SSQ Bucket falls off
/ SSQ Bucket falls off #41
Cadplans, not sure what you're arguing about. Your pins are set up just as the ones in the picture, difference being yours are rectangular the OP are round.
/ SSQ Bucket falls off #42
Not arguing,, just adding data to the discussion,,
/ SSQ Bucket falls off #43
I think he's referring to your comment "just for the sake of argument". That implies you want to "argue". :)
/ SSQ Bucket falls off #44
maybe it's just a "feature". it's easier to remove, and will fall off if used improperly, preventing breakage!..
/ SSQ Bucket falls off #45
Presumably the ssqa and bucket were working fine until recently? And now the bucket falls off 7 times in a day. Ought to be fairly straightforward to figure out what changed.
/ SSQ Bucket falls off #46
Take a big hammer to the pin slot and straighten it up to tighten against the pin
/ SSQ Bucket falls off #48
just weld another thickness of steel onto the implement receiving hole where the QA pin goes through and be done with it
I dont see any wear or bending that isn't supposed to be bent. The cut out box lines are straight with no indication on any wear other than paint worn off . From the scrapped off paint, it looks like the OP might be trying to hook up on unlevel ground because the paint is scuffed off badly on the left side but not on the right.
Try hooking / unhooking on level ground and it will go easier although really not necessary. The way to hookup it to tilt your QA assembly to full dump and maneuver it under to top lip till both sides are fully engaged, then raise the FEL and tilt the bucket back so the weight of the bucket is keeping it engaged against the pins the lower the handles fully to engage the pins and compress the spring.
There is an adjustment to adjust the spring tension. It should be really tight but no so tight that you cant fully depress the lever.
My brother-in-law's New Holland got so loose once that there was no spring tension to hold the pin down. The pin was about 1 thread from falling off, so check that also.
Gary, you are correct. I have been hooking the bucket up in some very odd positions due to it falling off while loading dirt in a ditch along the road. I could have put a chain around it and pulled it to level ground but it has happened so frequently it was wearing me out.
I am going to adjust the pin/spring tension and see if that works. I would say the handles are snug but not too difficult to push down and lock into place.
The upper wedge of the bucket doesn't appear bent or to be an issue.
Many thanks to you all. You have been very helpful.
/ SSQ Bucket falls off #50
Also, check the receiver on the loader. It should be even and straight. Sometimes the cylinders will not extend or retract evenly without something ridged (bucket, forks, etc) connected. that may be causing the SSQA to not be tight enough to engage the locking pin allowing it to slip behind the slot
:confused::confused3:
/ SSQ Bucket falls off #51
When the handles go "over center" they should almost compltely compress the spring.
/ SSQ Bucket falls off #52
What loader? If it's the LA723, there were two different models QA for them.
/ SSQ Bucket falls off #55
So a couple people responded that they did not see what I think is wear on the bucket.
My eyes are not what they used to be, however this still looks like a problem to me.
Maybe the main problem, maybe not, but looks like it needs to be addressed.
/ SSQ Bucket falls off #56
If it is bent down it definitely needs to be addressed, but the way I see it, it looks liked scraped paint, but I am using my phone so it it could be bent.
/ SSQ Bucket falls off #57
Am I just seeing things?View attachment 607527
No I see it too. The sun angle and shadow make it hard to see.
I lightened the picture to make the shadow stand out and added a straight line along the edge of the slot:
The worn spot shows in the dip on the shadow on the back of the bucket.
The way the slot is worn, the pin should be worn at the edges and not flat all the way across.
But I don't think the slight amount of wear would cause the bucket to come off.
/ SSQ Bucket falls off #58
Yeah that would definitely need to be fixed unless you can make the pin drive further down in the hole to cause more friction. If it’s wore like that, I’m curious how worn are the pins.
/ SSQ Bucket falls off #60
A friend builds many SS buckets and other attachments, builds and adapts tractors to SS making unique couplers. He also has a CASE SS of his own. Compared to the other AG attachment systems, he has little nice to say about the strength and integrity of the SS system.
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
2022 Case TV450B (A64126)
2022 Case TV450B...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
