out of the root system that is left underground.
/ What kind of tree is this? #56
It WAS 3 days ago...hmmmm...
Hello, Mr. RSKY...hello...
May need to send for a wellness check...
OKAY, wellness check, no problems Saturday cutting on the devil's spawn tree. Problems started Sunday. Had to be packed out of church in the middle of the service. The nurse practitioner and hospital head nurse who were there both thought I was having a heart attack. I have never had any heart problems and none of my family ever has. They fed me nitro pills and aspirin until the ambulance got there. My wife said people were running out to the parking lot bringing in medical equipment out of their cars. Ambulance got there and took me the twenty-five or so miles to the hospital and by the time I got there my daughter who lives in another county and my sister who lives a 45-minute drive away were there. Wife said fifteen minutes after they carried me out and before they got to the ER a friend at a church on the other side of the county texted her asking how I was. Telephone, telegram, or tell a woman and the whole world knows. Preacher cut sermon short then song leader had to lead extra songs until the ambulance got out of the parking lot. LOL, when I cause a ruckus I cause a good one. By the time they got me to the ER there were prayers being said in five churches for me. And I don't even know any of those people.
They let me go today. Doctor said heart tests showed a perfect heart except for one small common problem that even he had and was not serious. So they think this may have something to do with my ear problems. I don't know. Church was cold, I had sweat running off my face and elbows, shirt was soaked. I couldn't talk. Had nausea, had vertigo, couldn't stand up. Daughter and wife said my face and arms were dark grey. In the ER and before admission to the hospital everything cleared up. After admission I had two smaller episodes that day with problems with my vision. Everything I looked at bounced up and down. Anybody experience anything like that?
Guess I will have to leave the devil's tree alone until I find out what this was.
RSKY
/ What kind of tree is this? #58
I suddenly started having BPPV (Benign Paroxysmal Positional Vertigo) about five or six or eight years ago. If I put my head in a certain position (for me, tilt far back and turn to it to the right like I'm trying to look at the ground right behind my shoulder), the world will start spinning like I just drank half a bottle of port and inhaled way too much of a cigar (specific example because that happened once. once. never again. sorry to the neighbor's bushes). Good thing is with BPPV there's a way you can reset the issue so the vertigo goes away; I still feel a bit queasy for a few hours after. Also good thing is I know how to avoid it so it only occasionally happens, most often when I'm stretching on the floor.
I wouldn't be surprised if you might have the same thing. Read up on "epley maneuver" just in case it happens again so you can reset before you go to the ER again.
/ What kind of tree is this? #59
RSKY
Well, I'm glad the tree didn't get you. Not sure of what condition you may have. Clearly a circulatory issue, but good to know the engine is clean.
/ What kind of tree is this? #60
Wow...wow...wow!
What's the next step? Sounds like something serious to find the root cause.
Any thing you're allergic to, or possible food poisoning?
Preliminary Listing / Full Catalog Coming Soon! (A60462)
Preliminary...
(INOP) KUBOTA SVL75-2 SKID STEER (A60429)
(INOP) KUBOTA...
UNUSED KJ K4020-40' X 20' STEEL CARPORT SHED (A60432)
UNUSED KJ...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
FORD 3000 TRACTOR (A60430)
FORD 3000 TRACTOR...
(15) UNUSED 8'X41' PROTECTION MATS (A60432)
(15) UNUSED 8'X41'...
