2008; 3510 (New Sheet Metal) 4WD Lever Leaking HYD Fluid
   / 2008; 3510 (New Sheet Metal) 4WD Lever Leaking HYD Fluid #1
TheRetiredBear
2008 Mahindra 3510
Hello You'll,
I noticed that my 4WD Shift Lever is leaking (pouring) Hyd Fluid from where it enters the Sump. After consulting with my local Mahindra Dealership Service Dept, I was informed of their backlog and the lead-time to get it looked at/worked on.
One of the Serviced Technicians stated it was a fairly simple repair being it was most likely the O-Ring (he stated just a typical one). He did say to pay attention to the "detent" ball.
Is anyone familiar with this repair or know anything about it? It seems pretty straight forward but, I don't want to damage anything or cause further delay in getting my tractor back in ops.
Thanks in advance . . .
   / 2008; 3510 (New Sheet Metal) 4WD Lever Leaking HYD Fluid #2
I'm no authority on your tractor but from what I see the "fix" for your leak should be relatively straight forward. I would think most anyone capable of handling a wrench could do it. Drain the fluid, then disconnect the shift linkage rod. Remove four M8 bolts and the shifting unit in question will slip out of the main case. Remove one roll pin and the pieces involved will separate. (pay attention to the "detent" ball and spring at this point) The O ring in question is Mahindra part number V7201024014. Mahindra lists it for $3.00 Can you handle that?
Harry, Thank you for the part number. I ordered a couple of the O-Rings from my local dealer and when they come in, I'm going to give it a shot. Gonna put down a white sheet to catch any parts I may drop.
   / 2008; 3510 (New Sheet Metal) 4WD Lever Leaking HYD Fluid #4
While the oil is drained would be a good time to pull and clean the hydraulic suction screen. It's only a few inches away from the shift lever housing. Looks like pear shaped flange with one bolt holding it in place. Since you'll be washing parts anyway......
KENWORTH ROLLBACK TOW TRUCK (A57192)
KENWORTH ROLLBACK...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55314)
2024 BCL...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2019 WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2019 WACKER NEUSON...
TANK MANIFOLD (A55745)
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
