Oil & Fuel New to me YM2500
/ New to me YM2500 #1
Brokeodie
Member
Yanmar ym2500
Hello everyone,
Glad I came across this site as there is Soo much valuable information. I recently purchased a YM2500 that has been sitting outside and not started in almost two years. This being said I'm having it winched on a trailer and brought to my house as i figured it would be best to change the fluids before starting. Am i being over cautious? What all should I change or check before attempting to start it? I did read that they are known to have water trickle down levers and what not so want to avoid damaging anything.
Any help would be greatly appreciated and thank you in advance.
/ New to me YM2500 #2
Welcome!
My YM240 had a similar history when I bought it. My only advice is be sure to use the compression release every time you crank it, so if there is water or something in a cylinder, you don't bend a rod. Aside from that, just the obvious cleanup, fluids replaced, maybe buy a battery.
Parked 2 years didn't hurt it. For me I would be impatient and drive it around a little before doing the 'annual service' it needs.
Normal starting procedure is get it spinning with compression released to get some oil pressure then drop the release lever, the inertia of the flywheel will assist the starter.
/ New to me YM2500
Welcome!
Thank you so much for that info. Is there any particular engine oil you find works better? Also what do you use in the transmission?
/ New to me YM2500 #4
For motor oil, any diesel rated oil. Match the viscosity to your ambient air temps. There will forever be the ongoing arguments over 15w40, 10w30 and other weights of oil, as well as the debates over full synthetic vs semi synthetic vs non synthetic. Personally, I believe a good quality oil based on tract record by brand in a diesel rated oil changed regularly is the route to go and your choice on the rest of the debates.
For hydraulic/transmission fluid the newest standard is j20c.
After sitting for 2 years, I would change both of these and clean the hydraulic screen and replace filters.
Also drain fuel, change fuel filter, and bleed the fuel system.
If 4x4 change front diff fluid watching for 3 drain plugs, 1 at each wheel and 1 at the pumpkin. Most call for 90w gear oil.
Hoye tractor and Fredrick’s are both good resources for parts and info.
/ New to me YM2500 #5
Buying a tractor with unknown history I think its important to clean the hydraulic 'strainer' (mesh) and I think you have a screw-on hydraulic filter too, that should be replaced. Get the right filter for that, designed for hydraulics, not for motor oil.
I would also put in a new fuel filter. After you have done this I don't see a need to replace the fuel filter for years. We don't have the contaminants in fuel that might be encountered in some parts of the world. YM240 Owner Manual says replace the fuel filter more frequently if fuel generally has more than a tablespoon of debris or water per fill up! I can't imagine fuel like that. Maybe stuff from 50 gallon drums in the outback or rural Alaska.
If you're reasonably sure this tractor was in use before that 2 years parked, then I don't think it needs 'major restoration' - fuel flush etc. Just check that all fluid levels are ok, start and enjoy it. Do 'annual maintenance' - replace coolant, lubricants - etc soon only so you have a known starting date for your periodic maintenance.
/ New to me YM2500 #6
Per Yanmar
Your YM2500 painted JD green would be a john Deere 850. So, the same oil info is listed here
Hydraulic fluid is Yanmar TF500A, hard to locate around the county, yet John Deere J20C and brands that are 'equivalent' would work, not compatible.
/ New to me YM2500 #7
Before starting, first verify IF any water had gotten into the engine via the exhaust pipe. Water damage like this can lock up the internals of the engine in rust. Should you try to start the engine, so much damage can be had.
So, 1st and foremost, verify the exhaust side of the engine inside is not rusty.
/ New to me YM2500
Thank you everyone for your assistance, so i did check the tractor and was able to turn it over replaced fluids and changed out Fuel lines as well as bleeding the fuel system. So the tractor turns over but it's not wanting to start. I'm not sure if there is enough fuel coming out of the ports. Looked for videos or information on how much fuel is supposed to come out. Ordered injector puller to see spray pattern and verify. If this is good i guess compression test is next? Fyi this is my first diesel to try and fix.
Thank you
/ New to me YM2500 #9
Thank you
Two quick questions;
1) Do you have a decompression lever? (And are you turning it off once the engine is spinning?)
2) Is fuel coming out of the fuel fitting at every injector?
All the best,
Peter
/ New to me YM2500
Update:
So tonight the tractor started up after turning it over for a bit but turns off as if It has no fuel. Thinking it's the pump and will be sending it off to get looked at.
Will keep you posted.
