If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #561
Check the purchase contract, it should have a short warranty.
Call the dealer, he should fix it.
   / If you have Toolcat questions, ask them here... #562
He said if its not something major it would be on me.
So I am trying to do everything I can before calling Bobcat to come out.
It there a source of wiring diagram?
   / If you have Toolcat questions, ask them here... #563
Also fuses are not labeled.
The fuses I am checking are below front of driver seat.
Fuse box you need is located by right knee when sitting in the seat. :thumbsup:
   / If you have Toolcat questions, ask them here... #564
Nothing on the wall by the right knee.
Box I see is between my legs.
Does the box stick out or is it behind a panel?
   / If you have Toolcat questions, ask them here... #565
Removed the selector arm.
seems like common in Pin 1
Pin1 to Pin 2 looks like rabbit button - momentary contact,
Pin 1 to 5 active in park
1 to 6 in forward
1 to 4 in reverse.
Looks like actuator/lever switch is working ok
   / If you have Toolcat questions, ask them here... #566
1 to 6 in forward
1 to 4 in reverse.
Do you have 12v going to it?? :confused3:
   / If you have Toolcat questions, ask them here... #567
Page 90 of your manual.
   / If you have Toolcat questions, ask them here... #568
Just an FYI if one of my fellow Toolcat aficionados or Bobcatters in general pull a boner like me and crush their 7-pin connector between the SSQC and your attachment there is an alternative to the $300+ cable replacement.. Not associated with this company but I did order the connector on Monday for $98 and was in my mailbox yesterday.. 1 man band.. for people running non skid steer attachments also make harness kits and what not..
Skid Steer Genius designs and manufactures industrial control systems.
   / If you have Toolcat questions, ask them here... #569
Just an FYI if one of my fellow Toolcat aficionados or Bobcatters in general pull a boner like me and crush their 7-pin connector between the SSQC and your attachment there is an alternative to the $300+ cable replacement.. Not associated with this company but I did order the connector on Monday for $98 and was in my mailbox yesterday.. 1 man band.. for people running non BOBCAT skid steer attachments also make harness kits and what not..
   / If you have Toolcat questions, ask them here... #570
Yep, I bookmarked this page a long time ago: Bobcat(R) 7 Pin Adapters – Skid Steer Genius
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2018 Chevrolet Camaro 1LT Coupe (A59231)
2018 Chevrolet...
