Water Heater Trips Breaker,,, HELP!!,,,??
/ Water Heater Trips Breaker,,, HELP!!,,,?? #21
I got a wood stove, so I can make my own hot water - not fast, but I can if need be. So I elected not to hook it up.
You gotta think outside the box sometimes. :)
/ Water Heater Trips Breaker,,, HELP!!,,,?? #22
a generator is a luxury, I have no idea why the water heater is where you draw the line, hell a hand water pump for the well doesn't need electricity and you can go buy a big block of ice for refrigeration. don't forget the candles for lighting....
sometimes you just need to think outside the box.
/ Water Heater Trips Breaker,,, HELP!!,,,?? #23
That will be nice when it's 90 degrees.
/ Water Heater Trips Breaker,,, HELP!!,,,?? #24
I'm a believer so I'll be replacing my propane water heater with an electric and putting it on a genny. Can't take a chance on being out of propane and catching flu.
/ Water Heater Trips Breaker,,, HELP!!,,,?? #25
The easy way is do as pros do (not plumbers ) test amp draw.
why would you say ''not plumbers'' ? I have tested many water heaters with an amp meter in my day. HVAC systems too !
/ Water Heater Trips Breaker,,, HELP!!,,,?? #26
You are right of course, I just can't help worrying about how long ice will be available in the zombie apocalypse.
/ Water Heater Trips Breaker,,, HELP!!,,,?? #27
Yes, bad elements will trip breakers. Breakers are heat protected. If calciuum buildup is enough, wire load will increase, ie more heat. Thermal breaker will trip.
more than likely, no one replaced anode either.
personally, id replace entire thing if its real old.
/ Water Heater Trips Breaker,,, HELP!!,,,?? #28
I am using 1 I put in 1980, half a dozen elements since. Another 2 gas from the early 90s.
/ Water Heater Trips Breaker,,, HELP!!,,,?? #29
Had a woman ask,,, would her son be able to tell whats with her heater. He was out of town for a day or 2 and was concerned about calling the local knob. Son is lic master spark unlimited, think he has taken every test they have.
/ Water Heater Trips Breaker,,, HELP!!,,,?? #30
Would you translate this for me, please. I assume that since we're talking about water heaters, it has something to do with gas, but beyond that I haven't a clue as to what you're talking about.
/ Water Heater Trips Breaker,,, HELP!!,,,?? #31
What's "real old"? I've had them last 20 years, then 15, then 10, all in "soft water" areas.
Are they getting like tires? Planned obsolescense?
/ Water Heater Trips Breaker,,, HELP!!,,,?? #32
I miss the old Hoyt all copper 20 and 30 gallon gas fired water heaters ..
Made in Oakland CA for generations until moved to Reno NV and then vanished...
/ Water Heater Trips Breaker,,, HELP!!,,,?? #33
What’s this generator luxury you all talkin about?
/ Water Heater Trips Breaker,,, HELP!!,,,?? #36
I installed a water softener in my home 40 years ago, so I have not had a reason to replace heater heater elements,,
My daughter's home has a typical 2-element electric hot water heater, probably 4500 watt elements, 240 volt, ~50 gallon,,,
Yes, she has high calcium water, no water softener, the elements surely have buildup on them.
Anyways, both elements show resistance, so they are not burned out,, as far as electrically concerned.
BUT, I do hear the water heater "growling" when the heater has to heat water. (Calcium buildup, I assume)
I know the elements need replaced, I have the "LOW DENSITY WATTAGE" version elements to replace the ones in the water heater now.
My real question is,,, "Hmmmm, the circuit breaker will trip occasionally!!"
Would calcium buildup cause the circuit breaker to trip, ?? OR, would the tripped breaker be do to some other issue??
Thanks for the help.
I
Calcium builds up on element takes current to heat water. More current degrades the heating element. Once degraded enough it will short to ground. Some heaters use to have anion rod in center to keep build up on elements. Some swear by it others do not. In soften water element will fail faster over time. I use to run 240 v timer on my electric water heater. Setting times for use during the day. Otherwise unit will run as it pleases. This extended my element life from 2 years to 5 years. Reduced electricity costs and gave access to the bathroom on off hours. Who wants a Luke warm shower. Wife forced me to install lp gas water heater then I was waiting to use the bathroom again.
/ Water Heater Trips Breaker,,, HELP!!,,,?? #37
Soften will not fail as fast much longer period of time before element replacement. Needed to restate this.
2016 Toyota Camry Sedan (A61569)
2016 Toyota Camry...
2018 RoGator 1100C (A63118)
2018 RoGator 1100C...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
FORD 8630 POWERSHIFT TRACTOR (A62130)
FORD 8630...