/ New to me YM2500
Update:
I sent off the pump and injectors to "ThePumpGuySC" his turn around time is incredible. He tested the injectors and they were no bueno so they needed to be purchased. Mike was able to get pump sorted and working and have it back two me in less than two weeks (Most of it shipping time). I did order the new shims, insulators, and injectors and they arrived the same day and have been put in. The timing gasket was in rough shape so I used two shims that were about the same thickness (no I did not measure it) and put it all together. I put the injectors in and hooked up all the fuel lines, return lines and tightened it all up. I was able to bleed the fuel system and make sure there was no air coming thru. I turned over the tractor and after a few seconds it STARTED!!! I let it run but noticed that the oil light was on :( so it was time to throw more parts at it. I went to O'Reilly and they had one that matched exactly that was off of a 1978 Subaru Standard (Thank you to the this forum). I did install the sensor and it worked no more light (Phew). The tractor is running and I am able to lower the speed but it seems like it shuts itself off at low idle or if I press the accelerator and release. could this be a timing issue or some other adjustment that needs to be done?
thank you everyone in advance
/ New to me YM2500 #12
I'm thinking your 2500 is pretty much identical to the John Deere 850. If so, you might need to make an adjustment at #32 locknuts and also check and make sure your idle spring and ball are in place (#4 & 5). Then might need to adust locknuts #23 with a little more tension.
the action may be reversed on your 2500 but setup should be very similar. Or at least I think so.
/ New to me YM2500
Ok, thank you for that Winston1 i will take a look and see what I can find out. So another thing I noticed is that the 3point went up but it's not wanting to go back down. I made sure that the lock was turned fully counter clock wise. Does it matter the rpms or should it go down if the tractor is off? Also should the pin fully extend and touch the lever? (See attached photo).
Sorry for the basic questions as this is my first tractor.
/ New to me YM2500 #14
Winston, you are so correct. The YM2500 and YM2610 both have the same throttle control to the 3T80 engine. There is an idle detent that tends to slip at time. When the engine is set to 1400rpms or less and it slips back to the idle detent, then it needs a bit of readjustment.
The odd thing is, the John Deere machines get a butterfly pivot lever between the two linkages. This in turn makes the lever for RPM control pushed in the other direction. John Deere wanted all their machines to behave all the same, both domestic and imported. And now you know the rest of the story, Good day. :)
/ New to me YM2500 #15
Hmmm, where is that little shiny lock pin located? It might be on my machine too. I just never paid any attention.
I know about the under seat tiny lever like this spot. Mine has to sit in that position, else it will not go up or down, depending what way it's flipped.
And there their is the HARD LOCK stop to the 3PT found here
/ New to me YM2500
Hi bmaverick so in the first picture you have it's under that metal shield you have. I guess mine did not come with it. Follow the spring. I will try moving the two levers as i was playing with them but could not find any documentation on them. So I was able to put it at 2200 rpms and drive around a bit. I will post an audio clip as how the motor sounds and you can tell me if it's normal.. Also i noticed the front loader stutters a bit during operation and the pump or something makes what sounds like a whining noise.
/ New to me YM2500
So I decided tonight to drain the hydraulic fluid and the milk shake did make me sad.. So apparently there is water in the system that i will now have to get out. I did read on some post to put diesel, ATF F, and alcohol into the case and run the tractor but not run the pto etc and I've also read to just use diesel and run all pto, lifts etc. Anyone have the best way of removing the water and starting over?
/ New to me YM2500 #19
NO, please no alcohol in the system. ATF+4 is the go to on these Yanmar/John Deere compacts. And the newer 'clean' diesel works nicely now as it's low sulfur.
J20C is the mainstay Hy-Gard fluid to use. IF you live in higher elevations or harsh winters J20D is the formula to use.
Bummer about the milky white fluid. It would take 2 or 3 rinses to purge. Possibly more. Thus the 'clean' diesel of today is the most cost effect method.
Your YM2500 should be identical to flush and refill. See my posting here
/ New to me YM2500 #20
Congratulations on getting the fuel side of your tractor sorted out!
As disappointing as it is to find a milkshake, be thankful that you did the change now. (Pat yourself on the back for doing it sooner rather than later!) If you found a lot of gunk on the filter, you may want to work at getting any sludge up of the bottom of the tank before refilling it. (Compressed air, rags, whatever it takes.)
Yes, it is a shampoo, rinse, repeat sort of thing, and do operate everything a couple of times to flush things out, but not under any load. Personally, I have never used diesel to flush a hydraulic system, and I would never add alcohol. I would just stay with a J20C fluid. Around here at Tractor supply, it is only about 1.6x diesel in cost anyway.
All the best,
Peter
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2005 INTERNATIONAL 9400I (A67714)
2005 INTERNATIONAL...
Unused 2026 Schulte SMR-800 Hydraulic Multi-Rake Skid Steer Attachment (A66734)
Unused 2026...
2012 PROCO 130BBL VACUUM TRAILER (A67714)
2012 PROCO 130BBL...
2018 Komatsu D51PXi-24 Crawler Tractor Dozer (A66734)
2018 Komatsu...
2015 Ford F-250 Knapheide Service Truck (A66736)
2015 Ford F-250...
