Hooks on FEL Bucket
   / Hooks on FEL Bucket #41
This idea isn't for everyone but for repetitive lifting, I use this SSQA to 3pt adapter. Assuming your tractor has a FEL with SSQA, it takes just a minute to drop the bucket and install the adapter:
It's certainly more $$ than weld or bolt on bucket hooks but it serves a dual purpose. I bought it years ago to use 3 pt implements on the FEL. I found it works better for lifting than using bucket hooks. Without the weight of the bucket, the FEL lifting capacity is increased. The lift point is closer to the pivot pins as well. I find I get 200+ pounds of increased lift over using the bucket with my LA1055 FEL.
For center point lifting, I use a clevis mounted on a short piece of 2" square tube in the adapter receiver. For two point lifting, I use pins on either side of the adapter.
BTW, the adapter is available on Amazon for $100 less than the Titan price.
   / Hooks on FEL Bucket #42
B26 HD bucket.
   / Hooks on FEL Bucket #43
Talking hooks. Who and why would you choose one style over the other? chain grabbing hooks or just regular ,car towing, type hooks? I can see advantages to both.
   / Hooks on FEL Bucket #44
Depends on your rigging equipment. Shackles, wire rope or synthetic straps don’t fit chain hooks. Good to have options. Wrong rigging can easily be damaged or severely strength comprised.
Simple holes in the side cutting bars of a bucket for a shackle works great. Stronger part of the bucket.
   / Hooks on FEL Bucket #45
The SSQA on the V417 has chain slots:
   / Hooks on FEL Bucket #46
I use two, and use something off the center for heavy loads. Use the lifting tongs to hold logs off the ground for bucking. Weight stays in the middle.
This was just a glamor photo, lol.
   / Hooks on FEL Bucket #50
Why not just make a short section of chain with a tow hook that would fasten to the bucket chain grab hooks for those times when you lifting with things other than chain?
   / Hooks on FEL Bucket #51
   / Hooks on FEL Bucket #54
Actually.... You could use the ovals...
There are on sides of my FEL bucket, took a while to figure out what they were for........
   / Hooks on FEL Bucket #55
Good idea, I will look on the backside to see if it is flat.
That would be perfect for the chain in the picture since it only has one hook (y) .
   / Hooks on FEL Bucket #56
I think one of the big things about a chain hook is that since you can hook it anywhere on the chain, you can set the length more easily than if you had a large hook or ring where you would have to double your chain back and hook it to itself to shorten it. Or if you have a bare chain or chain with hook on only one end. I think it's useful to have chain hooks and one larger hook/loop/d-ring etc.
Also, for those with a sturdy enough bucket, i swear these things from harbor freight are by far the cheapest piece for sale that gives you the functionality it does. ATV Hitch Adapter
It gives you the 2" receiver (which also lets you just run a pin through a chain link fed into the receiver), a large and sturdy hoop/loop, can be bolted OR welded, or if you turn it backwards you also get a clevis pin hole. I have it mounted backwards on a 3pt a-frame on my Case garden tractor and most 2" drawbars will still go into it from the bolt hole end. I shaved that end down a bit on mine since some of my drawbars would not fit into it from that direction.
In my case having the bolt hole end sticking out is mostly to pull pin-type attachments for garden tractors, but you could also put a shackle through it just as easily.
Could also mount it upside down beneath top bucket lip if you had a reason to. It puts in a lot of good work for $11.
   / Hooks on FEL Bucket #58
Bend your bucket picking up in center. Corner is stronger.
Center for light weight, two in-line with the loader arms for the heavier loads
The two in line with the loader arms are used in conjunction to spread the load
   / Hooks on FEL Bucket #60
The ovals will work, thanks for the tip.
Found a picture of the backside that shows the oval holes:
2015 Vermeer MX125 500 Gallon Drilling Fluid System T/A Trailer (A59228)
2015 Vermeer MX125...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2014 International Maxxforce DT (A53317)
2014 International...
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
