Hooks on FEL Bucket
   / Hooks on FEL Bucket #61
Center for light weight, two in-line with the loader arms for the heavier loads
The two in line with the loader arms are used in conjunction to spread the load
We keep an 8' chain to hook on each corner and that always puts load on the corners. Never even tried a center hook. Last thing I loaded was a 14' disc that an oil field man wanted to use. Used two tractors and backed the trailer under it. I do have a hitch ball in the center of one for moving goose neck trailers. Sometimes we have a couple sets of scaffolding on a trailer with people on it working. Easier to negotiate that way.
   / Hooks on FEL Bucket #62
The back to back hooks confused me a bit. The only thing I could think to do with it right off the bat was shorten a piece of chain. Which is apparently what it does! But I don't know if i'd make any use of it if i already had chain hooks on my bucket (which i do, on one at least). I guess its just more universal because it can go with the rest of the chain wherever you use it, unlike bucket hooks. But anyday i learn anything about rigging is a good one because im bound to do enough of it yet in my life that every trick i learn will eventually be made use of.
   / Hooks on FEL Bucket #64
Something that is useful that some scoff at is back to back hooks...
That's what I use. I have 2 that store perfectly on the loader arm. 9 links of 5/16 chain hooks on the flat steel on the bucket top
   / Hooks on FEL Bucket #65
Reminds me of this:
I use a old set it passenger car tire chains to act as a "chain cradle" coupled with regular chains to hold really odd shaped objects ....
EDITED FOR CLARITY: I use the set of old tire chains to cradle/basket large awkward objects in stead of a single chain around around object as shown in picture....
   / Hooks on FEL Bucket #66
No I mean the 2 hooks connected end to end, the guy in the vid uses them on his Kubota with the curled-back upper lip of the bucket. I guess that's how Fladogman up there uses them.
   / Hooks on FEL Bucket #67
You're right, the MX bucket has a big flat iron top for extra support, they clip on and hold nicely. I was concerned about them sliding but haven't experienced them doing so. It's nice not having those hooks to grab limbs when clearing land. My dad welded hooks on his bucket and they grab vines and limbs.
Do the L and BX models have a reenforced top on the bucket? If not this method may no be a good option
   / Hooks on FEL Bucket #68
And you misinterpreted my post about using tire chain as a cradle.
   / Hooks on FEL Bucket #70
As far as the bx, I don't think so. That's why personally I'd be real careful doing this if I had one of those, only them for lightweight stuff. I got a massey ferguson, I got hooks on the bucket but never snagged anything on them which I didn't want to.
   / Hooks on FEL Bucket #72
Bolt on hooks - bolt on tooth bar.
   / Hooks on FEL Bucket #73
Recently someone posted about two hooks on a short chain. That seemed like a great idea and since I already had a short chunk of chain and some extra hooks I made one up. Then the next day I used it to shorten a long chain. Very useful. I can't believe the idea never occurred to me, especially since I have been using chains for about 50 years or so.
Eric
   / Hooks on FEL Bucket #74
I too made a couple chain baskets from old tire chains. Just for moving big rocks. They work very well.
Eric
   / Hooks on FEL Bucket #75
One of the most productive things I have done was to haul my bucket 25 miles to a weld shop to get a couple of hooks welded on. After watching it being done, I concluded "I can learn to do that!"
I bought a welder and taught myself. I've done many projects over the years, from farm projects to tables and display racks. I'm sure glad I had those hooks welded on!
   / Hooks on FEL Bucket #76
Actually.... You could use the ovals...
The ovals will work, thanks for the tip. Found a picture of the backside that shows the oval holes:
Tried DL Meisen's idea of putting the no hook end through the oval hole in the SSQA:
Works gooder-un, gonna be real handy (y)
   / Hooks on FEL Bucket #77
Interesting to see the different thought processes
   / Hooks on FEL Bucket #78
I think one of the big things about a chain hook is that since you can hook it anywhere on the chain, you can set the length more easily than if you had a large hook or ring where you would have to double your chain back and hook it to itself to shorten it. Or if you have a bare chain or chain with hook on only one end. I think it's useful to have chain hooks and one larger hook/loop/d-ring etc.
Also, for those with a sturdy enough bucket, i swear these things from harbor freight are by far the cheapest piece for sale that gives you the functionality it does. ATV Hitch Adapter
It gives you the 2" receiver (which also lets you just run a pin through a chain link fed into the receiver), a large and sturdy hoop/loop, can be bolted OR welded, or if you turn it backwards you also get a clevis pin hole. I have it mounted backwards on a 3pt a-frame on my Case garden tractor and most 2" drawbars will still go into it from the bolt hole end. I shaved that end down a bit on mine since some of my drawbars would not fit into it from that direction.
In my case having the bolt hole end sticking out is mostly to pull pin-type attachments for garden tractors, but you could also put a shackle through it just as easily.
Could also mount it upside down beneath top bucket lip if you had a reason to. It puts in a lot of good work for $11.
I have one on my tractor and it is super handy. Use it for light loads with the welded ring. You can slip in any normal shank into it with whatever you choose on the end. Makes it great for moving trailers as you can just pick it up without ever getting off the tractor.
   / Hooks on FEL Bucket #79
If I recall welding hooks was my first mod on my CUT.
No, sorry, my DIY cab won first place and it went on from there, followed by heat, LED's back up camera, pusher front blade, electric chute rotator and it seems never to stop.
LOL, keeps me busy!
   / Hooks on FEL Bucket #80
Another thing it brings to mind is something i may have done temporarily at one point and then taken back apart.. but you can pin a 'clevis' hook directly to an 'eye' hook and just make a double ended hook with no chain in between.
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
DEUTZ MARATHON...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
