Lynch Pins Coming Off
/ Lynch Pins Coming Off #41
I don't think I have ever lost a lynch pin. I almost have all of my implements converted so I don't use them much anymore. I use the 5/16" half moon shaped ones as shear pins in my finish mower. I keep a load of those. But since I got rid of the fire ant beds I don't shear pins anymore.
I kept losing them on my 3 point mower wheels and trying to find the spacers got old quick. A careful loop and twist of safety wire fixed my issue so they can't open. For something that you constantly remove, probably not the best idea though.
I have some baling wire, I'll try that too!
Thank you!
/ Lynch Pins Coming Off #47
This is one of the failed pins. Pretty obvious what the issue is :-(
/ Lynch Pins Coming Off #48
Some types of these pins are not symmetrical. They close with more force and more completely in one direction. In the other direction they don't have as much force and don't close all the way.
/ Lynch Pins Coming Off #49
That was the only direction it would even come close to closing. I got the new ones and they close with some force like they should.
/ Lynch Pins Coming Off #54
I finally got the bail to move over. Don't trust it as it had something stuck in there :-0
/ Lynch Pins Coming Off #55
On my 3 pt I have 4 lynch pin locations.
They held 5/8" pins in place.
My 'cure' was to replace those 5/8" 'pins' with short 5/8" bolts and self locking nuts.
That was years ago when I got fed up limping home for lack of spares on board.
Haven't suffered lynch pin issues ever since.
Another 'cure' I came up with was to use some wire to safety my 3-point turnbuckles after having lost one. That cost me a whole new adjustment kit since the turnbuckle only was not to be had.
(well it actually was but combined with shipping fees it was cheaper to buy an aftermarket kit)
(The handiest safety wire is Hydro lineman's aluminum wire* that they carry in a roll on their trucks. Easy to shape and holds without twisting.)
* I now keep a few lengths on my tractor at all times.
/ Lynch Pins Coming Off #56
I've never lost a pin. I've lost a couple hairpin keepers on the pins where my lower 3-point arms attach to the tractor. At those two points I've gone to bolts with double nylon keeper nuts. Base to base - torqued down tight and LockTite.
This has solved the problem for me. The rest of the locations - I use those snap over pins that S219 speaks of. And, yes, they hurt real bad when they snap shut on my fingers.
I think what sickeys did - post#52 is a good answer also.
I’m putting bolts and nuts on the front side of my lift arms. Safety wire on others. Thank you!
Thank you for your input. Like I said, bolts and nuts on the front of my 3 point lift arms, wire on the others that keep disappearing. That’s my new plan. Thanks again!
/ Lynch Pins Coming Off #60
Slight tangent here, someone recently lost one of those smaller lynch pins on the road around here. My neighbor found it the hard way. Embedded in the left rear tire on his truck! Right through the tread.
2022 EZ-GO ELITE...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
213065 (A64276)
213065 (A64276)
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2014 Ford F-550 4x4 Versalift SST40EIH-01 40ft. Insulated Bucket Truck (A64556)
2014 Ford F-550...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
