Trailer Lights Gurus--Got a Question.
/ Trailer Lights Gurus--Got a Question.
Go back a reread some of the posts he was replying to, and what he replied with. Pretty sure this never said the actuator is on the truck:
Come on guys. Give it up. :)
/ Trailer Lights Gurus--Got a Question. #82
There is only one wire besides the ground wire. So the signal for all the functions has to go thru that wire. Right?
Also on LED trailer lights I think it is the number of LED's that are lit to distinguish between the various functions. (dim and bright, blinking etc)
I understand the seperate filaments in incandescent lights but, again, how the signal for seperate filaments is sent thru the one wire. (different voltage?)
4 wires there should be!
/ Trailer Lights Gurus--Got a Question. #83
The tail-stop-turn trailer lights I've seen with 2 wires were grounded with the mounting bolt. One wire was tail, the other was stop-turn.
Bruce
/ Trailer Lights Gurus--Got a Question. #84
U keep saying, "1 wire." I dont get that. What 1 wire are u talking about. Mine has 4: 1 ground, 1 for running lights, 1 for left turn/ flas/ brake, and 1 for right turn/ flas/ brake.
Yes, four wires at the connector. White is common or ground, brown is running (tail) lights, yellow is left side flashing and green is right flashing. My trailer harness has just the two wires going to each light.
Bruce
Hmmm. Maybe now we're getting somewhere!
/ Trailer Lights Gurus--Got a Question. #87
I see 3 on those units in the amazon picture. White is gnd, low brightness is the brown on your connector (running), high brightness is the green or yellow on your connector (turn/flash/brake)
/ Trailer Lights Gurus--Got a Question. #88
Another concern is there are two other colored wires in addition to the white wire on each light. The diagram below shows the two colored wires attached to seperate leads. My trailer just has the white wire on each side plus a colored wire so I spliced the two colored wires of the light together with the colored trailer wire at each light location. Maybe this is incorrect but not sure how else one would do it.
Hook the Brown wire to the Black wire on the LEDs. This is your 'running lights'.
Hook the Yellow wire to the Left LED's Red wire. This is your Left Stop/Turn.
Hook the Green wire to the Right Led's Red wire, this is your Right Stop/Turn.
White wires from all lights then go to ground, either chassis (can be via mounting bolt. On your LEDs its a White wire.) or directly to the white wire on the plug (preferred).
The confusion is the number of wires at two different places. You're talking about at the vehicle/trailer connector, right? Yes, four wires.
The one wire I mention is in addition to the white wire on the trailer harness at each light location.
/ Trailer Lights Gurus--Got a Question. #90
I see 3 at each light?
/ Trailer Lights Gurus--Got a Question. #91
If you only have two wires you only have 1 function. For running lights and brake/turn you would need three wires.
Same as in the diagram you attached.
Edit: As @herm0016 points out below, three conductors can be from two wires and ground.
/ Trailer Lights Gurus--Got a Question. #92
hook the ground wire to the chassis at each light, and the 2 wires, individually to the 2 other wires. we are not confused. electricity is not magic.
my trailer is set up exactly like this. grounds run to the mounting bolt of the light with a star washer.
/ Trailer Lights Gurus--Got a Question. #93
Here is one of your pictures labeled. You must have one wire for tail and one wire for stop-turn. Ground may be a wire to the trailer connector (Best) or a wire to the mounting bolt if the bolt isn't grounded (Not as reliable).
Bruce
Bruce
Thanks. I will give that a try. I guess the confusing part is the white wire on the trailer harness at each light location. This, to me, is ground or neutral but your comment earlier leads me to believe that the wire wire is actually is a substitute for brown for the tail lights. (running light) Then the second wire (black in my case) of the trailer harness would go to the yellow wire on the left side and green on the right side.
Thanks, will try that.
That fixed it! Everything works as it should. (even without the pickup lights turned on:))
The old lights only having two wires, a white and a black, and the wiring harness having a white and a black also made perfect sense that one of them was a ground. Right? No, wrong. The light mounting studs were the ground to the trailer chassis, I guess.
Not sure why the new LED's have a grounding wire instead of thru the mounting bolts. Maybe just because they are LED technology. (I did connect the white wires to the trailer chassis)
I should have figured this out a lot sooner but just needed some help from you guys.
Thanks again!
/ Trailer Lights Gurus--Got a Question. #97
Costello: And you don't know the fellows' names.
Abbott: Well I should.
Costello: Well then who's on first?
Abbott: Yes.
Costello: I mean the fellow's name.
Abbott: Who.
Costello: The guy on first.
Abbott: Who.
Costello: The first baseman.
Abbott: Who.
Costello: The guy playing...
Abbott: Who is on first!
Costello: I'm asking you who's on first.
Abbott: That's the man's name.
Costello: That's who's name?
Abbott: Yes.
Costello: Well go ahead and tell me.
Abbott: That's it.
Costello: That's who?
Abbott: Yes. PAUSE
Costello: Look, you gotta first baseman?
Abbott: Certainly.
Costello: Who's playing first?
Abbott: That's right.
Costello: When you pay off the first baseman every month, who gets the money?
Abbott: Every dollar of it.
Costello: All I'm trying to find out is the fellow's name on first base.
Abbott: Who.
/ Trailer Lights Gurus--Got a Question. #98
Abbott: Yes.
Abbott: Who.
Abbott: Who.
Abbott: Who.
Abbott: Yes.
Abbott: That's it.
Abbott: Yes. PAUSE
Abbott: Certainly.
Abbott: Who.
Are you a controller, and actuator, or possibly an instigator? :D
/ Trailer Lights Gurus--Got a Question. #99
If it were me, i'd have both (all) trailer white ground wires going into the trailer connector pin that connects to the truck white/gnd socket.
If you have the LED white wires grounded to the trailer, it sounds like you are using the actual hitch ball as the ground circuit to the truck. That will be very intermittent......
Actually the white ground wire runs from the pickup, where it is grounded to the frame, to the trailer via the 4pin connector. Then it connects to the trailer frame behind the trailer axle.
I thought, too, that it continued out to each light but therein lies my confusion and I still don't know who the hell is on first.
2017 Chevrolet Silverado 2500HD 4x4 Crew Cab Reading Service Truck (A68183)
2017 Chevrolet...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2019 JOHN DEERE 750K LGP CRAWLER DOZER (A65056)
2019 JOHN DEERE...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
