Lynch Pins Coming Off
/ Lynch Pins Coming Off
Slight tangent here, someone recently lost one of those smaller lynch pins on the road around here. My neighbor found it the hard way. Embedded in the left rear tire on his truck! Right through the tread.
That’s not good
/ Lynch Pins Coming Off #62
Forget the pins. I use equivalent sized bolts with nylon self locking nuts. I don't want to have a link pin fall out and bend the support arms, so lynch pins are out for me.
I've had the same issue repeatedly on a 7' finish mower; my solution was the same. Bolts long enough that the shank spans the entire load area, and nyloc nuts.
/ Lynch Pins Coming Off #63
There are several posts about this but not many recently so a new day means new ideas. When I brush hog a different lynch pin falls off nearly every time. I've brush hogged five times in the last two months and have lost four lynch pins.
Facts: I do have a lot of overgrown weeds and saplings and I do use the HD black lynch pins.
My question is how do I keep them from coming off? I don't care about losing them so much as I do about tearing up my equipment. Chaining them to somewhere on the tractor just keeps me from losing the pin but it doesn't stop the inevitable damage from the pin coming out. Is there a better more secure pin out there other than a bolt and nut? Duct tape? Key rings? Thanks in advance for any and all suggestions.
Might try using a bolt with a lock nut on it. Bigger pain to disconnect but it won’t come off on you
/ Lynch Pins Coming Off #64
/ Lynch Pins Coming Off #65
I would just use electrical tape so that they will never come off:) electrical tape...its not just for electricians in my garage.
/ Lynch Pins Coming Off #66
Buy a set of 6 cheap keyed alike locks. Used instead of pins in equipment and trailer hitched, etc. imo
/ Lynch Pins Coming Off #67
I have a few with the pin short enough that the circular keeper doesn’t stop on the pin, it passes it and the keeper lays flat against the implement. This lessens the chance of something getting behind it. It does make them more difficult for you to remove, but that what we are looking for right?
so cut or grind the end of them off a little.
/ Lynch Pins Coming Off #68
Mine were doing that on my rear finish mower, found out that they had too much slack on the shaft between the post and the pin, I installed a spring and a washer to keep the linchpins from rolling sideways which was a lot easier for them to come off and I haven’t haven’t had another problem Since doing that, been good for about 10 years now with no lost pins. I can take a picture later of what I’m talking about if you would like.
/ Lynch Pins Coming Off #69
Picture is worth a thousand words! Please send👍🏻👍🏻👍🏻
You will win the comment of the day!🚜✌🏻
/ Lynch Pins Coming Off #70
Way back when the Massey Ferguson 200 series were new they came with a locking linch pin. You had to squeeze he top so the bottom of the ring could be lifted to remove the pin. Some farmers cussed them because they did not squeeze them and actually bent the locking ring rendering them useless. I searched for them could not find them from Massey but did find the same pin used by JD pn AA23627. A quick search on the net finds the price at about $6.00. Don't know what other types cost but still cheaper than tearing up equipment.
/ Lynch Pins Coming Off #71
New to tractoring but I see this as a real problem. Now I’m wondering if a grade 8 bolt and a nut/jam nut would solve the problem. I don’t see where this would take longer than tape, zip ties or wire.
/ Lynch Pins Coming Off #72
A couple of things to try: Cut a piece of metal pipe to make a bushing to reduce the slack/play between the equipment frame and the lift arm. If you reduce this space so that the linch pin fits snugly beteeen the lift arm and the hole in your draw pin, that may fix the issue. The attached implement can move around enough to shear or dislodge your linch pin. A weak spring action in the pin could also cause it to come off.
See photo below for a hairpin cotter. Get the largest one that will fit in the drawpin hole and use those.
Both options are low cost and can keep the equipment secure. This could also prevent ruining a rear tire or breaking a top link (have had this to happen) if the equipment pitches off too far to one side.
  • Draw Pin.pdf
/ Lynch Pins Coming Off #73
That picture of the pin in Post 47 shows the problem! Way too much gap. I use the black "heavy duty" ones from TSC. One side is flat, they are a little longer than the standard one and the spring of the ring is tight. I ave not had one come off. Have bent several using the Intimidator Tree puller but usually straighten them back and keep using until I feel like they are bending too easily. Never lost one on the shredder but they do only close to the flat side.
/ Lynch Pins Coming Off #74
Drill a hole in the bottom of the pin, thread wire through and tie it off at the top of the pin.
This is what the military does with a lot of their aircraft.
/ Lynch Pins Coming Off #75
There's also the Rue Ring cotter pin
The popular and revolutionary Rue Ring™ Locking Cotter Pin surrounds the shaft and locks itself on, making it one of the safest cotters available today- unlike R Clips and other Cotter Pin Clips. Rue Ring™ Locking Cotter Pins are best used on light to medium applications. Rue Ring™ Locking Cotter Pins install fast without tools.[/unquote]
/ Lynch Pins Coming Off #76
IMHO The best solution is to use a padlock and key or a combo lock. If using a key attach the key to your tractor key ring or handy area on the ROPS where the sticks and weeds cannot dislodge the key.
/ Lynch Pins Coming Off #77
I gave up for my back blade and just used bolts & nuts. It stays on now.
/ Lynch Pins Coming Off #78
Zip ties.
/ Lynch Pins Coming Off #80
I assume it is the under growth unlatching the pins so would it be better to fit a suitable nut and bolt for this job. The inconvenience of fitting them is offset to the damage that could be done to the PTO shaft etc..
