MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,307
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Look at the guys who operate the stand behind mowers on steep banks. They have no problem. As long as the ergonomics of the machine work well for the standing position it's easy and secure. In my case my heals lock into a spot on each side of the transmission hump and my legs straddle the steering wheel. So I have 4 points of contact with my feet / legs. I acknowledge that this works so well because the ergonomics of my particular machine fit my 6'3" frame well in the standing position and that if I were much shorter, the position wouldn't work as well. But I don't need to stand to see the tips of my forks. I can see them on the ground from the seated position. If I stand, I can see the full attachment up front. I typically only stand up when I need that little extra visibility or if digging out a stump with the stump bucket. Then I stand the entire time for skid steer like visibility.
One of my CUT criteria when shopping was visibility and I didn't even look at anything that didn't have a seat height higher than the front of the hood. The JD CUTs are terrible. The seats are so low and hoods so high (with exception of the JD 110 which is awesome)
After purchasing my tractor, I build brackets to raise the seat a little more. This was to fit my long legs in the seated position, but it had the added benefit of increasing seated visibility.
I've been eyeing up the JD110 in our local cemetery where we take walks a few times a week. Pretty neat machine. Gets into really tight spaces between all the graves and has no problem lifting the concreted vaults into the holes.
