ANOTHER ELECTRICAL QUESTION
   / ANOTHER ELECTRICAL QUESTION #1
TBone
LA (Lower Alabama)
Kubota L-2501 HST
I have a subpanel with 12 - 120v circuits. The sheathing on the romex wires coming into the panel was cut back so far that I cannot determine which hot wires are paired with which neutral. Without going into a long explanation why, I have a need to know which neutral goes with each hot wire. Anybody got any suggestions on how I can determine that? Thanks.
   / ANOTHER ELECTRICAL QUESTION #3
I have a subpanel with 12 - 120v circuits. The sheathing on the romex wires coming into the panel was cut back so far that I cannot determine which hot wires are paired with which neutral. Without going into a long explanation why, I have a need to know which neutral goes with each hot wire. Anybody got any suggestions on how I can determine that? Thanks.[/
probably the only solution is to cut out an area above the panel.
   / ANOTHER ELECTRICAL QUESTION #4
An electrician that does neat work will have the Sheathing cut back close to the cable connector. He/she will also form and layer the wires neatly in the panel.
So you need to KILL the power to the panel, trace the hot wire from the breaker to where it comes in the panel and then pull out the neutral.
   / ANOTHER ELECTRICAL QUESTION #5
I would turn the power off to the panel and disconnect all of the white, neutral wires and all of the ground wires. Then I would do a continuity test from the hot wire to the neutral wires. If one of them goes to a light, the switch will have to be on. If they all go to outlets, then the meter will make a sound when you have continuity.
How To Test For Continuity | Fluke
I can see where the light switch trick would work but if the circuit only went to outlets there would have to have a load on them wouldn't they? I don't think you would get continuity between the hot and neutral on an open circuit. I do have a good multi-meter.
   / ANOTHER ELECTRICAL QUESTION #8
They are in rigid conduit.
If they are in conduit then they should not have the outer wrap of Romex cable but just single strand wire such as THHN. To put romex in conduit I believe would be a code violation.
   / ANOTHER ELECTRICAL QUESTION #9
You can match the current. By that I mean turn off all other loads on the circuit in question. Then put a heat gun or other known load on that circuit and if it pulls 9 amps on the hot, 9 amps will be coming back on the paired neutral.
   / ANOTHER ELECTRICAL QUESTION #10
Just plug in a 110 v heater or something.
1761 (A58375)
1761 (A58375)
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2010 BOBCAT TOOLCAT 5610 UTILITY WORK MACHINE (A59823)
2010 BOBCAT...
Deere 310SK (A57148)
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
