SSQ Bucket falls off
/ SSQ Bucket falls off #61
A friend builds many SS buckets and other attachments, builds and adapts tractors to SS making unique couplers. He also has a CASE SS of his own. Compared to the other AG attachment systems, he has little nice to say about the strength and integrity of the SS system.
The OP's machine is ~ 30HP,, I have a tractor that is double that horsepower, and around triple the weight,,
Many skid steers are over 100HP,,,
If there were A N Y issue with SSQA strength or design,, I am sure there would be more than T W O negative comments,,, :confused3:
IMHO,, I like the SSQA,, :thumbsup: (mostly, because I like typing SSQA,,,) :laughing:
/ SSQ Bucket falls off #62
Whether you like it or not, or me for that matter is not the issue. It's NOT a well designed or very strong system. A good system can not come off, no way, no how. A system where you could pry the tool off, is not a well engineered system. And that, the likihood of that happening depending on the various tolerences involved is of no comfort either.
/ SSQ Bucket falls off #63
My SSQA attachments won’t stay on well if the gap on both sides where the upper angle fits into the attachment
Kubota MX
Andy
/ SSQ Bucket falls off #65
I agree. For high HP, high capacity systems the European method used by JD on their larger tractors is much preferred. The SSQA system definitely has limitations. Non of which have been approached by the OP.
/ SSQ Bucket falls off #66
I have ripped the bottom (where the pins are arrested) out of a SS plate on my snow plow. Not much material there.
And I don't even understand why those pins are wedge shaped. To me, they go the wrong way, if I recall.
/ SSQ Bucket falls off #67
The lower they go, the tighter the connection. No other way to design them. Reversed, the taper would be worthless.
/ SSQ Bucket falls off #68
Seems to me, the pins move in a pipe, straight up and down, and the bevelled end is not acting on the piece of plate that I tore out. I could be totally confused.
/ SSQ Bucket falls off #69
That's possible.
/ SSQ Bucket falls off #70
Most of the SSQA problems that I have read about are on Kubota and other tractor loaders.
I think they cheaped out when they made their QA.
I have lifted over 6,000 pounds on the Bobcat SSQA, but to me it looks stronger than the tractor QA.
/ SSQ Bucket falls off #71
Yeah, I don't get the wedges. They don't draw the plate in. What do they do? Maybe just pierce through dirt/frozen dirt and ice. But they don't tighten up in any way.
/ SSQ Bucket falls off #72
They pin the plate to the QA.
Does this drawing help?
/ SSQ Bucket falls off #73
Thanks. I meant the slant serves no purpose of acting like a wedge. Only, maybe to pierce an obstruction in the opening. Some Ag attachment systems do use wedges for a secure attachment.
/ SSQ Bucket falls off #74
I would be ordering up some stiffer springs for one thing.
/ SSQ Bucket falls off #75
Great news!
You aren’t the first person to have this problem. Back in about 2004 I had an L4330 with an LA 853 loader and the ssqa bucket would fall off. I posted my problem here back then luckily others had the same issue and gave me their fix for the LA 853;
Stack several large flat washers in the locking mechanism so the spring gets totally compressed. It fixed mine and the bucket never came off again.
Back then many others did the exact same thing.
I sold the tractor years ago for a bigger M95 or I would go take a picture of the washer set up.
/ SSQ Bucket falls off #76
Take a second to review his top pic. It clearly shows how they work. If you still don't get it then you'll just hafta take our word for it.
/ SSQ Bucket falls off #77
Presumably the ssqa and bucket were working fine until recently? And now the bucket falls off 7 times in a day. Ought to be fairly straightforward to figure out what changed.
Greased pins and no stop blocks. Previously the springs and friction were sufficient to prevent the pins from rising. Stop blocks make it impossible for the pins to rise enuf to get out of the bucket slots.
/ SSQ Bucket falls off #78
Popularity of the SSQA ensures ready availability of a wide range of implements in that style.
/ SSQ Bucket falls off #79
What Tractor Mike said, I always raise the implement and look to be sure the pins are engaged. IMO, greasing aids in allowing the springs to keep the wedges self-tight. Up to a point, the more spring pressure the better, esp if they don't bind as they cam over. I cannot reach across from one side to tighten the opposite-side locking lever. If I could, I'd tighten or replace the springs, hoping not to rely on the blocks alone.
Wear on the OP's tabs looks to be made worse by the bucket falling off so many times. I agree that shimming the lower plate to tighten the fit might help, say test-fitting spacer metal into the gap with the bucket attached to determine a fairly snug fit. Then, I'd want to be sure the downward limit of pin travel allows contact hopefully on the upper half of the pins' tapers. It was asked about.
btw, can you say "stacking tolerances"?
/ SSQ Bucket falls off #80
Great news!
You aren稚 the first person to have this problem. Back in about 2004 I had an L4330 with an LA 853 loader and the ssqa bucket would fall off. I posted my problem here back then luckily others had the same issue and gave me their fix for the LA 853;
Gene has the answer. Apply more pressure to the locking pins so they can't work up and out of the slots in the implement. Greasing the pins may be making the problem worse too. Grease can help the pins slip in the slots easier but it can also help them slip out of the slots easier.
Towable Generator (A60352)
Towable Generator...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
John Deere 772-A Grader (A62679)
John Deere 772-A...
