If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #521
Were you able to get your radio working?
   / If you have Toolcat questions, ask them here... #522
I did not get it working yet couldn't find fuse. Need to trace wiring but used it for 30 inches of snow we just got. Haven't looked in detail but now i have a wire grounding somewhere as the wheel sensor code of 50-13 keeps coming and going.
   / If you have Toolcat questions, ask them here... #523
In my manual is shows two radio power options. As trebdubs mentioned there is a switch batt option powered via fuse 10 and there is an unswitched option powered via fuse 8.
On my unit there was an in-line connector in the power wire above the headliner that runs along side the antenna. Maybe yours is lose?
   / If you have Toolcat questions, ask them here... #524
New to this forum have a question on a 2017 5600 toolkit. Seems to be in the morning when we go to start it up the engine starts and quits. For the most part it usually starts after that and keeps running the rest of the day. the other morning I started and it did the exact same thing a few times and then it was okay. some days it does not do it all. I am thinking key switch but figured I would run the question here first if there was possibly something else that I am not aware of.
thank you
   / If you have Toolcat questions, ask them here... #525
not sure about the toolcat but the Deere and Cat have a relay to hold the fuel shutoff open, during starting the solenoid is held during the cranking, once it fires it is held by a relay, if this relay is bad the fuel shutoff closes and motor will die, will allays fire back up with the turn of the key
   / If you have Toolcat questions, ask them here... #526
Can anyone tell me if Bobcat has finally solved the problem with curl cylinder not holding pressure on the newer Toolcats?
DEWFPO
   / If you have Toolcat questions, ask them here... #527
No they haven't at least not on mine, a 5610 G series.
I have a 72" Brushcat mower and have to constantly adjust the height of the front or it starts dragging.
   / If you have Toolcat questions, ask them here... #528
the Toolcat heating system, there is the valve under the drivers seat and the rheostat on the dash, going to take out the rheostat tomorrow and check but at the valve there is no voltage change regardless where the dial is set, best guess does this mean the rheostat is bad? anything else I should check?
   / If you have Toolcat questions, ask them here... #529
i just had a similar experience with my machine and the A/C its a used machine and I could not get cold air after the engine warmed up. come to find out the previous owner removed the valve under the drive seat. so my ac was fighting the heat. had to make a quick fix. installed a ball valve in the line and shut the heat off. looked at the cost for a new valve, well over $200 so I think I will just keep the $5 ball valve and manually change over from ac to heat when needed.
   / If you have Toolcat questions, ask them here... #530
craneman13, where did you locate the ball valve?
   / If you have Toolcat questions, ask them here... #531
the valve is located under the driver seat. the previous owner had removed that valve and just put a "coupling" or barbed hose connector in its place. I removed that and put a ball valve with barb fittings on both ends. 1/2" is the size. again it is a cheap, fast fix, and I will look at buying a true valve sometime in the near future. but at least now I have nice cool cab to sit in to mow with.
   / If you have Toolcat questions, ask them here... #532
craneman13, my valve is under the seat but to access requires to remove the seat and cover, Im thinking locating the ball valve just under the cab accessed by raising the box,
   / If you have Toolcat questions, ask them here... #533
anybody ever break the glass on a toolcat?? I have F series and broke the passenger door upper rear window yesterday.. looking at the Bobcat parts sight I have to replace the upper front & rear door glass as an assembly.. I'm sure that won't be cheap.. anybody familiar with other options??
   / If you have Toolcat questions, ask them here... #534
No, not on the Toolcat, but did on the Versahandler. Took the frame to the local glass shop, he cut and tempered the replacement safety glass for a lot less than the cost of the replacement part.
I looked at the Toolcat and don't see how to remove the hinge.
Trailer it to a Auto Glass shop and see what they say.
Keep us posted so I know what to do when ours gets broken. :)
   / If you have Toolcat questions, ask them here... #535
$455.00 for both upper window passenger door glass (only way they sell it). Dealer said he's sold 2 of them already this year... should be at the dealer by the end of this week.. that will get me to pay more attention....
   / If you have Toolcat questions, ask them here... #536
I need to move a Toolcat a few hundred yards to get it under a roof and out of the sun to work on it. It currently will not start. Is there anything in particular that I need to do before I try to tow it?
Thanks.....
   / If you have Toolcat questions, ask them here... #537
My G series manual pg96 states there is no recommended towing procedure. They say you can lift it to a trailer or skid it a short distance (wheels wont turn). :confused:
   / If you have Toolcat questions, ask them here... #538
I found some information on another thread that says you need the 4 magic bolts for towing the A thru C models. These apparently can not be used for the D-model. Anyone have any information regarding the newer models?
   / If you have Toolcat questions, ask them here... #539
ruffdog...thanks for the info. I guess they expect you to skid it short distances. My John Deere hydrostat has two screws that you simply turn a quarter turn and then it can be towed.
   / If you have Toolcat questions, ask them here... #540
The F Series is the same, the wheels won't turn because the brakes are on. The brakes are released by hydraulic pressure after the motor starts.
What Series is yours?
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2021 HYUNDAI ROBEX 35Z-9A EXCAVATOR (A60429)
2021 HYUNDAI ROBEX...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
