What To Use For Front Shields ON Brush Hogs?
/ What To Use For Front Shields ON Brush Hogs? #21
Used round hay baler belt.
/ What To Use For Front Shields ON Brush Hogs? #24
On a brush cutter? Good luck with that. It's a brush cutter, it will make dust regardless of the type of shield used, unless there is a lot of moisture going on on the brush and ground. If it creates enough dust to become unbearable, then the cutter most likely just digging into the ground and needs to be setup better. Or get a cabbed tractor if none of that is enough.
I understand that. Been doing this a while.
Cutter is not "digging" into the ground. It is set properly.
The issue is that without any type of guard on the front, my JD brush hog shoots a huge amount of very fine cuttings and dust out the right front of the cutter (right side as sitting on the tractor).
The main problem is that this stuff then goes straight up between the right rear wheel and seat so you get it all in the ear and side of your head.
With a guard a lot of this will deflect back under the cutter and also to the ground.
My actual question was about what others have used to make a front guard. Just looking for inexpensive options rather than the pricy guards from the manufacturer.
/ What To Use For Front Shields ON Brush Hogs? #27
Chains will handle this
/ What To Use For Front Shields ON Brush Hogs? #28
My new Landpride cutter came with rubber belting on the front.
/ What To Use For Front Shields ON Brush Hogs? #29
Understood. However, you don't need to buy the overpriced stuff from the manufacturer. I say for less than $100, you can have a chain skirt both at the front and back of the mower looking as nice or even better than the factory one.
/ What To Use For Front Shields ON Brush Hogs? #30
We use pieces of old John Deere hay roller belts.
20704 (A55853)
20704 (A55853)
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
(4) Dura Trench Drain Grates (A60463)
(4) Dura Trench...
2022 Kubota SVL97-2 (A60462)
2022 Kubota...
Freightliner Columbia (A61307)
Freightliner...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
