If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #561
Check the purchase contract, it should have a short warranty.
Call the dealer, he should fix it.
   / If you have Toolcat questions, ask them here... #562
He said if its not something major it would be on me.
So I am trying to do everything I can before calling Bobcat to come out.
It there a source of wiring diagram?
   / If you have Toolcat questions, ask them here... #563
Also fuses are not labeled.
The fuses I am checking are below front of driver seat.
Fuse box you need is located by right knee when sitting in the seat. :thumbsup:
   / If you have Toolcat questions, ask them here... #564
Nothing on the wall by the right knee.
Box I see is between my legs.
Does the box stick out or is it behind a panel?
   / If you have Toolcat questions, ask them here... #565
Removed the selector arm.
seems like common in Pin 1
Pin1 to Pin 2 looks like rabbit button - momentary contact,
Pin 1 to 5 active in park
1 to 6 in forward
1 to 4 in reverse.
Looks like actuator/lever switch is working ok
   / If you have Toolcat questions, ask them here... #566
1 to 6 in forward
1 to 4 in reverse.
Do you have 12v going to it?? :confused3:
   / If you have Toolcat questions, ask them here... #567
Page 90 of your manual.
   / If you have Toolcat questions, ask them here... #568
Just an FYI if one of my fellow Toolcat aficionados or Bobcatters in general pull a boner like me and crush their 7-pin connector between the SSQC and your attachment there is an alternative to the $300+ cable replacement.. Not associated with this company but I did order the connector on Monday for $98 and was in my mailbox yesterday.. 1 man band.. for people running non skid steer attachments also make harness kits and what not..
Skid Steer Genius designs and manufactures industrial control systems.
   / If you have Toolcat questions, ask them here... #569
Just an FYI if one of my fellow Toolcat aficionados or Bobcatters in general pull a boner like me and crush their 7-pin connector between the SSQC and your attachment there is an alternative to the $300+ cable replacement.. Not associated with this company but I did order the connector on Monday for $98 and was in my mailbox yesterday.. 1 man band.. for people running non BOBCAT skid steer attachments also make harness kits and what not..
   / If you have Toolcat questions, ask them here... #570
Yep, I bookmarked this page a long time ago: Bobcat(R) 7 Pin Adapters – Skid Steer Genius
   / If you have Toolcat questions, ask them here... #571
Now newbies like me have this information too.....thanks guys!
   / If you have Toolcat questions, ask them here... #572
Wow, that was timely. Thanks to you and Xfaxman! One of the pins inside my blower connector is looking pretty weak and I was going to take an AED with me to the Bobcat dealer to get a quote on a replacement cable.
   / If you have Toolcat questions, ask them here... #573
Does anyone know if the curl cylinder circuit and the dump bed cylinder circuit on the 5600 are designed to purposely bleed off for some reason?
DEWFPO
   / If you have Toolcat questions, ask them here... #574
Dewdpo, I do not know
   / If you have Toolcat questions, ask them here... #575
They are not designed to intentionally bleed down but there is not load holding valve in either circuit so rate of bleed down depends on rate of by-pass in the valve spool (spool OD to vavlve housing ID), then could have added bleed down if cylinder seal is leaking allowing oil to exit both ends of the cylinder.
   / If you have Toolcat questions, ask them here... #576
Thanks SSdoxie.
DEWFPO
   / If you have Toolcat questions, ask them here... #577
my toolcat will not bleed down and Im guessing it should not, its a 2005 vintage
   / If you have Toolcat questions, ask them here... #578
Than I'm jealous. Mine's a 2009 Series D purchased in late 2008 and it does.
DEWFPO
   / If you have Toolcat questions, ask them here... #579
the 2005 toolcat A series, couple issues, the locking axle requires both front steer and rear to be illuminated to engage, you can steer in 2 wheel and it will stay engaged but if i let the switch off and the front steer is not centered it will not engage until i realign, this how it should be?
now to my next question, when the indicator says both steer axles are aligned it turns to the left slightly, is this a adjustment of a sensor and easily accessed?
   / If you have Toolcat questions, ask them here... #580
Has anyone removed the black plastic hood/visor at the top/front of the cab that houses the 4 off-road/work lights? I am installing a magnetic rotating beacon and side work lights and want to run the wiring into that covering and down the A pillar to the dash. Has anyone done this? Any tips or pitfalls?
Thanks, DEWFPO
I have mine off along with the entire cab, Mine already had the beacon installed but once you remove the roof liner and the plastic hood/visor it will be very easy to run the wires along roof above door on right side, and down the back wall there is a place to hide the wire to get it down to behind your seat. If you want I can get you some pics mine is all torn apart currently with cab off unit, and everything out of cab.
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2002 Bobcat 763 Compact Skid Steer (A56438)
2002 Bobcat 763...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2018 Toro Sand Pro 5040 Bunker Rake (A59228)
2018 Toro Sand Pro...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
