If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #561
Check the purchase contract, it should have a short warranty.
Call the dealer, he should fix it.
   / If you have Toolcat questions, ask them here... #562
He said if its not something major it would be on me.
So I am trying to do everything I can before calling Bobcat to come out.
It there a source of wiring diagram?
   / If you have Toolcat questions, ask them here... #563
Also fuses are not labeled.
The fuses I am checking are below front of driver seat.
Fuse box you need is located by right knee when sitting in the seat. :thumbsup:
   / If you have Toolcat questions, ask them here... #564
Nothing on the wall by the right knee.
Box I see is between my legs.
Does the box stick out or is it behind a panel?
   / If you have Toolcat questions, ask them here... #565
Removed the selector arm.
seems like common in Pin 1
Pin1 to Pin 2 looks like rabbit button - momentary contact,
Pin 1 to 5 active in park
1 to 6 in forward
1 to 4 in reverse.
Looks like actuator/lever switch is working ok
   / If you have Toolcat questions, ask them here... #566
1 to 6 in forward
1 to 4 in reverse.
Do you have 12v going to it?? :confused3:
   / If you have Toolcat questions, ask them here... #567
Page 90 of your manual.
   / If you have Toolcat questions, ask them here... #568
Just an FYI if one of my fellow Toolcat aficionados or Bobcatters in general pull a boner like me and crush their 7-pin connector between the SSQC and your attachment there is an alternative to the $300+ cable replacement.. Not associated with this company but I did order the connector on Monday for $98 and was in my mailbox yesterday.. 1 man band.. for people running non skid steer attachments also make harness kits and what not..
Skid Steer Genius designs and manufactures industrial control systems.
   / If you have Toolcat questions, ask them here... #569
Just an FYI if one of my fellow Toolcat aficionados or Bobcatters in general pull a boner like me and crush their 7-pin connector between the SSQC and your attachment there is an alternative to the $300+ cable replacement.. Not associated with this company but I did order the connector on Monday for $98 and was in my mailbox yesterday.. 1 man band.. for people running non BOBCAT skid steer attachments also make harness kits and what not..
   / If you have Toolcat questions, ask them here... #570
Yep, I bookmarked this page a long time ago: Bobcat(R) 7 Pin Adapters – Skid Steer Genius
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
Case 930 Tractor (A59814)
Case 930 Tractor...
2018 CON-WAY DOLLY (A59575)
2018 CON-WAY DOLLY...
1995 Rinker Captiva 190 (A56436)
1995 Rinker...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
